[petsc-users] MPI Iterative solver crash on HPC
Thu Jan 17 07:59:16 CST 2019
On Thu, Jan 17, 2019 at 8:16 AM Sal Am <tempohoper at gmail.com> wrote:
> SuperLU_dist supports 64-bit ints. Are you not running in parallel?
> I will try that, although I think solving the real problem (later on if I
> can get this to work) with 30 million finite elements might be a problem
> for SuperLU_dist. so it is better to get an iterative solver to work with
> first.
> 1) Try using    -build_twosided allreduce    on this run
> How I ran it: mpiexec valgrind --tool=memcheck -q --num-callers=20
> --log-file=valgrind.log-osaii.%p ./solveCSys -malloc off -ksp_type bcgs
> -pc_type gamg -mattransposematmult_via scalable -build_twosided allreduce
> -ksp_monitor -log_view
> I have attached the full error output.
You are getting an SEGV on MatSetValues(), so its either
1) Running out of memory
2) You passed an invalid array
> 2) Is it possible to get something that fails here but we can run. None of
>> our tests show this problem.
> I am not how I can do that, but i have added my code which is quite short
> and should only read and solve the system, the problem arises at larger
> matrices for example current test case has 6 million finite elements (~2B
> non-zero numbers and 25M x 25M matrix).
Are you running with 64-bit ints here?
   Matt
> On Wed, Jan 16, 2019 at 1:12 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Jan 16, 2019 at 3:52 AM Sal Am via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> The memory requested is an insane number. You may need to use 64 bit
>>>> integers.
>>> Thanks Mark, I reconfigured it to use 64bit, however in the process it
>>> says I can no longer use MUMPS and SuperLU as they are not supported (I see
>>> on MUMPS webpage it supports 64int). However it does not exactly solve the
>>> problem.
>>> This time, it crashes at
>>>> [6]PETSC ERROR: #1 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line
>>>> 1989 in /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
>>>> ierr      = PetscMalloc1(bi[pn]+1,&bj);
>>>> which allocates local portion of B^T*A.
>>>> You may also try to increase number of cores to reduce local matrix
>>>> size.
>>> So I increased the number of cores to 16 on one node and ran it by :
>>> --log-file=valgrind.log-osa.%p ./solveCSys -malloc off -ksp_type bcgs
>>> -pc_type gamg -mattransposematmult_via scalable -ksp_monitor -log_view
>>> It crashed after reading in the matrix and before starting to solve. The
>>> error:
>>> [15]PETSC ERROR: [0]PETSC ERROR:
>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>> batch system) has told this process to end
>>> [0]PETSC ERROR: [1]PETSC ERROR:
>>> [2]PETSC ERROR:
>>> [2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>> [3]PETSC ERROR:
>>> [4]PETSC ERROR:
>>> [4]PETSC ERROR: [5]PETSC ERROR: [6]PETSC ERROR:
>>> [8]PETSC ERROR:
>>> [12]PETSC ERROR:
>>> [12]PETSC ERROR: [14]PETSC ERROR:
>>> [14]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>> mpiexec noticed that process rank 10 with PID 0 on node r03n01 exited on
>>> signal 9 (Killed).
>>> Now I was running this with valgrind as someone had previously suggested
>>> and the 16 files created all contain the same type of error:
>> Okay, its possible that there are bugs in the MPI implementation. So
>> of our tests show this problem.
>>   Thanks,
>>      Matt
>>> ==25940== Invalid read of size 8
>>> ==25940==    at 0x5103326: PetscCheckPointer (checkptr.c:81)
>>> ==25940==    by 0x4F42058: PetscCommGetNewTag (tagm.c:77)
>>> ==25940==    by 0x4FC952D: PetscCommBuildTwoSidedFReq_Ibarrier
>>> (mpits.c:373)
>>> ==25940==    by 0x4FCB29B: PetscCommBuildTwoSidedFReq (mpits.c:572)
>>> ==25940==    by 0x52BBFF4: VecAssemblyBegin_MPI_BTS (pbvec.c:251)
>>> ==25940==    by 0x52D6B42: VecAssemblyBegin (vector.c:140)
>>> ==25940==    by 0x5328C97: VecLoad_Binary (vecio.c:141)
>>> ==25940==    by 0x5329051: VecLoad_Default (vecio.c:516)
>>> ==25940==    by 0x52E0BAB: VecLoad (vector.c:933)
>>> ==25940==    by 0x4013D5: main (solveCmplxLinearSys.cpp:31)
>>> ==25940==  Address 0x19f807fc is 12 bytes inside a block of size 16
>>> alloc'd
>>> ==25940==    at 0x4C2A603: memalign (vg_replace_malloc.c:899)
>>> ==25940==    by 0x4FD0B0E: PetscMallocAlign (mal.c:41)
>>> ==25940==    by 0x4FD23E7: PetscMallocA (mal.c:397)
>>> ==25940==    by 0x4FC948E: PetscCommBuildTwoSidedFReq_Ibarrier
>>> (mpits.c:371)
>>> ==25940==
>>> On Mon, Jan 14, 2019 at 7:29 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Fande:
>>>>> According to this PR
>>>>> https://bitbucket.org/petsc/petsc/pull-requests/1061/a_selinger-feature-faster-scalable/diff
>>>>> Should we set the scalable algorithm as default?
