[petsc-users] KSP solve time and iterations
Stefano Zampini stefano.zampini at gmail.com
Sun Jan 13 09:08:36 CST 2019
What problem are you trying to solve?
For standard elliptic problems (e.g. poisson or elasticity) you should use
a preconditioner that scales, for example PCGAMG or BoomerAMG from HYPRE
(PCHYPRE, if you configured PETSc with support for HYPRE via
--download-hypre)
Alternatively, since you are using FEM with local Assembly, you can use
PCBDDC, but this requires few extra calls
- call MatSetType(K,MATIS)
- provide an ISLocalToGlobalMapping of local to global degrees of freedom
before you set preallocation via MatSetLocalToGlobalMapping (if you provide
this call, then you can use MatSetValuesLocal for both AIJ amd MATIS types)
Il giorno dom 13 gen 2019 alle ore 17:59 Valerio Barnabei via petsc-users <
petsc-users at mcs.anl.gov> ha scritto:
> Hello everybody,
> I have some doubts about the parallel solution of a simple FEM ksp
> problem. I searched in the mailing list but the information I found are not
> helping me.
> I need to control manually the parallel assemble of the main matrix, but I
> would like to use PetSC for the solution of the final linear system K*U=F.
> The algorithm I am using, loads an already decomposed FEM domain, and each
> process contributes to the global matrix assembly using its portion of
> domain decomposition (made in pre-processing). In the element loop, at each
> element I load the element submatrix in the global matrix via MatSetValue
> function. Then, out of the element loop, I write
> ...matrix preallocation
> ...calculate element local stiffness matrix (local in a FEM sense and
> local in a domain decomposition sense)
> MatSetValue (ADD)
> and then
> ierr=MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr=MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr=VecAssemblyBegin(F);CHKERRQ(ierr);
> ierr=VecAssemblyEnd(F);CHKERRQ(ierr);
> This part scales perfectly and is sufficiently fast.
> My K matrix is a sort of banded diagonal matrix: my preallocation is not
> perfect, but it works at this stage of my work.
> Finally I solve the system with the ksp logic:
> ierr=KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
> ierr=KSPSetOperators(ksp,K,K);CHKERRQ(ierr);
> ierr=KSPGetPC(ksp,&pc);CHKERRQ(ierr);
> ierr=PCSetType(pc,PCBJACOBI);CHKERRQ(ierr); //or PCNONE, or PCJACOBI, the
> behaviour is almost identical, the iteration number lowers but is still
> really high
> ierr=KSPSetTolerances(ksp,1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
> ierr=KSPSetFromOptions(ksp);CHKERRQ(ierr);
> ierr=KSPSolve(ksp,F,sol);
> When I run the code I am noticing some strange behaviours. Indeed, the
> numerical solution appear right, and the code scales if I make a simple
> strong-scaling test. However, the ksp_log and log_view (see below, logs for
> a 160k quad linear element uniform 2dmesh) shows me a huge number of
> iterations, and the time spent in "solve" function is very high.
> Furthermore, the more I increase the problem size keeping a constant load
> per process (weak scaling) the more iterations seems to be needed for
> convergence. In general, when increasing the problem size (i.e. 16M
> elements) the convergence is not achieved before the maximum iteration
> number is achieved.
> Question 1: Am I doing it right? Or am I making some trouble with the MPI
> communication management? (i'm aware that my domain decomposition does not
> match the petsc matrix decomposition, I'm expecting it to cripple my
> algorithm a bit)
> Question 2: Why the solver takes so much time and so many iterations? the
> problem is really simple, and the solution appears correct when plotted. Am
> I ill conditioning the system?
> Thanks in advance for your help. I can add any further information if
> needed.
> Valerio
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190113/1a23f79b/attachment.html>
