[petsc-users] Preconditioning systems of equations with complex numbers
Matthew Knepley
knepley at gmail.com
Thu Jan 31 14:46:47 CST 2019
On Thu, Jan 31, 2019 at 3:20 PM Justin Chang via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi all,
> I'm working with some folks to extract a linear system of equations from
> an external software package that solves power flow equations in complex
> form. Since that external package uses serial direct solvers like KLU from
> suitesparse, I want a proof-of-concept where the same matrix can be solved
> in PETSc using its parallel solvers.
> I got mumps to achieve a very minor speedup across two MPI processes on a
> single node (went from solving a 300k dog system in 1.8 seconds to 1.5
> seconds). However I want to use iterative solvers and preconditioners but I
> have never worked with complex numbers so I am not sure what the "best"
> options are given PETSc's capabilities.
> So far I tried GMRES/BJACOBI and it craps out (unsurprisingly). I believe
> I also tried BICG with BJACOBI and while it did converge it converged
> slowly. Does anyone have recommendations on how one would go about
> preconditioning PETSc matrices with complex numbers? I was originally
> thinking about converting it to cartesian form: Declaring all voltages =
> sqrt(real^2+imaginary^2) and all angles to be something like a conditional
> arctan(imaginary/real) because all the papers I've seen in literature that
> claim to successfully precondition power flow equations operate in this
> form.
1) We really need to see the (simplified) equations
2) All complex equations can be converted to a system of real equations
twice as large, but this is not necessarily the best way to go
Matt
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190131/f50b2a73/attachment.html>