>>>> Sure, we can. But I feel we need do more tests to compare scalable and
>>>> non-scalable algorithms.
>>>> On theory, for small to medium matrices, non-scalable matmatmult()
>>>> algorithm enables more efficient
>>>> data accessing. Andreas optimized scalable implementation. Our
>>>> non-scalable implementation might have room to be further optimized.
>>>> Hong
>>>>> On Fri, Jan 11, 2019 at 10:34 AM Zhang, Hong via petsc-users <
>>>>>> Add option '-mattransposematmult_via scalable'
>>>>>> Hong
>>>>>> On Fri, Jan 11, 2019 at 9:52 AM Zhang, Junchao via petsc-users <
>>>>>>> I saw the following error message in your first email.
>>>>>>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>>>>>>> [0]PETSC ERROR: too large an object or bleeding by not properly
>>>>>>> [0]PETSC ERROR: destroying unneeded objects.
>>>>>>> Probably the matrix is too large. You can try with more compute
>>>>>>> nodes, for example, use 8 nodes instead of 2, and see what happens.
>>>>>>> --Junchao Zhang
>>>>>>> On Fri, Jan 11, 2019 at 7:45 AM Sal Am via petsc-users <
>>>>>>>> Using a larger problem set with 2B non-zero elements and a matrix
>>>>>>>> of 25M x 25M I get the following error:
>>>>>>>> [4]PETSC ERROR:
>>>>>>>> [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>> Violation, probably memory access out of range
>>>>>>>> [4]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>> -on_error_attach_debugger
>>>>>>>> [4]PETSC ERROR: or see
>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>>>>>> Mac OS X to find memory corruption errors
>>>>>>>> [4]PETSC ERROR: likely location of problem given in stack below
>>>>>>>> [4]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>>>> available,
>>>>>>>> [4]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>>> function
>>>>>>>> [4]PETSC ERROR:       is given.
>>>>>>>> [4]PETSC ERROR: [4] MatCreateSeqAIJWithArrays line 4422
>>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/aij.c
>>>>>>>> [4]PETSC ERROR: [4] MatMatMultSymbolic_SeqAIJ_SeqAIJ line 747
>>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/matmatmult.c
>>>>>>>> [4]PETSC ERROR: [4]
>>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable line 1256
>>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult_MPIAIJ_MPIAIJ line 1156
>>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult line 9950
>>>>>>>> /lustre/home/vef002/petsc/src/mat/interface/matrix.c
>>>>>>>> [4]PETSC ERROR: [4] PCGAMGCoarsen_AGG line 871
>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/agg.c
>>>>>>>> [4]PETSC ERROR: [4] PCSetUp_GAMG line 428
>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>> [4]PETSC ERROR: [4] PCSetUp line 894
>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/interface/precon.c
>>>>>>>> [4]PETSC ERROR: [4] KSPSetUp line 304
>>>>>>>> /lustre/home/vef002/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>> [4]PETSC ERROR: --------------------- Error Message
>>>>>>>> [4]PETSC ERROR: Signal received
>>>>>>>> [4]PETSC ERROR: See
>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>>>> shooting.
>>>>>>>> [4]PETSC ERROR: Petsc Release Version 3.10.2, unknown
>>>>>>>> [4]PETSC ERROR: ./solveCSys on a linux-cumulus-debug named r02g03
>>>>>>>> by vef002 Fri Jan 11 09:13:23 2019
>>>>>>>> [4]PETSC ERROR: Configure options PETSC_ARCH=linux-cumulus-debug
>>>>>>>> --with-cc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicc
>>>>>>>> --with-fc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpifort
>>>>>>>> --with-cxx=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicxx
>>>>>>>> --download-parmetis --download-metis --download-ptscotch
>>>>>>>> --download-superlu_dist --download-mumps --with-scalar-type=complex
>>>>>>>> --with-debugging=yes --download-scalapack --download-superlu
>>>>>>>> --download-fblaslapack=1 --download-cmake
>>>>>>>> [4]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>>>>>>> MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
>>>>>>>> with errorcode 59.
>>>>>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>>>>>> You may or may not see output from other processes, depending on
>>>>>>>> exactly when Open MPI kills them.
