[petsc-users] KSP solve time and iterations
Valerio Barnabei valerio.barnabei at gmail.com
Fri Jan 18 09:47:50 CST 2019
Hello (again),
I'm trying to figure out how to change my program in order to use MATIS
type and PCBDD.
I managed to build my MATIS matrix successfully, but my code is now slower.
I think the main issue is that i'm using MatSetValues inside the element
loop, and passing as values the e-th local element matrix.
In a sort of pseudocode, where B is the shape functions matrix and D is a
“diffusion” matrix:
for e in localElements
for qp in quadraturePoints{
                        for n in localNodes {
                                   for m in localNodes {
                                               ke +=
weights[qp]*detJ[qp]*B[n]^T* D*B[m];
For n in localNodes{
For m in localNodes{
                fe[n] -= ke[n* localNodes +m]*ge[e][m];//ge is a simple
array that lets me easily take into account Dirichlet conditions, for my
simple case
for n in localNodes{
//            idx [n]=LM [e][n];
//LM is the DOF array (rows are Local elements, columns are local nodes,
values are global dofs, i.e. row/col indices for global assembly of K,
negative values are prescribed DOFs
MatSetValues(K, localNodes, (PetscInt*) &idx [0], localNodes, (PetscInt*)
&idx [0], (PetscScalar*) &ke[0], ADD_VALUES);
//same for VecSetValues
Just to clarify: the array I used to create the map is a unique array for
each process, without the negative values of the prescribed DOFs; the array
I’m using in matsetvalues is each time the portion of the array used for
the map relative to the current element. In addition to that: the code is
working, it gives the same result of an older version where I used MATAIJ,
but the portion of the element assembly loop is slower, and so is the
solving process (compared using PCNONE on both, obtained same iterations to
converge, same norm_2 of solution vector).
I guess using MatSetValues outside of the loop, using the same large array
I used to create the map for the matIS is supposed to be better, but I
cannot see a way to use it with this elemental assembly logic.
Stefano suggested to use MatSetValuesLocal: in that case what is supposed
to be idx? (I’m using global indices now).
If I use MatSetValuesLocal, can I stick with this logic of adding values
inside the element loop? Is there any other way you suggest to assign
values for this case?Any suggestion would be really appreciated.
I’m not sure I explained my issue properly, I can give any further
information needed.
Valerio
Il giorno ven 18 gen 2019 alle ore 15:55 Valerio Barnabei <
valerio.barnabei at gmail.com> ha scritto:
> The mail was still incomplete. Sorry, i will write it again.
> Apologies.
> Il giorno ven 18 gen 2019 alle ore 15:53 Valerio Barnabei <
>> Hello,
>> type and PCBDD.
>> slower. I think the main issue is that i'm using MatSetValues inside the
>> element loop, and passing as values the e-th local element matrix. In a
>> sort of pseudocode:
>> for e in localElements:{
>> for (int qp=0;qp<ngp_tot;qp++)
>>        for(int A=0;A<Nnodesloc;A++){
>>                 for(int B=0;B<Nnodesloc;B++){
>>                     //Bat dot temp (NB: ba_n0=bat_0n)
>>                     double
>> prod=temp[0][A][qp]*BaT[B][0][qp]+temp[1][A][qp]*BaT[B][1][qp];
>>                     //ke[A][B]+=weights[qp]*detJ[qp]*prod;
>>                     ke[A*Nnodesloc+B]+=weights[qp]*detJ[qp]*prod;
>> Actually i have lots of doubts:
>> -when using ISLocalToGlobalMappingCreate(), what's the blocksize?
>> Il giorno lun 14 gen 2019 alle ore 15:08 Valerio Barnabei <
>>> Thank you Stefano for your quick answer, I will try to change PC as you
>>> suggest, and I will read something about MATIS type. I will let you know if
>>> I still have doubts.
>>> Valerio
>>> Il giorno dom 13 gen 2019 alle ore 16:08 Stefano Zampini <
>>> stefano.zampini at gmail.com> ha scritto:
>>>> What problem are you trying to solve?
