[petsc-users] snes/ex19 issue with nvprof
Xiangdong epscodes at gmail.com
Sat Jul 6 22:35:34 CDT 2019
Hi Mark,
For your latest commit 9ab9e86e1e, I can get the normal run working by
either commenting out all PetscCheckTypeNames in veccuda2.cu or use
"-dm_vec_type cuda" instead of "-vec_type cuda".
However, even with your latest commit, I still got an error when using
nvprof (different lines reported). I checked that I did use same cuda
driver and library (cuda_10.1.168_418.67_linux).
 eps at new:~/MyCodes/petsctest$ nvprof --profile-child-processes mpiexec -np
1 ./extest -da_refine 5 -snes_view -snes_monitor -ksp_monitor -mat_type
aijcusparse -dm_vec_type cuda
==8902== NVPROF is profiling process 8902, command: ./extest -da_refine 5
-snes_view -snes_monitor -ksp_monitor -mat_type aijcusparse -dm_vec_type
cuda
lid velocity = 0.000106281, prandtl # = 1., grashof # = 1.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Error in external library
[0]PETSC ERROR: CUDA error 700
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.11.3-1103-g9ab9e86e1e
 GIT Date: 2019-07-06 17:40:27 -0400
[0]PETSC ERROR: ./extest on a arch-debug-origin named new by eps Sat Jul  6
23:24:58 2019
[0]PETSC ERROR: Configure options PETSC_ARCH=arch-debug-origin
--with-debugging=1 --with-mpi-dir=/home/eps/MyLocal/mpi/mpich --with-cuda=1
--download-fblaslapack
[0]PETSC ERROR: #1 VecCUDACopyFromGPU() line 131 in
/home/eps/MyLocal/petsc-latest/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
[0]PETSC ERROR: #2 VecGetArray() line 1556 in
/home/eps/MyLocal/petsc-latest/src/vec/vec/interface/rvector.c
[0]PETSC ERROR: #3 VecGetArray2d() line 2185 in
[0]PETSC ERROR: #4 DMDAVecGetArray() line 68 in
/home/eps/MyLocal/petsc-latest/src/dm/impls/da/dagetarray.c
[0]PETSC ERROR: #5 FormInitialGuess() line 223 in
/home/eps/MyCodes/petsctest/extest.c
[0]PETSC ERROR: #6 main() line 159 in /home/eps/MyCodes/petsctest/extest.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -da_refine 5
[0]PETSC ERROR: -dm_vec_type cuda
[0]PETSC ERROR: -ksp_monitor
[0]PETSC ERROR: -mat_type aijcusparse
[0]PETSC ERROR: -snes_monitor
[0]PETSC ERROR: -snes_view
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
==8902== Profiling application: ./extest -da_refine 5 -snes_view
-snes_monitor -ksp_monitor -mat_type aijcusparse -dm_vec_type cuda
==8902== Profiling result:
No kernels were profiled.
No API activities were profiled.
==8902== Warning: Some profiling data are not recorded. Make sure
cudaProfilerStop() or cuProfilerStop() is called before application exit to
flush profile data.
======== Error: Application returned non-zero code 76
Thank you.
Best,
Xiangdong
On Sat, Jul 6, 2019 at 5:51 PM Mark Adams <mfadams at lbl.gov> wrote:
> I'm using CUDA 10.1.105 and this looks like a logic bug and not a CUDA
> problem.
> I added two MatSetType calls that I thought were the right thing to do.
> Your error is a type problem and test with DMPlex so the matrix creation
> goes through a different code path.
> You could try removing them and see if it works.
> That is really all there is in this branch at this point other than some
> ViennaCL stuff.
> I would verify that a fresh pull from master works. I would also
> reconfigure. I have just pulled from master and pushed so you can do a
> fresh pull.
> On Sat, Jul 6, 2019 at 4:07 PM Xiangdong <epscodes at gmail.com> wrote:
>> Hi Mark,
>> Yes, I am using your branch (mark/gamg-fix-viennacl-rebased) with Petsc
>> Development GIT revision: v3.11.3-1064-g8b74309384. I compiled PETSc with
>> CUDA 10.1.
>> Which version of CUDA are you using?
>> Thanks.
>> Xiangdong
>> On Sat, Jul 6, 2019 at 1:43 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> I am not able to reproduce this error. THis is what I get. Are you
>>> pulling from mark/gamg-fix-viennacl-rebased ?
