[petsc-users] MPI Iterative solver crash on HPC
Sal Am tempohoper at gmail.com
Thu Jan 17 10:43:26 CST 2019
I did two runs, one with the SuperLU_dist and one with bcgs using jacobi,
attached are the results of one of the reports from valgrind on one random
processor (out of the 128 files).
DS = direct solver
IS = iterative  solver
There is an awful lot of errors.
how I initiated the two runs:
mpiexec valgrind --tool=memcheck -q --num-callers=20
--log-file=valgrind.log-IS.%p ./solveCSys -malloc off -ksp_type bcgs
-pc_type jacobi -mattransposematmult_via scalable -build_twosided allreduce
-ksp_monitor -log_view
--log-file=valgrind.log-DS.%p ./solveCSys -malloc off -ksp_type gmres
-pc_type lu -pc_factor_mat_solver_type superlu_dist -ksp_max_it 1
-ksp_monitor_true_residual -log_view -ksp_error_if_not_converged
Thank you
On Thu, Jan 17, 2019 at 4:24 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 17, 2019 at 9:18 AM Sal Am <tempohoper at gmail.com> wrote:
>> 1) Running out of memory
>>> 2) You passed an invalid array
>> I have select=4:ncpus=32:mpiprocs=32:mem=300GB in the job script, i.e.
>> using 300GB/node, a total of 1200GB memory, using 4 nodes and 32 processors
>> per node (128 processors in total).
>> I am not sure what would constitute an invalid array or how I can check
>> that. I am using the same procedure as when dealing with the smaller
>> matrix. i.e. Generate matrix A and vector b using FEM software then convert
>> the matrix and vector using a python script ready for petsc. read in petsc
>> and calculate.
>> Are you running with 64-bit ints here?
>> Yes I have it configured petsc with  --with-64-bit-indices and debugging
>> mode, which this was run on.
> It sounds like you have enough memory, but the fact that is runs for
> smaller problems makes me suspicious. It
> could still be a memory overwrite. Can you either
> a) Run under valgrind
> or
> b) Run under the debugger and get a stack trace
>    Thanks,
>     Matt
>> On Thu, Jan 17, 2019 at 1:59 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Thu, Jan 17, 2019 at 8:16 AM Sal Am <tempohoper at gmail.com> wrote:
>>>> SuperLU_dist supports 64-bit ints. Are you not running in parallel?
>>>> I will try that, although I think solving the real problem (later on if
>>>> I can get this to work) with 30 million finite elements might be a problem
>>>> for SuperLU_dist. so it is better to get an iterative solver to work with
>>>> first.
>>>> 1) Try using    -build_twosided allreduce    on this run
>>>> How I ran it: mpiexec valgrind --tool=memcheck -q --num-callers=20
>>>> --log-file=valgrind.log-osaii.%p ./solveCSys -malloc off -ksp_type bcgs
>>>> -pc_type gamg -mattransposematmult_via scalable -build_twosided allreduce
>>>> I have attached the full error output.
>>> You are getting an SEGV on MatSetValues(), so its either
>>>> 2) Is it possible to get something that fails here but we can run. None
>>>>> of our tests show this problem.
>>>> I am not how I can do that, but i have added my code which is quite
>>>> short and should only read and solve the system, the problem arises at
>>>> larger matrices for example current test case has 6 million finite elements
>>>> (~2B non-zero numbers and 25M x 25M matrix).
>>>    Matt
>>>> On Wed, Jan 16, 2019 at 1:12 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Jan 16, 2019 at 3:52 AM Sal Am via petsc-users <
>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> The memory requested is an insane number. You may need to use 64 bit
>>>>>>> integers.
>>>>>> Thanks Mark, I reconfigured it to use 64bit, however in the process
>>>>>> it says I can no longer use MUMPS and SuperLU as they are not supported (I
>>>>>> see on MUMPS webpage it supports 64int). However it does not exactly solve
>>>>>> the problem.
>>>>>> This time, it crashes at
>>>>>>> [6]PETSC ERROR: #1 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line
>>>>>>> 1989 in /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
>>>>>>> ierr      = PetscMalloc1(bi[pn]+1,&bj);
>>>>>>> which allocates local portion of B^T*A.
>>>>>>> You may also try to increase number of cores to reduce local matrix
>>>>>>> size.