>>>> For standard elliptic problems (e.g. poisson or elasticity) you should
>>>> use a preconditioner that scales, for example PCGAMG or BoomerAMG from
>>>> HYPRE (PCHYPRE, if you configured PETSc with support for HYPRE via
>>>> --download-hypre)
>>>> Alternatively, since you are using FEM with local Assembly, you can use
>>>> PCBDDC, but this requires few extra calls
>>>> - call MatSetType(K,MATIS)
>>>> - provide an ISLocalToGlobalMapping of local to global degrees of
>>>> freedom before you set preallocation via MatSetLocalToGlobalMapping (if you
>>>> provide this call, then you can use MatSetValuesLocal for both AIJ
>>>> amd MATIS types)
>>>> Il giorno dom 13 gen 2019 alle ore 17:59 Valerio Barnabei via
>>>> petsc-users <petsc-users at mcs.anl.gov> ha scritto:
>>>>> Hello everybody,
>>>>> I have some doubts about the parallel solution of a simple FEM ksp
>>>>> problem. I searched in the mailing list but the information I found are not
>>>>> helping me.
>>>>> I need to control manually the parallel assemble of the main matrix,
>>>>> but I would like to use PetSC for the solution of the final linear system
>>>>> K*U=F.
>>>>> The algorithm I am using, loads an already decomposed FEM domain, and
>>>>> each process contributes to the global matrix assembly using its portion of
>>>>> domain decomposition (made in pre-processing). In the element loop, at each
>>>>> element I load the element submatrix in the global matrix via MatSetValue
>>>>> function. Then, out of the element loop, I write
>>>>> ...matrix preallocation
>>>>> ...calculate element local stiffness matrix (local in a FEM sense and
>>>>> local in a domain decomposition sense)
>>>>> MatSetValue (ADD)
>>>>> and then
>>>>> ierr=MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>> ierr=MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>> ierr=VecAssemblyBegin(F);CHKERRQ(ierr);
>>>>> ierr=VecAssemblyEnd(F);CHKERRQ(ierr);
>>>>> This part scales perfectly and is sufficiently fast.
>>>>> My K matrix is a sort of banded diagonal matrix: my preallocation is
>>>>> not perfect, but it works at this stage of my work.
>>>>> Finally I solve the system with the ksp logic:
>>>>> ierr=KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>> ierr=KSPSetOperators(ksp,K,K);CHKERRQ(ierr);
>>>>> ierr=KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>>>> ierr=PCSetType(pc,PCBJACOBI);CHKERRQ(ierr); //or PCNONE, or PCJACOBI,
>>>>> the behaviour is almost identical, the iteration number lowers but is still
>>>>> really high
>>>>> ierr=KSPSetTolerances(ksp,1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
>>>>> ierr=KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>> ierr=KSPSolve(ksp,F,sol);
>>>>> When I run the code I am noticing some strange behaviours. Indeed, the
>>>>> numerical solution appear right, and the code scales if I make a simple
>>>>> strong-scaling test. However, the ksp_log and log_view (see below, logs for
>>>>> a 160k quad linear element uniform 2dmesh) shows me a huge number of
>>>>> iterations, and the time spent in "solve" function is very high.
>>>>> Furthermore, the more I increase the problem size keeping a constant load
>>>>> per process (weak scaling) the more iterations seems to be needed for
>>>>> convergence. In general, when increasing the problem size (i.e. 16M
>>>>> elements) the convergence is not achieved before the maximum iteration
>>>>> number is achieved.
>>>>> Question 1: Am I doing it right? Or am I making some trouble with the
>>>>> MPI communication management? (i'm aware that my domain decomposition does
>>>>> not match the petsc matrix decomposition, I'm expecting it to cripple my
>>>>> algorithm a bit)
>>>>> Question 2: Why the solver takes so much time and so many iterations?
>>>>> the problem is really simple, and the solution appears correct when
>>>>> plotted. Am I ill conditioning the system?
>>>>> Thanks in advance for your help. I can add any further information if
>>>>> needed.
>>>>> Valerio
>>>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190118/f0837f4c/attachment-0001.html>
