[petsc-users] Vecs and Mats with non-contiguous parallel layout
Wed Jan 30 06:10:13 CST 2019
On Tue, Jan 29, 2019 at 7:58 PM Dave Lee via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> just wondering if its possible to manually specify the parallel
> decomposition of data within PETSc Vecs and Mats? And if so, will the
> FieldSplit preconditioning handle this also?
> I have an application (non-PETSc) data layout as:
> DATA[16][4][num_procs][3472]
> and if possible I would like to use FieldSplit preconditioning without
> re-arranging this layout.
Yes. You need to call
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetIS.html
in order to define the splits. Note that if you have nested splits, you
will have to also call it on the
nested PC, which stinks, but we have no other way of getting the
information.
Nested splits can also be handled by implementing the DM interface, but
that is a lot of work. It is,
however, the way we handle it internally because it makes things
much easier and more flexible.
     Matt
> Currently I have a nested FieldSplit preconditioning with 16 outer field
> splits, and a schur complement field split within each. however this throws
> up an indexing error as FieldSplit assumes that the parallel decomposition
> is contiguous (I think).
> [0]PETSC ERROR: #1 ISComplement() line 750 in
> /home/dlee0035/soft/petsc-3.9.3/src/vec/is/is/utils/iscoloring.c
> [0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 703 in
> /home/dlee0035/soft/petsc-3.9.3/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #3 PCSetUp() line 923 in
> /home/dlee0035/soft/petsc-3.9.3/src/ksp/pc/interface/precon.c
> Cheers, Dave.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190130/790ed4c8/attachment.html>