>>>>>> So I increased the number of cores to 16 on one node and ran it by :
>>>>>> --log-file=valgrind.log-osa.%p ./solveCSys -malloc off -ksp_type bcgs
>>>>>> -pc_type gamg -mattransposematmult_via scalable -ksp_monitor -log_view
>>>>>> It crashed after reading in the matrix and before starting to solve.
>>>>>> The error:
>>>>>> [15]PETSC ERROR: [0]PETSC ERROR:
>>>>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>>>>> the batch system) has told this process to end
>>>>>> [0]PETSC ERROR: [1]PETSC ERROR:
>>>>>> [2]PETSC ERROR:
>>>>>> [2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>>>>> [3]PETSC ERROR:
>>>>>> [4]PETSC ERROR:
>>>>>> [4]PETSC ERROR: [5]PETSC ERROR: [6]PETSC ERROR:
>>>>>> [8]PETSC ERROR:
>>>>>> [12]PETSC ERROR:
>>>>>> [12]PETSC ERROR: [14]PETSC ERROR:
>>>>>> [14]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>>>>> mpiexec noticed that process rank 10 with PID 0 on node r03n01 exited
>>>>>> on signal 9 (Killed).
>>>>>> Now I was running this with valgrind as someone had previously
>>>>>> suggested and the 16 files created all contain the same type of error:
>>>>> Okay, its possible that there are bugs in the MPI implementation. So
>>>>> None of our tests show this problem.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> ==25940== Invalid read of size 8
>>>>>> ==25940==    at 0x5103326: PetscCheckPointer (checkptr.c:81)
>>>>>> ==25940==    by 0x4F42058: PetscCommGetNewTag (tagm.c:77)
>>>>>> ==25940==    by 0x4FC952D: PetscCommBuildTwoSidedFReq_Ibarrier
>>>>>> (mpits.c:373)
>>>>>> ==25940==    by 0x4FCB29B: PetscCommBuildTwoSidedFReq (mpits.c:572)
>>>>>> ==25940==    by 0x52BBFF4: VecAssemblyBegin_MPI_BTS (pbvec.c:251)
>>>>>> ==25940==    by 0x52D6B42: VecAssemblyBegin (vector.c:140)
>>>>>> ==25940==    by 0x5328C97: VecLoad_Binary (vecio.c:141)
>>>>>> ==25940==    by 0x5329051: VecLoad_Default (vecio.c:516)
>>>>>> ==25940==    by 0x52E0BAB: VecLoad (vector.c:933)
>>>>>> ==25940==    by 0x4013D5: main (solveCmplxLinearSys.cpp:31)
>>>>>> ==25940==  Address 0x19f807fc is 12 bytes inside a block of size 16
>>>>>> alloc'd
>>>>>> ==25940==    at 0x4C2A603: memalign (vg_replace_malloc.c:899)
>>>>>> ==25940==    by 0x4FD0B0E: PetscMallocAlign (mal.c:41)
>>>>>> ==25940==    by 0x4FD23E7: PetscMallocA (mal.c:397)
>>>>>> ==25940==    by 0x4FC948E: PetscCommBuildTwoSidedFReq_Ibarrier
>>>>>> (mpits.c:371)
>>>>>> ==25940==
>>>>>> On Mon, Jan 14, 2019 at 7:29 PM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>>> wrote:
>>>>>>> Fande:
>>>>>>>> According to this PR
>>>>>>>> https://bitbucket.org/petsc/petsc/pull-requests/1061/a_selinger-feature-faster-scalable/diff
>>>>>>>> Should we set the scalable algorithm as default?
>>>>>>> Sure, we can. But I feel we need do more tests to compare scalable
>>>>>>> and non-scalable algorithms.
>>>>>>> On theory, for small to medium matrices, non-scalable matmatmult()
>>>>>>> algorithm enables more efficient
>>>>>>> data accessing. Andreas optimized scalable implementation. Our
>>>>>>> non-scalable implementation might have room to be further optimized.
>>>>>>> Hong
>>>>>>>> On Fri, Jan 11, 2019 at 10:34 AM Zhang, Hong via petsc-users <
>>>>>>>>> Add option '-mattransposematmult_via scalable'
>>>>>>>>> Hong
>>>>>>>>> On Fri, Jan 11, 2019 at 9:52 AM Zhang, Junchao via petsc-users <
>>>>>>>>>> I saw the following error message in your first email.
>>>>>>>>>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>>>>>>>>>> [0]PETSC ERROR: too large an object or bleeding by not properly
>>>>>>>>>> [0]PETSC ERROR: destroying unneeded objects.
