[petsc-users] MPI Iterative solver crash on HPC
Sal Am tempohoper at gmail.com
Thu Jan 17 07:16:26 CST 2019
> SuperLU_dist supports 64-bit ints. Are you not running in parallel?
I will try that, although I think solving the real problem (later on if I
can get this to work) with 30 million finite elements might be a problem
for SuperLU_dist. so it is better to get an iterative solver to work with
first.
1) Try using    -build_twosided allreduce    on this run
How I ran it: mpiexec valgrind --tool=memcheck -q --num-callers=20
--log-file=valgrind.log-osaii.%p ./solveCSys -malloc off -ksp_type bcgs
-pc_type gamg -mattransposematmult_via scalable -build_twosided allreduce
-ksp_monitor -log_view
I have attached the full error output.
2) Is it possible to get something that fails here but we can run. None of
> our tests show this problem.
I am not how I can do that, but i have added my code which is quite short
and should only read and solve the system, the problem arises at larger
matrices for example current test case has 6 million finite elements (~2B
non-zero numbers and 25M x 25M matrix).
On Wed, Jan 16, 2019 at 1:12 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 16, 2019 at 3:52 AM Sal Am via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> The memory requested is an insane number. You may need to use 64 bit
>>> integers.
>> Thanks Mark, I reconfigured it to use 64bit, however in the process it
>> says I can no longer use MUMPS and SuperLU as they are not supported (I see
>> on MUMPS webpage it supports 64int). However it does not exactly solve the
>> problem.
>> This time, it crashes at
>>> [6]PETSC ERROR: #1 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1989
>>> in /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
>>> ierr      = PetscMalloc1(bi[pn]+1,&bj);
>>> which allocates local portion of B^T*A.
>>> You may also try to increase number of cores to reduce local matrix size.
>> So I increased the number of cores to 16 on one node and ran it by :
>> --log-file=valgrind.log-osa.%p ./solveCSys -malloc off -ksp_type bcgs
>> -pc_type gamg -mattransposematmult_via scalable -ksp_monitor -log_view
>> It crashed after reading in the matrix and before starting to solve. The
>> error:
>> [15]PETSC ERROR: [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>> batch system) has told this process to end
>> [0]PETSC ERROR: [1]PETSC ERROR:
>> [2]PETSC ERROR:
>> [2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>> [3]PETSC ERROR:
>> [4]PETSC ERROR:
>> [4]PETSC ERROR: [5]PETSC ERROR: [6]PETSC ERROR:
>> [8]PETSC ERROR:
>> [12]PETSC ERROR:
>> [12]PETSC ERROR: [14]PETSC ERROR:
>> [14]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>> mpiexec noticed that process rank 10 with PID 0 on node r03n01 exited on
>> signal 9 (Killed).
>> Now I was running this with valgrind as someone had previously suggested
>> and the 16 files created all contain the same type of error:
> Okay, its possible that there are bugs in the MPI implementation. So
>   Thanks,
>      Matt
>> ==25940== Invalid read of size 8
>> ==25940==    at 0x5103326: PetscCheckPointer (checkptr.c:81)
>> ==25940==    by 0x4F42058: PetscCommGetNewTag (tagm.c:77)
>> ==25940==    by 0x4FC952D: PetscCommBuildTwoSidedFReq_Ibarrier
>> (mpits.c:373)
>> ==25940==    by 0x4FCB29B: PetscCommBuildTwoSidedFReq (mpits.c:572)
>> ==25940==    by 0x52BBFF4: VecAssemblyBegin_MPI_BTS (pbvec.c:251)
>> ==25940==    by 0x52D6B42: VecAssemblyBegin (vector.c:140)
>> ==25940==    by 0x5328C97: VecLoad_Binary (vecio.c:141)
>> ==25940==    by 0x5329051: VecLoad_Default (vecio.c:516)
>> ==25940==    by 0x52E0BAB: VecLoad (vector.c:933)
>> ==25940==    by 0x4013D5: main (solveCmplxLinearSys.cpp:31)
>> ==25940==  Address 0x19f807fc is 12 bytes inside a block of size 16
>> alloc'd
>> ==25940==    at 0x4C2A603: memalign (vg_replace_malloc.c:899)
>> ==25940==    by 0x4FD0B0E: PetscMallocAlign (mal.c:41)
>> ==25940==    by 0x4FD23E7: PetscMallocA (mal.c:397)
>> ==25940==    by 0x4FC948E: PetscCommBuildTwoSidedFReq_Ibarrier
>> (mpits.c:371)
>> ==25940==
>> On Mon, Jan 14, 2019 at 7:29 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>> Fande:
>>>> According to this PR
>>>> https://bitbucket.org/petsc/petsc/pull-requests/1061/a_selinger-feature-faster-scalable/diff
>>>> Should we set the scalable algorithm as default?