>>>>>>>> [0]PETSC ERROR:
>>>>>>>> the batch system) has told this process to end
>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>> [0]PETSC ERROR: or see
>>>>>>>> Using Valgrind on only one of the valgrind files the following
>>>>>>>> error was written:
>>>>>>>> ==9053== Invalid read of size 4
>>>>>>>> ==9053==    at 0x5B8067E: MatCreateSeqAIJWithArrays (aij.c:4445)
>>>>>>>> ==9053==    by 0x5BC2608: MatMatMultSymbolic_SeqAIJ_SeqAIJ
>>>>>>>> (matmatmult.c:790)
>>>>>>>> ==9053==    by 0x5D106F8:
>>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable (mpimatmatmult.c:1337)
>>>>>>>> ==9053==    by 0x5D0E84E: MatTransposeMatMult_MPIAIJ_MPIAIJ
>>>>>>>> (mpimatmatmult.c:1186)
>>>>>>>> ==9053==    by 0x5457C57: MatTransposeMatMult (matrix.c:9984)
>>>>>>>> ==9053==    by 0x64DD99D: PCGAMGCoarsen_AGG (agg.c:882)
>>>>>>>> ==9053==    by 0x64C7527: PCSetUp_GAMG (gamg.c:522)
>>>>>>>> ==9053==    by 0x6592AA0: PCSetUp (precon.c:932)
>>>>>>>> ==9053==    by 0x66B1267: KSPSetUp (itfunc.c:391)
>>>>>>>> ==9053==    by 0x4019A2: main (solveCmplxLinearSys.cpp:68)
>>>>>>>> ==9053==  Address 0x8386997f4 is not stack'd, malloc'd or
>>>>>>>> (recently) free'd
>>>>>>>> ==9053==
>>>>>>>> On Fri, Jan 11, 2019 at 8:41 AM Sal Am <tempohoper at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Thank you Dave,
>>>>>>>>> I reconfigured PETSc with valgrind and debugging mode, I ran the
>>>>>>>>> code again with the following options:
>>>>>>>>> mpiexec -n 8 valgrind --tool=memcheck -q --num-callers=20
>>>>>>>>> --log-file=valgrind.log.%p ./solveCSys -malloc off -ksp_type bcgs -pc_type
>>>>>>>>> gamg -log_view
>>>>>>>>> (as on the petsc website you linked)
>>>>>>>>> It finished solving using the iterative solver, but the resulting
>>>>>>>>> valgrind.log.%p files (all 8 corresponding to each processor) are all
>>>>>>>>> empty. And it took a whooping ~15hours, for what used to take ~10-20min.
>>>>>>>>> Maybe this is because of valgrind? I am not sure. Attached is the log_view.
>>>>>>>>> On Thu, Jan 10, 2019 at 8:59 AM Dave May <dave.mayhem23 at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Thu, 10 Jan 2019 at 08:55, Sal Am via petsc-users <
>>>>>>>>>>> I am not sure what is exactly is wrong as the error changes
>>>>>>>>>>> slightly every time I run it (without changing the parameters).
>>>>>>>>>> This likely implies that you have a memory error in your code (a
>>>>>>>>>> memory leak would not cause this behaviour).
>>>>>>>>>> I strongly suggest you make sure your code is free of memory
>>>>>>>>>> errors.
>>>>>>>>>> You can do this using valgrind. See here
>>>>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>> for an explanation of how to use valgrind.
>>>>>>>>>>> I have attached the first two run's errors and my code.
>>>>>>>>>>> Is there a memory leak somewhere? I have tried running it with
>>>>>>>>>>> -malloc_dump, but not getting anything printed out, however, when run with
>>>>>>>>>>> -log_view I see that Viewer is created 4 times, but destroyed 3 times. The
>>>>>>>>>>> way I see it, I have destroyed it where I see I no longer have use for it
>>>>>>>>>>> so not sure if I am wrong. Could this be the reason why it keeps crashing?
>>>>>>>>>>> It crashes as soon as it reads the matrix, before entering the solving mode
>>>>>>>>>>> (I have a print statement before solving starts that never prints).
>>>>>>>>>>> how I run it in the job script on 2 node with 32 processors
>>>>>>>>>>> using the clusters OpenMPI.
>>>>>>>>>>> mpiexec ./solveCSys -ksp_type bcgs -pc_type gamg
>>>>>>>>>>> -ksp_converged_reason -ksp_monitor_true_residual -log_view
>>>>>>>>>>> -ksp_error_if_not_converged -ksp_monitor -malloc_log -ksp_view
>>>>>>>>>>> the matrix:
>>>>>>>>>>> 2 122 821 366 (non-zero elements)
>>>>>>>>>>> 25 947 279 x 25 947 279
>>>>>>>>>>> Thanks and all the best
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/20e8f61e/attachment-0001.html>