>>> 13:38  /gpfs/alpine/scratch/adams/geo127$ jsrun -n 1 -c 4 -a 4 -g 1
>>> ./ex19 -da_refine 5 -snes_view -snes_monitor -ksp_monitor -mat_type
>>> aijcusparse -vec_type cuda -log_view
>>>   0 SNES Function norm 1.036007954337e-02
>>>     0 KSP Residual norm 9.144944502871e-02
>>>     1 KSP Residual norm 2.593759906204e-02
>>>     2 KSP Residual norm 1.669815200495e-02
>>>     3 KSP Residual norm 1.510777951698e-02
>>>     4 KSP Residual norm 1.458401237884e-02
>>>     5 KSP Residual norm 1.418635322926e-02
>>>     6 KSP Residual norm 1.377436725003e-02
>>>     7 KSP Residual norm 1.332236907186e-02
>>>     8 KSP Residual norm 1.288602527920e-02
>>>     9 KSP Residual norm 1.240018288138e-02
>>>    10 KSP Residual norm 1.186798872492e-02
>>> On Fri, Jul 5, 2019 at 11:07 PM Xiangdong <epscodes at gmail.com> wrote:
>>>> Hi Mark,
>>>> After pulling your new commit, I got an error when running ex19 (even
>>>> without nvprof). Same error with version 3.11.3. But ex19 run fine with old
>>>> commit 64edb9194a9.
>>>> Below is a run time log error file. By the way, which version of cuda
>>>> does PETSc support?
>>>> Thank you.
>>>> Xiangdong
>>>>     0 KSP Residual norm 9.158537890035e-02
>>>> [0]PETSC ERROR: Invalid argument
>>>> [0]PETSC ERROR: Object (seq) is not seqcuda or mpicuda
>>>> [0]PETSC ERROR: See
>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>> shooting.
>>>> v3.11.3-1064-g8b74309384  GIT Date: 2019-07-03 10:24:59 -0400
>>>> [0]PETSC ERROR: ./extest on a arch-debug2 named new by eps Fri Jul  5
>>>> 22:57:02 2019
>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=arch-debug2
>>>> --with-blaslapack-dir=/home/eps/MyLocal/intel/mkl --with-cuda=1
>>>> [0]PETSC ERROR: #1 VecCUDAGetArrayRead() line 1304 in
>>>> /home/eps/MyLocal/petsc-mark/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
>>>> [0]PETSC ERROR: #2 MatMultAdd_SeqAIJCUSPARSE() line 1415 in
>>>> /home/eps/MyLocal/petsc-mark/src/mat/impls/aij/seq/seqcusparse/
>>>> aijcusparse.cu
>>>> [0]PETSC ERROR: #3 MatMult_SeqAIJCUSPARSE() line 1347 in
>>>> aijcusparse.cu
>>>> [0]PETSC ERROR: #4 MatMult() line 2368 in
>>>> /home/eps/MyLocal/petsc-mark/src/mat/interface/matrix.c
>>>> [0]PETSC ERROR: #5 PCApplyBAorAB() line 662 in
>>>> /home/eps/MyLocal/petsc-mark/src/ksp/pc/interface/precon.c
>>>> [0]PETSC ERROR: #6 KSP_PCApplyBAorAB() line 309 in
>>>> /home/eps/MyLocal/petsc-mark/include/petsc/private/kspimpl.h
>>>> [0]PETSC ERROR: #7 KSPGMRESCycle() line 152 in
>>>> /home/eps/MyLocal/petsc-mark/src/ksp/ksp/impls/gmres/gmres.c
>>>> [0]PETSC ERROR: #8 KSPSolve_GMRES() line 237 in
>>>> [0]PETSC ERROR: #9 KSPSolve() line 764 in
>>>> /home/eps/MyLocal/petsc-mark/src/ksp/ksp/interface/itfunc.c
>>>> [0]PETSC ERROR: #10 SNESSolve_NEWTONLS() line 225 in
>>>> /home/eps/MyLocal/petsc-mark/src/snes/impls/ls/ls.c
>>>> [0]PETSC ERROR: #11 SNESSolve() line 4430 in
>>>> /home/eps/MyLocal/petsc-mark/src/snes/interface/snes.c
>>>> [0]PETSC ERROR: #12 main() line 161 in
>>>> [0]PETSC ERROR: -vec_type cuda
>>>> application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0
>>>> On Wed, Jul 3, 2019 at 10:27 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> My branch mark/gamg-fix-viennacl-rebased fixes this problem for me.
