[petsc-users] Vecs and Mats with non-contiguous parallel layout
Dave Lee davelee2804 at gmail.com
Tue Jan 29 18:13:45 CST 2019
just wondering if its possible to manually specify the parallel
decomposition of data within PETSc Vecs and Mats? And if so, will the
FieldSplit preconditioning handle this also?
I have an application (non-PETSc) data layout as:
DATA[16][4][num_procs][3472]
and if possible I would like to use FieldSplit preconditioning without
re-arranging this layout.
Currently I have a nested FieldSplit preconditioning with 16 outer field
splits, and a schur complement field split within each. however this throws
up an indexing error as FieldSplit assumes that the parallel decomposition
is contiguous (I think).
[0]PETSC ERROR: #1 ISComplement() line 750 in
/home/dlee0035/soft/petsc-3.9.3/src/vec/is/is/utils/iscoloring.c
[0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 703 in
/home/dlee0035/soft/petsc-3.9.3/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #3 PCSetUp() line 923 in
/home/dlee0035/soft/petsc-3.9.3/src/ksp/pc/interface/precon.c
Cheers, Dave.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190130/91ad292b/attachment.html>
