[petsc-users] snes/ex19 issue with nvprof
Mark Adams mfadams at lbl.gov
Sat Jul 6 16:52:12 CDT 2019
I'm using CUDA 10.1.105 and this looks like a logic bug and not a CUDA
problem.
I added two MatSetType calls that I thought were the right thing to do.
Your error is a type problem and test with DMPlex so the matrix creation
goes through a different code path.
You could try removing them and see if it works.
That is really all there is in this branch at this point other than some
ViennaCL stuff.
I would verify that a fresh pull from master works. I would also
reconfigure. I have just pulled from master and pushed so you can do a
fresh pull.
On Sat, Jul 6, 2019 at 4:07 PM Xiangdong <epscodes at gmail.com> wrote:
> Hi Mark,
> Yes, I am using your branch (mark/gamg-fix-viennacl-rebased) with Petsc
> Development GIT revision: v3.11.3-1064-g8b74309384. I compiled PETSc with
> CUDA 10.1.
> Which version of CUDA are you using?
> Thanks.
> Xiangdong
> On Sat, Jul 6, 2019 at 1:43 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I am not able to reproduce this error. THis is what I get. Are you
>> pulling from mark/gamg-fix-viennacl-rebased ?
>> 13:38  /gpfs/alpine/scratch/adams/geo127$ jsrun -n 1 -c 4 -a 4 -g 1
>> ./ex19 -da_refine 5 -snes_view -snes_monitor -ksp_monitor -mat_type
>> aijcusparse -vec_type cuda -log_view
>> lid velocity = 0.000106281, prandtl # = 1., grashof # = 1.
>>   0 SNES Function norm 1.036007954337e-02
>>     0 KSP Residual norm 9.144944502871e-02
>>     1 KSP Residual norm 2.593759906204e-02
>>     2 KSP Residual norm 1.669815200495e-02
>>     3 KSP Residual norm 1.510777951698e-02
>>     4 KSP Residual norm 1.458401237884e-02
>>     5 KSP Residual norm 1.418635322926e-02
>>     6 KSP Residual norm 1.377436725003e-02
>>     7 KSP Residual norm 1.332236907186e-02
>>     8 KSP Residual norm 1.288602527920e-02
>>     9 KSP Residual norm 1.240018288138e-02
>>    10 KSP Residual norm 1.186798872492e-02
>> On Fri, Jul 5, 2019 at 11:07 PM Xiangdong <epscodes at gmail.com> wrote:
>>> Hi Mark,
>>> After pulling your new commit, I got an error when running ex19 (even
>>> without nvprof). Same error with version 3.11.3. But ex19 run fine with old
>>> commit 64edb9194a9.
>>> Below is a run time log error file. By the way, which version of cuda
>>> does PETSc support?
>>> Thank you.
>>> Xiangdong
>>>     0 KSP Residual norm 9.158537890035e-02
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Invalid argument
>>> [0]PETSC ERROR: Object (seq) is not seqcuda or mpicuda
>>> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.11.3-1064-g8b74309384
>>>  GIT Date: 2019-07-03 10:24:59 -0400
>>> [0]PETSC ERROR: ./extest on a arch-debug2 named new by eps Fri Jul  5
>>> 22:57:02 2019
>>> [0]PETSC ERROR: Configure options PETSC_ARCH=arch-debug2
>>> --with-debugging=1 --with-mpi-dir=/home/eps/MyLocal/mpi/mpich
>>> --with-blaslapack-dir=/home/eps/MyLocal/intel/mkl --with-cuda=1
>>> [0]PETSC ERROR: #1 VecCUDAGetArrayRead() line 1304 in
>>> /home/eps/MyLocal/petsc-mark/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
>>> [0]PETSC ERROR: #2 MatMultAdd_SeqAIJCUSPARSE() line 1415 in
>>> /home/eps/MyLocal/petsc-mark/src/mat/impls/aij/seq/seqcusparse/
>>> aijcusparse.cu
>>> [0]PETSC ERROR: #3 MatMult_SeqAIJCUSPARSE() line 1347 in
>>> aijcusparse.cu
>>> [0]PETSC ERROR: #4 MatMult() line 2368 in
>>> /home/eps/MyLocal/petsc-mark/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: #5 PCApplyBAorAB() line 662 in
>>> /home/eps/MyLocal/petsc-mark/src/ksp/pc/interface/precon.c
>>> [0]PETSC ERROR: #6 KSP_PCApplyBAorAB() line 309 in
>>> /home/eps/MyLocal/petsc-mark/include/petsc/private/kspimpl.h
>>> [0]PETSC ERROR: #7 KSPGMRESCycle() line 152 in
>>> /home/eps/MyLocal/petsc-mark/src/ksp/ksp/impls/gmres/gmres.c
>>> [0]PETSC ERROR: #8 KSPSolve_GMRES() line 237 in
>>> [0]PETSC ERROR: #9 KSPSolve() line 764 in
>>> /home/eps/MyLocal/petsc-mark/src/ksp/ksp/interface/itfunc.c
>>> [0]PETSC ERROR: #10 SNESSolve_NEWTONLS() line 225 in
>>> /home/eps/MyLocal/petsc-mark/src/snes/impls/ls/ls.c
>>> [0]PETSC ERROR: #11 SNESSolve() line 4430 in
>>> /home/eps/MyLocal/petsc-mark/src/snes/interface/snes.c
>>> [0]PETSC ERROR: #12 main() line 161 in
>>> /home/eps/MyCodes/petsctest/extest.c
>>> [0]PETSC ERROR: PETSc Option Table entries:
>>> [0]PETSC ERROR: -da_refine 5
>>> [0]PETSC ERROR: -ksp_monitor
>>> [0]PETSC ERROR: -mat_type aijcusparse
>>> [0]PETSC ERROR: -snes_monitor
>>> [0]PETSC ERROR: -snes_view
>>> [0]PETSC ERROR: -vec_type cuda
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>> error message to petsc-maint at mcs.anl.gov----------
>>> application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0
>>> On Wed, Jul 3, 2019 at 10:27 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> My branch mark/gamg-fix-viennacl-rebased fixes this problem for me.
