[petsc-users] MPI Iterative solver crash on HPC
Thu Jan 17 11:37:54 CST 2019
On Thu, Jan 17, 2019 at 11:43 AM Sal Am <tempohoper at gmail.com> wrote:
> I did two runs, one with the SuperLU_dist and one with bcgs using jacobi,
> attached are the results of one of the reports from valgrind on one random
> processor (out of the 128 files).
> DS = direct solver
> IS = iterative  solver
> There is an awful lot of errors.
> how I initiated the two runs:
> mpiexec valgrind --tool=memcheck -q --num-callers=20
> --log-file=valgrind.log-IS.%p ./solveCSys -malloc off -ksp_type bcgs
> -pc_type jacobi -mattransposematmult_via scalable -build_twosided allreduce
> -ksp_monitor -log_view
> --log-file=valgrind.log-DS.%p ./solveCSys -malloc off -ksp_type gmres
> -pc_type lu -pc_factor_mat_solver_type superlu_dist -ksp_max_it 1
> -ksp_monitor_true_residual -log_view -ksp_error_if_not_converged
OpenMPI is not my favorite. You need to use a suppressions file to get rid
of all of that noise. Here is one:
https://github.com/geodynamics/pylith/blob/master/share/valgrind-openmpi.supp
    Matt
> Thank you
> On Thu, Jan 17, 2019 at 4:24 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jan 17, 2019 at 9:18 AM Sal Am <tempohoper at gmail.com> wrote:
>>> 1) Running out of memory
>>>> 2) You passed an invalid array
>>> I have select=4:ncpus=32:mpiprocs=32:mem=300GB in the job script, i.e.
>>> using 300GB/node, a total of 1200GB memory, using 4 nodes and 32 processors
>>> per node (128 processors in total).
>>> I am not sure what would constitute an invalid array or how I can check
>>> that. I am using the same procedure as when dealing with the smaller
>>> matrix. i.e. Generate matrix A and vector b using FEM software then convert
>>> the matrix and vector using a python script ready for petsc. read in petsc
>>> and calculate.
>>> Are you running with 64-bit ints here?
>>> Yes I have it configured petsc with  --with-64-bit-indices and debugging
>>> mode, which this was run on.
>> It sounds like you have enough memory, but the fact that is runs for
>> smaller problems makes me suspicious. It
>> could still be a memory overwrite. Can you either
>> a) Run under valgrind
>> or
>> b) Run under the debugger and get a stack trace
>>    Thanks,
>>     Matt
>>> On Thu, Jan 17, 2019 at 1:59 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Jan 17, 2019 at 8:16 AM Sal Am <tempohoper at gmail.com> wrote:
>>>>> SuperLU_dist supports 64-bit ints. Are you not running in parallel?
>>>>> I will try that, although I think solving the real problem (later on
>>>>> if I can get this to work) with 30 million finite elements might be a
>>>>> problem for SuperLU_dist. so it is better to get an iterative solver to
>>>>> work with first.
>>>>> 1) Try using    -build_twosided allreduce    on this run
>>>>> How I ran it: mpiexec valgrind --tool=memcheck -q --num-callers=20
>>>>> --log-file=valgrind.log-osaii.%p ./solveCSys -malloc off -ksp_type bcgs
>>>>> -pc_type gamg -mattransposematmult_via scalable -build_twosided allreduce
>>>>> I have attached the full error output.
>>>> You are getting an SEGV on MatSetValues(), so its either
>>>>> 2) Is it possible to get something that fails here but we can run.
>>>>>> None of our tests show this problem.
>>>>> I am not how I can do that, but i have added my code which is quite
>>>>> short and should only read and solve the system, the problem arises at
>>>>> larger matrices for example current test case has 6 million finite elements
>>>>> (~2B non-zero numbers and 25M x 25M matrix).
>>>>    Matt
>>>>> On Wed, Jan 16, 2019 at 1:12 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Jan 16, 2019 at 3:52 AM Sal Am via petsc-users <
>>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>>> The memory requested is an insane number. You may need to use 64 bit
>>>>>>>> integers.
>>>>>>> Thanks Mark, I reconfigured it to use 64bit, however in the process
>>>>>>> it says I can no longer use MUMPS and SuperLU as they are not supported (I
>>>>>>> see on MUMPS webpage it supports 64int). However it does not exactly solve
>>>>>>> the problem.
>>>>>>> This time, it crashes at
>>>>>>>> [6]PETSC ERROR: #1 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line
>>>>>>>> 1989 in /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
>>>>>>>> ierr      = PetscMalloc1(bi[pn]+1,&bj);
>>>>>>>> which allocates local portion of B^T*A.