>>> Sure, we can. But I feel we need do more tests to compare scalable and
>>> non-scalable algorithms.
>>> On theory, for small to medium matrices, non-scalable matmatmult()
>>> algorithm enables more efficient
>>> data accessing. Andreas optimized scalable implementation. Our
>>> non-scalable implementation might have room to be further optimized.
>>> Hong
>>>> On Fri, Jan 11, 2019 at 10:34 AM Zhang, Hong via petsc-users <
>>>>> Add option '-mattransposematmult_via scalable'
>>>>> Hong
>>>>> On Fri, Jan 11, 2019 at 9:52 AM Zhang, Junchao via petsc-users <
>>>>>> I saw the following error message in your first email.
>>>>>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>>>>>> [0]PETSC ERROR: too large an object or bleeding by not properly
>>>>>> [0]PETSC ERROR: destroying unneeded objects.
>>>>>> Probably the matrix is too large. You can try with more compute
>>>>>> nodes, for example, use 8 nodes instead of 2, and see what happens.
>>>>>> --Junchao Zhang
>>>>>> On Fri, Jan 11, 2019 at 7:45 AM Sal Am via petsc-users <
>>>>>>> Using a larger problem set with 2B non-zero elements and a matrix of
>>>>>>> 25M x 25M I get the following error:
>>>>>>> [4]PETSC ERROR:
>>>>>>> [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation, probably memory access out of range
>>>>>>> [4]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> -on_error_attach_debugger
>>>>>>> [4]PETSC ERROR: or see
>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>>>>> Mac OS X to find memory corruption errors
>>>>>>> [4]PETSC ERROR: likely location of problem given in stack below
>>>>>>> [4]PETSC ERROR: ---------------------  Stack Frames
>>>>>>> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>>> available,
>>>>>>> [4]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>> function
>>>>>>> [4]PETSC ERROR:       is given.
>>>>>>> [4]PETSC ERROR: [4] MatCreateSeqAIJWithArrays line 4422
>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/aij.c
>>>>>>> [4]PETSC ERROR: [4] MatMatMultSymbolic_SeqAIJ_SeqAIJ line 747
>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/matmatmult.c
>>>>>>> [4]PETSC ERROR: [4]
>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable line 1256
>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult_MPIAIJ_MPIAIJ line 1156
>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult line 9950
>>>>>>> /lustre/home/vef002/petsc/src/mat/interface/matrix.c
>>>>>>> [4]PETSC ERROR: [4] PCGAMGCoarsen_AGG line 871
>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/agg.c
>>>>>>> [4]PETSC ERROR: [4] PCSetUp_GAMG line 428
>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/gamg.c
>>>>>>> [4]PETSC ERROR: [4] PCSetUp line 894
>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/interface/precon.c
>>>>>>> [4]PETSC ERROR: [4] KSPSetUp line 304
>>>>>>> /lustre/home/vef002/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>> [4]PETSC ERROR: --------------------- Error Message
>>>>>>> [4]PETSC ERROR: Signal received
>>>>>>> [4]PETSC ERROR: See
>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>>> shooting.
>>>>>>> [4]PETSC ERROR: Petsc Release Version 3.10.2, unknown
>>>>>>> [4]PETSC ERROR: ./solveCSys on a linux-cumulus-debug named r02g03 by
>>>>>>> vef002 Fri Jan 11 09:13:23 2019
>>>>>>> [4]PETSC ERROR: Configure options PETSC_ARCH=linux-cumulus-debug
>>>>>>> --with-cc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicc
>>>>>>> --with-fc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpifort
>>>>>>> --with-cxx=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicxx
>>>>>>> --download-parmetis --download-metis --download-ptscotch
>>>>>>> --download-superlu_dist --download-mumps --with-scalar-type=complex
>>>>>>> --with-debugging=yes --download-scalapack --download-superlu
>>>>>>> --download-fblaslapack=1 --download-cmake
>>>>>>> [4]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>>>>>> MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
>>>>>>> with errorcode 59.
>>>>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>>>>> You may or may not see output from other processes, depending on
>>>>>>> exactly when Open MPI kills them.
