[petsc-users] Any reason for API change: DMGetWorkArray()
Thu Jan 10 16:36:21 CST 2019
On Thu, Jan 10, 2019 at 5:31 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Thanks, Matt,
> And then what is the reason to remove PetscDataType? I am out of curiosity.
Occam's Razor: "one should not increase, beyond what is necessary, the
number of entities required to explain anything"
   Matt
> DMGetWorkArray is a little misleading. This may/might make people think
> the routine is related to MPI, but it does not have anything to do with MPI.
> Thanks,
> Fande,
> On Thu, Jan 10, 2019 at 3:22 PM Matthew Knepley <knepley at gmail.com> wrote:
>> We are trying to eliminate PetscDataType.
>>   Matt
>> On Thu, Jan 10, 2019 at 5:10 PM Fande Kong via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi All,
>>> The second parameter is changed from PetscDataType to MPI_Datatype
>>> starting from PETSc-3.9.x
>>> Thanks,
>>> Fande Kong,
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190110/9c4a526f/attachment.html>