>>>>>>>> You may also try to increase number of cores to reduce local matrix
>>>>>>>> size.
>>>>>>> So I increased the number of cores to 16 on one node and ran it by :
>>>>>>> --log-file=valgrind.log-osa.%p ./solveCSys -malloc off -ksp_type bcgs
>>>>>>> -pc_type gamg -mattransposematmult_via scalable -ksp_monitor -log_view
>>>>>>> It crashed after reading in the matrix and before starting to solve.
>>>>>>> The error:
>>>>>>> [15]PETSC ERROR: [0]PETSC ERROR:
>>>>>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>>>>>> the batch system) has told this process to end
>>>>>>> [0]PETSC ERROR: [1]PETSC ERROR:
>>>>>>> [2]PETSC ERROR:
>>>>>>> [2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>>>>>> [3]PETSC ERROR:
>>>>>>> [4]PETSC ERROR:
>>>>>>> [4]PETSC ERROR: [5]PETSC ERROR: [6]PETSC ERROR:
>>>>>>> [8]PETSC ERROR:
>>>>>>> [12]PETSC ERROR:
>>>>>>> [12]PETSC ERROR: [14]PETSC ERROR:
>>>>>>> [14]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>>>>>> mpiexec noticed that process rank 10 with PID 0 on node r03n01
>>>>>>> exited on signal 9 (Killed).
>>>>>>> Now I was running this with valgrind as someone had previously
>>>>>>> suggested and the 16 files created all contain the same type of error:
>>>>>> Okay, its possible that there are bugs in the MPI implementation. So
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> ==25940== Invalid read of size 8
>>>>>>> ==25940==    at 0x5103326: PetscCheckPointer (checkptr.c:81)
>>>>>>> ==25940==    by 0x4F42058: PetscCommGetNewTag (tagm.c:77)
>>>>>>> ==25940==    by 0x4FC952D: PetscCommBuildTwoSidedFReq_Ibarrier
>>>>>>> (mpits.c:373)
>>>>>>> ==25940==    by 0x4FCB29B: PetscCommBuildTwoSidedFReq (mpits.c:572)
>>>>>>> ==25940==    by 0x52BBFF4: VecAssemblyBegin_MPI_BTS (pbvec.c:251)
>>>>>>> ==25940==    by 0x52D6B42: VecAssemblyBegin (vector.c:140)
>>>>>>> ==25940==    by 0x5328C97: VecLoad_Binary (vecio.c:141)
>>>>>>> ==25940==    by 0x5329051: VecLoad_Default (vecio.c:516)
>>>>>>> ==25940==    by 0x52E0BAB: VecLoad (vector.c:933)
>>>>>>> ==25940==    by 0x4013D5: main (solveCmplxLinearSys.cpp:31)
>>>>>>> ==25940==  Address 0x19f807fc is 12 bytes inside a block of size 16
>>>>>>> alloc'd
>>>>>>> ==25940==    at 0x4C2A603: memalign (vg_replace_malloc.c:899)
>>>>>>> ==25940==    by 0x4FD0B0E: PetscMallocAlign (mal.c:41)
>>>>>>> ==25940==    by 0x4FD23E7: PetscMallocA (mal.c:397)
>>>>>>> ==25940==    by 0x4FC948E: PetscCommBuildTwoSidedFReq_Ibarrier
>>>>>>> (mpits.c:371)
>>>>>>> ==25940==
>>>>>>> On Mon, Jan 14, 2019 at 7:29 PM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>>> Fande:
>>>>>>>>> According to this PR
>>>>>>>>> https://bitbucket.org/petsc/petsc/pull-requests/1061/a_selinger-feature-faster-scalable/diff
>>>>>>>>> Should we set the scalable algorithm as default?
>>>>>>>> Sure, we can. But I feel we need do more tests to compare scalable
>>>>>>>> and non-scalable algorithms.
>>>>>>>> On theory, for small to medium matrices, non-scalable matmatmult()
>>>>>>>> algorithm enables more efficient
>>>>>>>> data accessing. Andreas optimized scalable implementation. Our
>>>>>>>> non-scalable implementation might have room to be further optimized.
>>>>>>>> Hong
>>>>>>>>> On Fri, Jan 11, 2019 at 10:34 AM Zhang, Hong via petsc-users <
>>>>>>>>>> Add option '-mattransposematmult_via scalable'
>>>>>>>>>> Hong
>>>>>>>>>> On Fri, Jan 11, 2019 at 9:52 AM Zhang, Junchao via petsc-users <
>>>>>>>>>>> I saw the following error message in your first email.