>>>>>>> [0]PETSC ERROR:
>>>>>>> the batch system) has told this process to end
>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> [0]PETSC ERROR: or see
>>>>>>> Using Valgrind on only one of the valgrind files the following error
>>>>>>> was written:
>>>>>>> ==9053== Invalid read of size 4
>>>>>>> ==9053==    at 0x5B8067E: MatCreateSeqAIJWithArrays (aij.c:4445)
>>>>>>> ==9053==    by 0x5BC2608: MatMatMultSymbolic_SeqAIJ_SeqAIJ
>>>>>>> (matmatmult.c:790)
>>>>>>> ==9053==    by 0x5D106F8:
>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable (mpimatmatmult.c:1337)
>>>>>>> ==9053==    by 0x5D0E84E: MatTransposeMatMult_MPIAIJ_MPIAIJ
>>>>>>> (mpimatmatmult.c:1186)
>>>>>>> ==9053==    by 0x5457C57: MatTransposeMatMult (matrix.c:9984)
>>>>>>> ==9053==    by 0x64DD99D: PCGAMGCoarsen_AGG (agg.c:882)
>>>>>>> ==9053==    by 0x64C7527: PCSetUp_GAMG (gamg.c:522)
>>>>>>> ==9053==    by 0x6592AA0: PCSetUp (precon.c:932)
>>>>>>> ==9053==    by 0x66B1267: KSPSetUp (itfunc.c:391)
>>>>>>> ==9053==    by 0x4019A2: main (solveCmplxLinearSys.cpp:68)
>>>>>>> ==9053==  Address 0x8386997f4 is not stack'd, malloc'd or (recently)
>>>>>>> free'd
>>>>>>> ==9053==
>>>>>>> On Fri, Jan 11, 2019 at 8:41 AM Sal Am <tempohoper at gmail.com> wrote:
>>>>>>>> Thank you Dave,
>>>>>>>> I reconfigured PETSc with valgrind and debugging mode, I ran the
>>>>>>>> code again with the following options:
>>>>>>>> mpiexec -n 8 valgrind --tool=memcheck -q --num-callers=20
>>>>>>>> --log-file=valgrind.log.%p ./solveCSys -malloc off -ksp_type bcgs -pc_type
>>>>>>>> gamg -log_view
>>>>>>>> (as on the petsc website you linked)
>>>>>>>> It finished solving using the iterative solver, but the resulting
>>>>>>>> valgrind.log.%p files (all 8 corresponding to each processor) are all
>>>>>>>> empty. And it took a whooping ~15hours, for what used to take ~10-20min.
>>>>>>>> Maybe this is because of valgrind? I am not sure. Attached is the log_view.
>>>>>>>> On Thu, Jan 10, 2019 at 8:59 AM Dave May <dave.mayhem23 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Thu, 10 Jan 2019 at 08:55, Sal Am via petsc-users <
>>>>>>>>>> I am not sure what is exactly is wrong as the error changes
>>>>>>>>>> slightly every time I run it (without changing the parameters).
>>>>>>>>> This likely implies that you have a memory error in your code (a
>>>>>>>>> memory leak would not cause this behaviour).
>>>>>>>>> I strongly suggest you make sure your code is free of memory
>>>>>>>>> errors.
>>>>>>>>> You can do this using valgrind. See here
>>>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>> for an explanation of how to use valgrind.
>>>>>>>>>> I have attached the first two run's errors and my code.
>>>>>>>>>> Is there a memory leak somewhere? I have tried running it with
>>>>>>>>>> -malloc_dump, but not getting anything printed out, however, when run with
>>>>>>>>>> -log_view I see that Viewer is created 4 times, but destroyed 3 times. The
>>>>>>>>>> way I see it, I have destroyed it where I see I no longer have use for it
>>>>>>>>>> so not sure if I am wrong. Could this be the reason why it keeps crashing?
>>>>>>>>>> It crashes as soon as it reads the matrix, before entering the solving mode
>>>>>>>>>> (I have a print statement before solving starts that never prints).
>>>>>>>>>> how I run it in the job script on 2 node with 32 processors using
>>>>>>>>>> the clusters OpenMPI.
>>>>>>>>>> mpiexec ./solveCSys -ksp_type bcgs -pc_type gamg
>>>>>>>>>> -ksp_converged_reason -ksp_monitor_true_residual -log_view
>>>>>>>>>> -ksp_error_if_not_converged -ksp_monitor -malloc_log -ksp_view
>>>>>>>>>> the matrix:
>>>>>>>>>> 2 122 821 366 (non-zero elements)
>>>>>>>>>> 25 947 279 x 25 947 279
>>>>>>>>>> Thanks and all the best
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/f9fcc7c7/attachment-0001.html>
static char help[] = "Solves a complex sparse linear system in parallel with KSP.\n\n";
#include <petscksp.h>
#include <iostream>
int main(int argc,char **args){
    Vec            x,b;           /* approx solution, RHS */
    Mat            A, F;             /* linear system matrix */
    KSP            ksp;           /* linear solver context */
    // PetscReal      norm;          /* norm of solution error */
    PC             pc;            /* petsc preconditioner object */
    PetscMPIInt    rank, size;    /* petsc mpi rank and size object */
    PetscViewer    viewer;        /* petsc viewer object needed for vis. and reading */
    PetscErrorCode ierr;
    // Initialise PETSc needed in the beginning of program, includes MPI initialisation.
    ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return ierr;
    MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
    MPI_Comm_size(PETSC_COMM_WORLD,&size);
    // Check if configured with complex
    #if !defined(PETSC_USE_COMPLEX)
      SETERRQ(PETSC_COMM_WORLD,1,"This example requires complex numbers");
    #endif
           Read the matrix and right-hand-side vector that defines
           the linear system, Ax = b.
    ierr = PetscPrintf(PETSC_COMM_WORLD,"Reading vector in binary from Vector_b.dat ...\n");CHKERRQ(ierr);
    ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../petscpy/petscFiles/Vector_b.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
    ierr = VecCreate(PETSC_COMM_WORLD, &b);CHKERRQ(ierr);
    ierr = VecLoad(b,viewer); CHKERRQ(ierr);
    ierr = PetscPrintf(PETSC_COMM_WORLD,"Vector b read.\n");CHKERRQ(ierr);
    ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
    ierr = PetscPrintf(PETSC_COMM_WORLD,"Reading matrix in binary from Matrix_A.dat ...\n");CHKERRQ(ierr);
    ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../petscpy/petscFiles/Matrix_A.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
    ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
    ierr = MatLoad(A,viewer);CHKERRQ(ierr);
    ierr = PetscPrintf(PETSC_COMM_WORLD,"Matrix A read.\n");CHKERRQ(ierr);
    // Duplicate vector b for solution x, content not duplicated.
    ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
                  Create the linear solver and set various options
    // Create linear solver context
    ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
    /* Set operators. Here the matrix that defines the linear system
       also serves as the preconditioning constructor matrix.*/
    ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
    /* Set runtime options, e.g., -ksp_type <type> -pc_type <type>
     -ksp_monitor -ksp_rtol <rtol>. Here MUMPS is used if no runtime options is provided. */
    // ierr = KSPSetType(ksp, KSPGMRES);CHKERRQ(ierr);
    // ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
    // ierr = PCSetType(pc, PCLU);CHKERRQ(ierr);
    // ierr = PCFactorSetMatSolverType(pc, MATSOLVERMUMPS);CHKERRQ(ierr);
    ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
                        Solve the linear system
    /* KSPSetUp and KSPSetUpOnBlocks are optional.
    Used to enable more precise profiling of setting up the preconditioner */
    ierr = KSPSetUp(ksp);CHKERRQ(ierr);
    // ierr = PCFactorGetMatrix(pc, &F);
    ierr = KSPSetUpOnBlocks(ksp);CHKERRQ(ierr);
    ierr = PetscPrintf(PETSC_COMM_WORLD,"Solving the system Ax=b\n");CHKERRQ(ierr);
    ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
    ierr = PetscPrintf(PETSC_COMM_WORLD,"Done solving.\n");CHKERRQ(ierr);
    // Uncomment the following to view the solution in terminal
    // ierr = VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
                        Save solution and clean up
    ierr = PetscPrintf(PETSC_COMM_WORLD, "Writing solution x in PETSc binary file Vector_x_petsc.dat\n");CHKERRQ(ierr);
    ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD, "../petscpy/petscFiles/Vector_x_petsc.dat", FILE_MODE_WRITE, &viewer);CHKERRQ(ierr);
    ierr = PetscViewerBinarySetSkipHeader(viewer, PETSC_TRUE);CHKERRQ(ierr);
    ierr = VecView(x,viewer);CHKERRQ(ierr);CHKERRQ(ierr);
       Free work space.  All PETSc objects should be destroyed when they
       are no longer needed.
    ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
    ierr = VecDestroy(&x);CHKERRQ(ierr);
    ierr = VecDestroy(&b);CHKERRQ(ierr);
    ierr = MatDestroy(&A);CHKERRQ(ierr);
    ierr = PetscFinalize();
    return ierr;
/*TEST
   build:
      requires: complex, MUMPS
      optional: SuperLU_dist, SuperLU
   test:
      mpiexec -n 4 ./test -ksp_type gmres -pc_type lu -pc_factor_mat_solver_type mumps -ksp_max_it 1 -ksp_monitor_true_residual
TEST*/
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/f9fcc7c7/attachment-0001.obj>