>>>>>>>>>> Probably the matrix is too large. You can try with more compute
>>>>>>>>>> nodes, for example, use 8 nodes instead of 2, and see what happens.
>>>>>>>>>> --Junchao Zhang
>>>>>>>>>> On Fri, Jan 11, 2019 at 7:45 AM Sal Am via petsc-users <
>>>>>>>>>>> Using a larger problem set with 2B non-zero elements and a
>>>>>>>>>>> matrix of 25M x 25M I get the following error:
>>>>>>>>>>> [4]PETSC ERROR:
>>>>>>>>>>> [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>> [4]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>> [4]PETSC ERROR: or see
>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>>> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>>>>>>>>>>> Apple Mac OS X to find memory corruption errors
>>>>>>>>>>> [4]PETSC ERROR: likely location of problem given in stack below
>>>>>>>>>>> [4]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are
>>>>>>>>>>> not available,
>>>>>>>>>>> [4]PETSC ERROR:       INSTEAD the line number of the start of
>>>>>>>>>>> the function
>>>>>>>>>>> [4]PETSC ERROR:       is given.
>>>>>>>>>>> [4]PETSC ERROR: [4] MatCreateSeqAIJWithArrays line 4422
>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/aij.c
>>>>>>>>>>> [4]PETSC ERROR: [4] MatMatMultSymbolic_SeqAIJ_SeqAIJ line 747
>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/matmatmult.c
>>>>>>>>>>> [4]PETSC ERROR: [4]
>>>>>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable line 1256
>>>>>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult_MPIAIJ_MPIAIJ line 1156
>>>>>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult line 9950
>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/interface/matrix.c
>>>>>>>>>>> [4]PETSC ERROR: [4] PCGAMGCoarsen_AGG line 871
>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/agg.c
>>>>>>>>>>> [4]PETSC ERROR: [4] PCSetUp_GAMG line 428
>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>>>> [4]PETSC ERROR: [4] PCSetUp line 894
>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/interface/precon.c
>>>>>>>>>>> [4]PETSC ERROR: [4] KSPSetUp line 304
>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>> [4]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>> [4]PETSC ERROR: Signal received
>>>>>>>>>>> [4]PETSC ERROR: See
>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>>>>>>> shooting.
>>>>>>>>>>> [4]PETSC ERROR: Petsc Release Version 3.10.2, unknown
>>>>>>>>>>> [4]PETSC ERROR: ./solveCSys on a linux-cumulus-debug named
>>>>>>>>>>> r02g03 by vef002 Fri Jan 11 09:13:23 2019
>>>>>>>>>>> [4]PETSC ERROR: Configure options PETSC_ARCH=linux-cumulus-debug
>>>>>>>>>>> --with-cc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicc
>>>>>>>>>>> --with-fc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpifort
>>>>>>>>>>> --with-cxx=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicxx
>>>>>>>>>>> --download-parmetis --download-metis --download-ptscotch
>>>>>>>>>>> --download-superlu_dist --download-mumps --with-scalar-type=complex
>>>>>>>>>>> --with-debugging=yes --download-scalapack --download-superlu
>>>>>>>>>>> --download-fblaslapack=1 --download-cmake
>>>>>>>>>>> [4]PETSC ERROR: #1 User provided function() line 0 in  unknown
>>>>>>>>>>> file
>>>>>>>>>>> MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
>>>>>>>>>>> with errorcode 59.
>>>>>>>>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
>>>>>>>>>>> processes.
>>>>>>>>>>> You may or may not see output from other processes, depending on
>>>>>>>>>>> exactly when Open MPI kills them.