>>>>>>>>>>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>>>>>>>>>>> [0]PETSC ERROR: too large an object or bleeding by not properly
>>>>>>>>>>> [0]PETSC ERROR: destroying unneeded objects.
>>>>>>>>>>> Probably the matrix is too large. You can try with more compute
>>>>>>>>>>> nodes, for example, use 8 nodes instead of 2, and see what happens.
>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>> On Fri, Jan 11, 2019 at 7:45 AM Sal Am via petsc-users <
>>>>>>>>>>>> Using a larger problem set with 2B non-zero elements and a
>>>>>>>>>>>> matrix of 25M x 25M I get the following error:
>>>>>>>>>>>> [4]PETSC ERROR:
>>>>>>>>>>>> [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>> [4]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>> [4]PETSC ERROR: or see
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>>>> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>>>>>>>>>>>> Apple Mac OS X to find memory corruption errors
>>>>>>>>>>>> [4]PETSC ERROR: likely location of problem given in stack below
>>>>>>>>>>>> [4]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>>> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are
>>>>>>>>>>>> not available,
>>>>>>>>>>>> [4]PETSC ERROR:       INSTEAD the line number of the start of
>>>>>>>>>>>> the function
>>>>>>>>>>>> [4]PETSC ERROR:       is given.
>>>>>>>>>>>> [4]PETSC ERROR: [4] MatCreateSeqAIJWithArrays line 4422
>>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/aij.c
>>>>>>>>>>>> [4]PETSC ERROR: [4] MatMatMultSymbolic_SeqAIJ_SeqAIJ line 747
>>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/matmatmult.c
>>>>>>>>>>>> [4]PETSC ERROR: [4]
>>>>>>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable line 1256
>>>>>>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult_MPIAIJ_MPIAIJ line 1156
>>>>>>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult line 9950
>>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/interface/matrix.c
>>>>>>>>>>>> [4]PETSC ERROR: [4] PCGAMGCoarsen_AGG line 871
>>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/agg.c
>>>>>>>>>>>> [4]PETSC ERROR: [4] PCSetUp_GAMG line 428
>>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>>>>> [4]PETSC ERROR: [4] PCSetUp line 894
>>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/interface/precon.c
>>>>>>>>>>>> [4]PETSC ERROR: [4] KSPSetUp line 304
>>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>> [4]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>> [4]PETSC ERROR: Signal received
>>>>>>>>>>>> [4]PETSC ERROR: See
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for
>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>> [4]PETSC ERROR: Petsc Release Version 3.10.2, unknown
>>>>>>>>>>>> [4]PETSC ERROR: ./solveCSys on a linux-cumulus-debug named
>>>>>>>>>>>> r02g03 by vef002 Fri Jan 11 09:13:23 2019
>>>>>>>>>>>> [4]PETSC ERROR: Configure options
>>>>>>>>>>>> PETSC_ARCH=linux-cumulus-debug
>>>>>>>>>>>> --with-cc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicc
>>>>>>>>>>>> --with-fc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpifort
>>>>>>>>>>>> --with-cxx=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicxx
>>>>>>>>>>>> --download-parmetis --download-metis --download-ptscotch
>>>>>>>>>>>> --download-superlu_dist --download-mumps --with-scalar-type=complex
>>>>>>>>>>>> --with-debugging=yes --download-scalapack --download-superlu
>>>>>>>>>>>> --download-fblaslapack=1 --download-cmake
>>>>>>>>>>>> [4]PETSC ERROR: #1 User provided function() line 0 in  unknown
>>>>>>>>>>>> file
>>>>>>>>>>>> MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
>>>>>>>>>>>> with errorcode 59.
>>>>>>>>>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
>>>>>>>>>>>> processes.
>>>>>>>>>>>> You may or may not see output from other processes, depending on
>>>>>>>>>>>> exactly when Open MPI kills them.
