[petsc-users] KSP solve time and iterations
Valerio Barnabei
valerio.barnabei at gmail.com
Mon Jan 14 08:08:08 CST 2019
Thank you Stefano for your quick answer, I will try to change PC as you
suggest, and I will read something about MATIS type. I will let you know if
I still have doubts.
Valerio
Il giorno dom 13 gen 2019 alle ore 16:08 Stefano Zampini <
stefano.zampini at gmail.com> ha scritto:
> What problem are you trying to solve?
> For standard elliptic problems (e.g. poisson or elasticity) you should use
> a preconditioner that scales, for example PCGAMG or BoomerAMG from HYPRE
> (PCHYPRE, if you configured PETSc with support for HYPRE via
> --download-hypre)
> Alternatively, since you are using FEM with local Assembly, you can use
> PCBDDC, but this requires few extra calls
> - call MatSetType(K,MATIS)
> - provide an ISLocalToGlobalMapping of local to global degrees of freedom
> before you set preallocation via MatSetLocalToGlobalMapping (if you provide
> this call, then you can use MatSetValuesLocal for both AIJ amd MATIS types)
> Il giorno dom 13 gen 2019 alle ore 17:59 Valerio Barnabei via petsc-users <
> petsc-users at mcs.anl.gov> ha scritto:
>> Hello everybody,
>> I have some doubts about the parallel solution of a simple FEM ksp
>> problem. I searched in the mailing list but the information I found are not
>> helping me.
>> I need to control manually the parallel assemble of the main matrix, but
>> I would like to use PetSC for the solution of the final linear system
>> K*U=F.
>> The algorithm I am using, loads an already decomposed FEM domain, and
>> each process contributes to the global matrix assembly using its portion of
>> domain decomposition (made in pre-processing). In the element loop, at each
>> element I load the element submatrix in the global matrix via MatSetValue
>> function. Then, out of the element loop, I write
>> ...matrix preallocation
>> ...calculate element local stiffness matrix (local in a FEM sense and
>> local in a domain decomposition sense)
>> MatSetValue (ADD)
>> and then
>> ierr=MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr=MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr=VecAssemblyBegin(F);CHKERRQ(ierr);
>> ierr=VecAssemblyEnd(F);CHKERRQ(ierr);
>> This part scales perfectly and is sufficiently fast.
>> My K matrix is a sort of banded diagonal matrix: my preallocation is not
>> perfect, but it works at this stage of my work.
>> Finally I solve the system with the ksp logic:
>> ierr=KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>> ierr=KSPSetOperators(ksp,K,K);CHKERRQ(ierr);
>> ierr=KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>> ierr=PCSetType(pc,PCBJACOBI);CHKERRQ(ierr); //or PCNONE, or PCJACOBI, the
>> behaviour is almost identical, the iteration number lowers but is still
>> really high
>> ierr=KSPSetTolerances(ksp,1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
>> ierr=KSPSetFromOptions(ksp);CHKERRQ(ierr);
>> ierr=KSPSolve(ksp,F,sol);
>> When I run the code I am noticing some strange behaviours. Indeed, the
>> numerical solution appear right, and the code scales if I make a simple
>> strong-scaling test. However, the ksp_log and log_view (see below, logs for
>> a 160k quad linear element uniform 2dmesh) shows me a huge number of
>> iterations, and the time spent in "solve" function is very high.
>> Furthermore, the more I increase the problem size keeping a constant load
>> per process (weak scaling) the more iterations seems to be needed for
>> convergence. In general, when increasing the problem size (i.e. 16M
>> elements) the convergence is not achieved before the maximum iteration
>> number is achieved.
>> Question 1: Am I doing it right? Or am I making some trouble with the MPI
>> communication management? (i'm aware that my domain decomposition does not
>> match the petsc matrix decomposition, I'm expecting it to cripple my
>> algorithm a bit)
>> Question 2: Why the solver takes so much time and so many iterations? the
>> problem is really simple, and the solution appears correct when plotted. Am
>> I ill conditioning the system?
>> Thanks in advance for your help. I can add any further information if
>> needed.
>> Valerio
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190114/7cbbaf96/attachment-0001.html>