>>>>> Please give it a try.
>>>>> Thanks,
>>>>> Mark
>>>>> On Tue, Jul 2, 2019 at 10:41 PM Xiangdong via petsc-users <
>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> Hello everyone,
>>>>>> When I run the ex19 with cuda like this:
>>>>>>  mpiexec -np 4 ./ex19 -da_refine 5 -snes_view -snes_monitor
>>>>>> -ksp_monitor -mat_type aijcusparse -vec_type cuda  -log_view
>>>>>> it worked fine and produced correct results.
>>>>>> However, when I tried to run this example with nvprof:
>>>>>> nvprof --profile-child-processes mpiexec -np 4 ./extest -da_refine 5
>>>>>> -snes_view -snes_monitor -ksp_monitor -mat_type aijcusparse -vec_type cuda
>>>>>>  -log_view
>>>>>> I got errors like:
>>>>>> [3]PETSC ERROR: Error in external library
>>>>>> [3]PETSC ERROR: CUDA error 700
>>>>>> [3]PETSC ERROR: See
>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>> shooting.
>>>>>> [3]PETSC ERROR: Petsc Release Version 3.11.2, unknown
>>>>>> [3]PETSC ERROR: ./ex19 on a arch-opt named new by eps Tue Jul  2
>>>>>> 22:26:01 2019
>>>>>> [3]PETSC ERROR: Configure options PETSC_ARCH=arch-opt
>>>>>> --with-debugging=0 --with-mpi-dir=/home/eps/MyLocal/mpi/mpich
>>>>>> --with-cuda-dir=/home/eps/MyLocal/cuda
>>>>>> --with-hypre-dir=/home/eps/MyLocal/hypre-2.15.1/hypre-install
>>>>>> --download-hdf5=1
>>>>>> [3]PETSC ERROR: #1 VecSet_SeqCUDA() line 785 in
>>>>>> /home/eps/MyLocal/petsc/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
>>>>>> [3]PETSC ERROR: #2 VecSet() line 547 in
>>>>>> /home/eps/MyLocal/petsc/src/vec/vec/interface/rvector.c
>>>>>> [3]PETSC ERROR: #3 VecCreate_MPICUDA() line 178 in
>>>>>> /home/eps/MyLocal/petsc/src/vec/vec/impls/mpi/mpicuda/mpicuda.cu
>>>>>> [3]PETSC ERROR: #4 VecSetType() line 51 in
>>>>>> /home/eps/MyLocal/petsc/src/vec/vec/interface/vecreg.c
>>>>>> [3]PETSC ERROR: #5 VecCreate_CUDA() line 192 in
>>>>>> [3]PETSC ERROR: #6 VecSetType() line 51 in
>>>>>> [3]PETSC ERROR: #7 MatCreateVecs() line 8996 in
>>>>>> /home/eps/MyLocal/petsc/src/mat/interface/matrix.c
>>>>>> [3]PETSC ERROR: #8 MatFDColoringCreate() line 482 in
>>>>>> /home/eps/MyLocal/petsc/src/mat/matfd/fdmatrix.c
>>>>>> [3]PETSC ERROR: #9 SNESComputeJacobian_DMDA() line 175 in
>>>>>> /home/eps/MyLocal/petsc/src/snes/utils/dmdasnes.c
>>>>>> [3]PETSC ERROR: #10 SNESComputeJacobian() line 2718 in
>>>>>> /home/eps/MyLocal/petsc/src/snes/interface/snes.c
>>>>>> [3]PETSC ERROR: #11 SNESSolve_NEWTONLS() line 222 in
>>>>>> /home/eps/MyLocal/petsc/src/snes/impls/ls/ls.c
>>>>>> [3]PETSC ERROR: #12 SNESSolve() line 4560 in
>>>>>> [3]PETSC ERROR: #13 main() line 161 in
>>>>>> The full run log is attached.
>>>>>> I am using  NVIDIA-SMI 418.56       Driver Version: 418.56       CUDA
>>>>>> Version: 10.1.
>>>>>> I do not know why it is okay without nvprof but crashed with nvprof.
>>>>>> Any suggestion to fix this?
>>>>>> Thank you.
>>>>>> Best,
>>>>>> Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190706/2aa3fe96/attachment-0001.html>