>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>> (or the batch system) has told this process to end
>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>> [0]PETSC ERROR: or see
>>>>>>>>>>> Using Valgrind on only one of the valgrind files the following
>>>>>>>>>>> error was written:
>>>>>>>>>>> ==9053== Invalid read of size 4
>>>>>>>>>>> ==9053==    at 0x5B8067E: MatCreateSeqAIJWithArrays (aij.c:4445)
>>>>>>>>>>> ==9053==    by 0x5BC2608: MatMatMultSymbolic_SeqAIJ_SeqAIJ
>>>>>>>>>>> (matmatmult.c:790)
>>>>>>>>>>> ==9053==    by 0x5D106F8:
>>>>>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable (mpimatmatmult.c:1337)
>>>>>>>>>>> ==9053==    by 0x5D0E84E: MatTransposeMatMult_MPIAIJ_MPIAIJ
>>>>>>>>>>> (mpimatmatmult.c:1186)
>>>>>>>>>>> ==9053==    by 0x5457C57: MatTransposeMatMult (matrix.c:9984)
>>>>>>>>>>> ==9053==    by 0x64DD99D: PCGAMGCoarsen_AGG (agg.c:882)
>>>>>>>>>>> ==9053==    by 0x64C7527: PCSetUp_GAMG (gamg.c:522)
>>>>>>>>>>> ==9053==    by 0x6592AA0: PCSetUp (precon.c:932)
>>>>>>>>>>> ==9053==    by 0x66B1267: KSPSetUp (itfunc.c:391)
>>>>>>>>>>> ==9053==    by 0x4019A2: main (solveCmplxLinearSys.cpp:68)
>>>>>>>>>>> ==9053==  Address 0x8386997f4 is not stack'd, malloc'd or
>>>>>>>>>>> (recently) free'd
>>>>>>>>>>> ==9053==
>>>>>>>>>>> On Fri, Jan 11, 2019 at 8:41 AM Sal Am <tempohoper at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Thank you Dave,
>>>>>>>>>>>> I reconfigured PETSc with valgrind and debugging mode, I ran
>>>>>>>>>>>> the code again with the following options:
>>>>>>>>>>>> mpiexec -n 8 valgrind --tool=memcheck -q --num-callers=20
>>>>>>>>>>>> --log-file=valgrind.log.%p ./solveCSys -malloc off -ksp_type bcgs -pc_type
>>>>>>>>>>>> gamg -log_view
>>>>>>>>>>>> (as on the petsc website you linked)
>>>>>>>>>>>> It finished solving using the iterative solver, but the
>>>>>>>>>>>> resulting valgrind.log.%p files (all 8 corresponding to each processor) are
>>>>>>>>>>>> all empty. And it took a whooping ~15hours, for what used to take
>>>>>>>>>>>> ~10-20min. Maybe this is because of valgrind? I am not sure. Attached is
>>>>>>>>>>>> the log_view.
>>>>>>>>>>>> On Thu, Jan 10, 2019 at 8:59 AM Dave May <
>>>>>>>>>>>> dave.mayhem23 at gmail.com> wrote:
>>>>>>>>>>>>> On Thu, 10 Jan 2019 at 08:55, Sal Am via petsc-users <
>>>>>>>>>>>>>> I am not sure what is exactly is wrong as the error changes
>>>>>>>>>>>>>> slightly every time I run it (without changing the parameters).
>>>>>>>>>>>>> This likely implies that you have a memory error in your code
>>>>>>>>>>>>> (a memory leak would not cause this behaviour).
>>>>>>>>>>>>> I strongly suggest you make sure your code is free of memory
>>>>>>>>>>>>> errors.
>>>>>>>>>>>>> You can do this using valgrind. See here
>>>>>>>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>>>>> for an explanation of how to use valgrind.
>>>>>>>>>>>>>> I have attached the first two run's errors and my code.
>>>>>>>>>>>>>> Is there a memory leak somewhere? I have tried running it
>>>>>>>>>>>>>> with -malloc_dump, but not getting anything printed out, however, when run
>>>>>>>>>>>>>> with -log_view I see that Viewer is created 4 times, but destroyed 3 times.
>>>>>>>>>>>>>> The way I see it, I have destroyed it where I see I no longer have use for
>>>>>>>>>>>>>> it so not sure if I am wrong. Could this be the reason why it keeps
>>>>>>>>>>>>>> crashing? It crashes as soon as it reads the matrix, before entering the
>>>>>>>>>>>>>> solving mode (I have a print statement before solving starts that never
>>>>>>>>>>>>>> prints).
>>>>>>>>>>>>>> how I run it in the job script on 2 node with 32 processors
>>>>>>>>>>>>>> using the clusters OpenMPI.
>>>>>>>>>>>>>> mpiexec ./solveCSys -ksp_type bcgs -pc_type gamg
>>>>>>>>>>>>>> -ksp_converged_reason -ksp_monitor_true_residual -log_view
>>>>>>>>>>>>>> -ksp_error_if_not_converged -ksp_monitor -malloc_log -ksp_view
>>>>>>>>>>>>>> the matrix:
>>>>>>>>>>>>>> 2 122 821 366 (non-zero elements)
>>>>>>>>>>>>>> 25 947 279 x 25 947 279
>>>>>>>>>>>>>> Thanks and all the best
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/48c0c117/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/48c0c117/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/48c0c117/attachment-0003.obj>
