[petsc-users] snes/ex19 issue with nvprof
Mark Adams
mfadams at lbl.gov
Wed Jul 3 09:26:47 CDT 2019
My branch mark/gamg-fix-viennacl-rebased fixes this problem for me. Please
give it a try.
On Tue, Jul 2, 2019 at 10:41 PM Xiangdong via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello everyone,
> When I run the ex19 with cuda like this:
> mpiexec -np 4 ./ex19 -da_refine 5 -snes_view -snes_monitor -ksp_monitor
> -mat_type aijcusparse -vec_type cuda -log_view
> it worked fine and produced correct results.
> However, when I tried to run this example with nvprof:
> nvprof --profile-child-processes mpiexec -np 4 ./extest -da_refine 5
> -snes_view -snes_monitor -ksp_monitor -mat_type aijcusparse -vec_type cuda
> -log_view
> I got errors like:
> [3]PETSC ERROR: Error in external library
> [3]PETSC ERROR: CUDA error 700
> [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [3]PETSC ERROR: Petsc Release Version 3.11.2, unknown
> [3]PETSC ERROR: ./ex19 on a arch-opt named new by eps Tue Jul 2 22:26:01
> 2019
> [3]PETSC ERROR: Configure options PETSC_ARCH=arch-opt --with-debugging=0
> --with-mpi-dir=/home/eps/MyLocal/mpi/mpich
> --with-blaslapack-dir=/home/eps/MyLocal/intel/mkl
> --with-cuda-dir=/home/eps/MyLocal/cuda
> --with-hypre-dir=/home/eps/MyLocal/hypre-2.15.1/hypre-install
> --download-hdf5=1
> [3]PETSC ERROR: #1 VecSet_SeqCUDA() line 785 in
> /home/eps/MyLocal/petsc/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
> [3]PETSC ERROR: #2 VecSet() line 547 in
> /home/eps/MyLocal/petsc/src/vec/vec/interface/rvector.c
> [3]PETSC ERROR: #3 VecCreate_MPICUDA() line 178 in
> /home/eps/MyLocal/petsc/src/vec/vec/impls/mpi/mpicuda/mpicuda.cu
> [3]PETSC ERROR: #4 VecSetType() line 51 in
> /home/eps/MyLocal/petsc/src/vec/vec/interface/vecreg.c
> [3]PETSC ERROR: #5 VecCreate_CUDA() line 192 in
> [3]PETSC ERROR: #6 VecSetType() line 51 in
> [3]PETSC ERROR: #7 MatCreateVecs() line 8996 in
> /home/eps/MyLocal/petsc/src/mat/interface/matrix.c
> [3]PETSC ERROR: #8 MatFDColoringCreate() line 482 in
> /home/eps/MyLocal/petsc/src/mat/matfd/fdmatrix.c
> [3]PETSC ERROR: #9 SNESComputeJacobian_DMDA() line 175 in
> /home/eps/MyLocal/petsc/src/snes/utils/dmdasnes.c
> [3]PETSC ERROR: #10 SNESComputeJacobian() line 2718 in
> /home/eps/MyLocal/petsc/src/snes/interface/snes.c
> [3]PETSC ERROR: #11 SNESSolve_NEWTONLS() line 222 in
> /home/eps/MyLocal/petsc/src/snes/impls/ls/ls.c
> [3]PETSC ERROR: #12 SNESSolve() line 4560 in
> [3]PETSC ERROR: #13 main() line 161 in /home/eps/MyCodes/petsctest/extest.c
> The full run log is attached.
> I am using NVIDIA-SMI 418.56 Driver Version: 418.56 CUDA
> Version: 10.1.
> I do not know why it is okay without nvprof but crashed with nvprof. Any
> suggestion to fix this?
> Thank you.
> Best,
> Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190703/785dc001/attachment-0001.html>
