[petsc-users] KSP solve time and iterations
Valerio Barnabei valerio.barnabei at gmail.com
Fri Jan 18 08:55:22 CST 2019
The mail was still incomplete. Sorry, i will write it again.
Apologies.
Il giorno ven 18 gen 2019 alle ore 15:53 Valerio Barnabei <
valerio.barnabei at gmail.com> ha scritto:
> Hello,
> I'm trying to figure out how to change my program in order to use MATIS
> type and PCBDD.
> I managed to build my MATIS matrix successfully, but my code is now
> slower. I think the main issue is that i'm using MatSetValues inside the
> element loop, and passing as values the e-th local element matrix. In a
> sort of pseudocode:
> for e in localElements:{
> for (int qp=0;qp<ngp_tot;qp++)
>        for(int A=0;A<Nnodesloc;A++){
>                 for(int B=0;B<Nnodesloc;B++){
>                     //Bat dot temp (NB: ba_n0=bat_0n)
>                     double
> prod=temp[0][A][qp]*BaT[B][0][qp]+temp[1][A][qp]*BaT[B][1][qp];
>                     //ke[A][B]+=weights[qp]*detJ[qp]*prod;
>                     ke[A*Nnodesloc+B]+=weights[qp]*detJ[qp]*prod;
> Actually i have lots of doubts:
> -when using ISLocalToGlobalMappingCreate(), what's the blocksize?
> Il giorno lun 14 gen 2019 alle ore 15:08 Valerio Barnabei <
>> Thank you Stefano for your quick answer, I will try to change PC as you
>> suggest, and I will read something about MATIS type. I will let you know if
>> I still have doubts.
>> Valerio
>> Il giorno dom 13 gen 2019 alle ore 16:08 Stefano Zampini <
>> stefano.zampini at gmail.com> ha scritto:
>>> What problem are you trying to solve?
>>> For standard elliptic problems (e.g. poisson or elasticity) you should
>>> use a preconditioner that scales, for example PCGAMG or BoomerAMG from
>>> HYPRE (PCHYPRE, if you configured PETSc with support for HYPRE via
>>> --download-hypre)
>>> Alternatively, since you are using FEM with local Assembly, you can use
>>> PCBDDC, but this requires few extra calls
>>> - call MatSetType(K,MATIS)
>>> - provide an ISLocalToGlobalMapping of local to global degrees of
>>> freedom before you set preallocation via MatSetLocalToGlobalMapping (if you
>>> provide this call, then you can use MatSetValuesLocal for both AIJ
>>> amd MATIS types)
>>> Il giorno dom 13 gen 2019 alle ore 17:59 Valerio Barnabei via
>>> petsc-users <petsc-users at mcs.anl.gov> ha scritto:
>>>> Hello everybody,
>>>> I have some doubts about the parallel solution of a simple FEM ksp
>>>> problem. I searched in the mailing list but the information I found are not
>>>> helping me.
>>>> I need to control manually the parallel assemble of the main matrix,
>>>> but I would like to use PetSC for the solution of the final linear system
>>>> K*U=F.
>>>> The algorithm I am using, loads an already decomposed FEM domain, and
>>>> each process contributes to the global matrix assembly using its portion of
>>>> domain decomposition (made in pre-processing). In the element loop, at each
>>>> element I load the element submatrix in the global matrix via MatSetValue
>>>> function. Then, out of the element loop, I write
>>>> ...matrix preallocation
>>>> ...calculate element local stiffness matrix (local in a FEM sense and
>>>> local in a domain decomposition sense)
>>>> MatSetValue (ADD)
>>>> and then
>>>> ierr=MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>> ierr=MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>> ierr=VecAssemblyBegin(F);CHKERRQ(ierr);
>>>> ierr=VecAssemblyEnd(F);CHKERRQ(ierr);
>>>> This part scales perfectly and is sufficiently fast.
>>>> My K matrix is a sort of banded diagonal matrix: my preallocation is
>>>> not perfect, but it works at this stage of my work.
>>>> Finally I solve the system with the ksp logic:
>>>> ierr=KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>> ierr=KSPSetOperators(ksp,K,K);CHKERRQ(ierr);
>>>> ierr=KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>>> ierr=PCSetType(pc,PCBJACOBI);CHKERRQ(ierr); //or PCNONE, or PCJACOBI,
>>>> the behaviour is almost identical, the iteration number lowers but is still
>>>> really high
>>>> ierr=KSPSetTolerances(ksp,1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
>>>> ierr=KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>> ierr=KSPSolve(ksp,F,sol);
>>>> When I run the code I am noticing some strange behaviours. Indeed, the
>>>> numerical solution appear right, and the code scales if I make a simple
>>>> strong-scaling test. However, the ksp_log and log_view (see below, logs for
>>>> a 160k quad linear element uniform 2dmesh) shows me a huge number of
>>>> iterations, and the time spent in "solve" function is very high.
>>>> Furthermore, the more I increase the problem size keeping a constant load
>>>> per process (weak scaling) the more iterations seems to be needed for
>>>> convergence. In general, when increasing the problem size (i.e. 16M
>>>> elements) the convergence is not achieved before the maximum iteration
>>>> number is achieved.
>>>> Question 1: Am I doing it right? Or am I making some trouble with the
>>>> MPI communication management? (i'm aware that my domain decomposition does
>>>> not match the petsc matrix decomposition, I'm expecting it to cripple my
>>>> algorithm a bit)
>>>> Question 2: Why the solver takes so much time and so many iterations?
>>>> the problem is really simple, and the solution appears correct when
>>>> plotted. Am I ill conditioning the system?
>>>> Thanks in advance for your help. I can add any further information if
>>>> needed.
>>>> Valerio
>>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190118/e50cb3ed/attachment.html>