>>>> Please give it a try.
>>>> Thanks,
>>>> Mark
>>>> On Tue, Jul 2, 2019 at 10:41 PM Xiangdong via petsc-users <
>>>> petsc-users at mcs.anl.gov> wrote:
>>>>> Hello everyone,
>>>>> When I run the ex19 with cuda like this:
>>>>>  mpiexec -np 4 ./ex19 -da_refine 5 -snes_view -snes_monitor
>>>>> -ksp_monitor -mat_type aijcusparse -vec_type cuda  -log_view
>>>>> it worked fine and produced correct results.
>>>>> However, when I tried to run this example with nvprof:
>>>>> nvprof --profile-child-processes mpiexec -np 4 ./extest -da_refine 5
>>>>> -snes_view -snes_monitor -ksp_monitor -mat_type aijcusparse -vec_type cuda
>>>>>  -log_view
>>>>> I got errors like:
>>>>> [3]PETSC ERROR: Error in external library
>>>>> [3]PETSC ERROR: CUDA error 700
>>>>> [3]PETSC ERROR: See
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>> shooting.
>>>>> [3]PETSC ERROR: Petsc Release Version 3.11.2, unknown
>>>>> [3]PETSC ERROR: ./ex19 on a arch-opt named new by eps Tue Jul  2
>>>>> 22:26:01 2019
>>>>> [3]PETSC ERROR: Configure options PETSC_ARCH=arch-opt
>>>>> --with-debugging=0 --with-mpi-dir=/home/eps/MyLocal/mpi/mpich
>>>>> --with-cuda-dir=/home/eps/MyLocal/cuda
>>>>> --with-hypre-dir=/home/eps/MyLocal/hypre-2.15.1/hypre-install
>>>>> --download-hdf5=1
>>>>> [3]PETSC ERROR: #1 VecSet_SeqCUDA() line 785 in
>>>>> /home/eps/MyLocal/petsc/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
>>>>> [3]PETSC ERROR: #2 VecSet() line 547 in
>>>>> /home/eps/MyLocal/petsc/src/vec/vec/interface/rvector.c
>>>>> [3]PETSC ERROR: #3 VecCreate_MPICUDA() line 178 in
>>>>> /home/eps/MyLocal/petsc/src/vec/vec/impls/mpi/mpicuda/mpicuda.cu
>>>>> [3]PETSC ERROR: #4 VecSetType() line 51 in
>>>>> /home/eps/MyLocal/petsc/src/vec/vec/interface/vecreg.c
>>>>> [3]PETSC ERROR: #5 VecCreate_CUDA() line 192 in
>>>>> [3]PETSC ERROR: #6 VecSetType() line 51 in
>>>>> [3]PETSC ERROR: #7 MatCreateVecs() line 8996 in
>>>>> /home/eps/MyLocal/petsc/src/mat/interface/matrix.c
>>>>> [3]PETSC ERROR: #8 MatFDColoringCreate() line 482 in
>>>>> /home/eps/MyLocal/petsc/src/mat/matfd/fdmatrix.c
>>>>> [3]PETSC ERROR: #9 SNESComputeJacobian_DMDA() line 175 in
>>>>> /home/eps/MyLocal/petsc/src/snes/utils/dmdasnes.c
>>>>> [3]PETSC ERROR: #10 SNESComputeJacobian() line 2718 in
>>>>> /home/eps/MyLocal/petsc/src/snes/interface/snes.c
>>>>> [3]PETSC ERROR: #11 SNESSolve_NEWTONLS() line 222 in
>>>>> /home/eps/MyLocal/petsc/src/snes/impls/ls/ls.c
>>>>> [3]PETSC ERROR: #12 SNESSolve() line 4560 in
>>>>> [3]PETSC ERROR: #13 main() line 161 in
>>>>> The full run log is attached.
>>>>> I am using  NVIDIA-SMI 418.56       Driver Version: 418.56       CUDA
>>>>> Version: 10.1.
>>>>> I do not know why it is okay without nvprof but crashed with nvprof.
>>>>> Any suggestion to fix this?
>>>>> Thank you.
>>>>> Best,
>>>>> Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190706/c5de3bd2/attachment.html>
