[petsc-users] snes/ex19 issue with nvprof
    Xiangdong
    epscodes at gmail.com
    Fri Jul  5 22:07:20 CDT 2019
Hi Mark,
After pulling your new commit, I got an error when running ex19 (even
without nvprof). Same error with version 3.11.3. But ex19 run fine with old
commit 64edb9194a9.
Below is a run time log error file. By the way, which version of cuda does
PETSc support?
Thank you.
Xiangdong
lid velocity = 0.000106281, prandtl # = 1., grashof # = 1.
  0 SNES Function norm 1.036007954337e-02
    0 KSP Residual norm 9.158537890035e-02
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Object (seq) is not seqcuda or mpicuda
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.11.3-1064-g8b74309384
 GIT Date: 2019-07-03 10:24:59 -0400
[0]PETSC ERROR: ./extest on a arch-debug2 named new by eps Fri Jul  5
22:57:02 2019
[0]PETSC ERROR: Configure options PETSC_ARCH=arch-debug2 --with-debugging=1
--with-mpi-dir=/home/eps/MyLocal/mpi/mpich
--with-blaslapack-dir=/home/eps/MyLocal/intel/mkl --with-cuda=1
[0]PETSC ERROR: #1 VecCUDAGetArrayRead() line 1304 in
/home/eps/MyLocal/petsc-mark/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
[0]PETSC ERROR: #2 MatMultAdd_SeqAIJCUSPARSE() line 1415 in
/home/eps/MyLocal/petsc-mark/src/mat/impls/aij/seq/seqcusparse/
aijcusparse.cu
[0]PETSC ERROR: #3 MatMult_SeqAIJCUSPARSE() line 1347 in
aijcusparse.cu
[0]PETSC ERROR: #4 MatMult() line 2368 in
/home/eps/MyLocal/petsc-mark/src/mat/interface/matrix.c
[0]PETSC ERROR: #5 PCApplyBAorAB() line 662 in
/home/eps/MyLocal/petsc-mark/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #6 KSP_PCApplyBAorAB() line 309 in
/home/eps/MyLocal/petsc-mark/include/petsc/private/kspimpl.h
[0]PETSC ERROR: #7 KSPGMRESCycle() line 152 in
/home/eps/MyLocal/petsc-mark/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: #8 KSPSolve_GMRES() line 237 in
[0]PETSC ERROR: #9 KSPSolve() line 764 in
/home/eps/MyLocal/petsc-mark/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #10 SNESSolve_NEWTONLS() line 225 in
/home/eps/MyLocal/petsc-mark/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #11 SNESSolve() line 4430 in
/home/eps/MyLocal/petsc-mark/src/snes/interface/snes.c
[0]PETSC ERROR: #12 main() line 161 in /home/eps/MyCodes/petsctest/extest.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -da_refine 5
[0]PETSC ERROR: -ksp_monitor
[0]PETSC ERROR: -mat_type aijcusparse
[0]PETSC ERROR: -snes_monitor
[0]PETSC ERROR: -snes_view
[0]PETSC ERROR: -vec_type cuda
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0
On Wed, Jul 3, 2019 at 10:27 AM Mark Adams <mfadams at lbl.gov> wrote:
> My branch mark/gamg-fix-viennacl-rebased fixes this problem for me. Please
> give it a try.
> Thanks,
> Mark
> On Tue, Jul 2, 2019 at 10:41 PM Xiangdong via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hello everyone,
>> When I run the ex19 with cuda like this:
>>  mpiexec -np 4 ./ex19 -da_refine 5 -snes_view -snes_monitor -ksp_monitor
>> -mat_type aijcusparse -vec_type cuda  -log_view
>> it worked fine and produced correct results.
>> However, when I tried to run this example with nvprof:
>> nvprof --profile-child-processes mpiexec -np 4 ./extest -da_refine 5
>> -snes_view -snes_monitor -ksp_monitor -mat_type aijcusparse -vec_type cuda
>>  -log_view
>> I got errors like:
>> [3]PETSC ERROR: Error in external library
>> [3]PETSC ERROR: CUDA error 700
>> [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> [3]PETSC ERROR: Petsc Release Version 3.11.2, unknown
>> [3]PETSC ERROR: ./ex19 on a arch-opt named new by eps Tue Jul  2 22:26:01
>> 2019
>> [3]PETSC ERROR: Configure options PETSC_ARCH=arch-opt --with-debugging=0
>> --with-cuda-dir=/home/eps/MyLocal/cuda
>> --with-hypre-dir=/home/eps/MyLocal/hypre-2.15.1/hypre-install
>> --download-hdf5=1
>> [3]PETSC ERROR: #1 VecSet_SeqCUDA() line 785 in
>> /home/eps/MyLocal/petsc/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
>> [3]PETSC ERROR: #2 VecSet() line 547 in
>> /home/eps/MyLocal/petsc/src/vec/vec/interface/rvector.c
>> [3]PETSC ERROR: #3 VecCreate_MPICUDA() line 178 in
>> /home/eps/MyLocal/petsc/src/vec/vec/impls/mpi/mpicuda/mpicuda.cu
>> [3]PETSC ERROR: #4 VecSetType() line 51 in
>> /home/eps/MyLocal/petsc/src/vec/vec/interface/vecreg.c
>> [3]PETSC ERROR: #5 VecCreate_CUDA() line 192 in
>> [3]PETSC ERROR: #6 VecSetType() line 51 in
>> [3]PETSC ERROR: #7 MatCreateVecs() line 8996 in
>> /home/eps/MyLocal/petsc/src/mat/interface/matrix.c
>> [3]PETSC ERROR: #8 MatFDColoringCreate() line 482 in
>> /home/eps/MyLocal/petsc/src/mat/matfd/fdmatrix.c
>> [3]PETSC ERROR: #9 SNESComputeJacobian_DMDA() line 175 in
>> /home/eps/MyLocal/petsc/src/snes/utils/dmdasnes.c
>> [3]PETSC ERROR: #10 SNESComputeJacobian() line 2718 in
>> /home/eps/MyLocal/petsc/src/snes/interface/snes.c
>> [3]PETSC ERROR: #11 SNESSolve_NEWTONLS() line 222 in
>> /home/eps/MyLocal/petsc/src/snes/impls/ls/ls.c
>> [3]PETSC ERROR: #12 SNESSolve() line 4560 in
>> [3]PETSC ERROR: #13 main() line 161 in
>> The full run log is attached.
>> I am using  NVIDIA-SMI 418.56       Driver Version: 418.56       CUDA
>> Version: 10.1.
>> I do not know why it is okay without nvprof but crashed with nvprof. Any
>> suggestion to fix this?
>> Thank you.
>> Best,
>> Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190705/31dabcfe/attachment.html>