>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>> (or the batch system) has told this process to end
>>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>> [0]PETSC ERROR: or see
>>>>>>>>>>>> Using Valgrind on only one of the valgrind files the following
>>>>>>>>>>>> error was written:
>>>>>>>>>>>> ==9053== Invalid read of size 4
>>>>>>>>>>>> ==9053==    at 0x5B8067E: MatCreateSeqAIJWithArrays (aij.c:4445)
>>>>>>>>>>>> ==9053==    by 0x5BC2608: MatMatMultSymbolic_SeqAIJ_SeqAIJ
>>>>>>>>>>>> (matmatmult.c:790)
>>>>>>>>>>>> ==9053==    by 0x5D106F8:
>>>>>>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable (mpimatmatmult.c:1337)
>>>>>>>>>>>> ==9053==    by 0x5D0E84E: MatTransposeMatMult_MPIAIJ_MPIAIJ
>>>>>>>>>>>> (mpimatmatmult.c:1186)
>>>>>>>>>>>> ==9053==    by 0x5457C57: MatTransposeMatMult (matrix.c:9984)
>>>>>>>>>>>> ==9053==    by 0x64DD99D: PCGAMGCoarsen_AGG (agg.c:882)
>>>>>>>>>>>> ==9053==    by 0x64C7527: PCSetUp_GAMG (gamg.c:522)
>>>>>>>>>>>> ==9053==    by 0x6592AA0: PCSetUp (precon.c:932)
>>>>>>>>>>>> ==9053==    by 0x66B1267: KSPSetUp (itfunc.c:391)
>>>>>>>>>>>> ==9053==    by 0x4019A2: main (solveCmplxLinearSys.cpp:68)
>>>>>>>>>>>> ==9053==  Address 0x8386997f4 is not stack'd, malloc'd or
>>>>>>>>>>>> (recently) free'd
>>>>>>>>>>>> ==9053==
>>>>>>>>>>>> On Fri, Jan 11, 2019 at 8:41 AM Sal Am <tempohoper at gmail.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Thank you Dave,
>>>>>>>>>>>>> I reconfigured PETSc with valgrind and debugging mode, I ran
>>>>>>>>>>>>> the code again with the following options:
>>>>>>>>>>>>> mpiexec -n 8 valgrind --tool=memcheck -q --num-callers=20
>>>>>>>>>>>>> --log-file=valgrind.log.%p ./solveCSys -malloc off -ksp_type bcgs -pc_type
>>>>>>>>>>>>> gamg -log_view
>>>>>>>>>>>>> (as on the petsc website you linked)
>>>>>>>>>>>>> It finished solving using the iterative solver, but the
>>>>>>>>>>>>> resulting valgrind.log.%p files (all 8 corresponding to each processor) are
>>>>>>>>>>>>> all empty. And it took a whooping ~15hours, for what used to take
>>>>>>>>>>>>> ~10-20min. Maybe this is because of valgrind? I am not sure. Attached is
>>>>>>>>>>>>> the log_view.
>>>>>>>>>>>>> On Thu, Jan 10, 2019 at 8:59 AM Dave May <
>>>>>>>>>>>>> dave.mayhem23 at gmail.com> wrote:
>>>>>>>>>>>>>> On Thu, 10 Jan 2019 at 08:55, Sal Am via petsc-users <
>>>>>>>>>>>>>>> I am not sure what is exactly is wrong as the error changes
>>>>>>>>>>>>>>> slightly every time I run it (without changing the parameters).
>>>>>>>>>>>>>> This likely implies that you have a memory error in your code
>>>>>>>>>>>>>> (a memory leak would not cause this behaviour).
>>>>>>>>>>>>>> I strongly suggest you make sure your code is free of memory
>>>>>>>>>>>>>> errors.
>>>>>>>>>>>>>> You can do this using valgrind. See here
>>>>>>>>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>>>>>> for an explanation of how to use valgrind.
>>>>>>>>>>>>>>> I have attached the first two run's errors and my code.
>>>>>>>>>>>>>>> Is there a memory leak somewhere? I have tried running it
>>>>>>>>>>>>>>> with -malloc_dump, but not getting anything printed out, however, when run
>>>>>>>>>>>>>>> with -log_view I see that Viewer is created 4 times, but destroyed 3 times.
>>>>>>>>>>>>>>> The way I see it, I have destroyed it where I see I no longer have use for
>>>>>>>>>>>>>>> it so not sure if I am wrong. Could this be the reason why it keeps
>>>>>>>>>>>>>>> crashing? It crashes as soon as it reads the matrix, before entering the
>>>>>>>>>>>>>>> solving mode (I have a print statement before solving starts that never
>>>>>>>>>>>>>>> prints).
>>>>>>>>>>>>>>> how I run it in the job script on 2 node with 32 processors
>>>>>>>>>>>>>>> using the clusters OpenMPI.
>>>>>>>>>>>>>>> mpiexec ./solveCSys -ksp_type bcgs -pc_type gamg
>>>>>>>>>>>>>>> -ksp_converged_reason -ksp_monitor_true_residual -log_view
>>>>>>>>>>>>>>> -ksp_error_if_not_converged -ksp_monitor -malloc_log -ksp_view
>>>>>>>>>>>>>>> the matrix:
>>>>>>>>>>>>>>> 2 122 821 366 (non-zero elements)
>>>>>>>>>>>>>>> 25 947 279 x 25 947 279
>>>>>>>>>>>>>>> Thanks and all the best
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/4305a805/attachment-0001.html>
