[petsc-users] Data types for local ID's and global ID's for large problems
Wed Jan 9 16:55:26 CST 2019
On Wed, Jan 9, 2019 at 5:53 PM Weston, Brian Thomas via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Does PETSc have different data types for local ID’s and global ID’s? For
> example, if PETSc is configured for 32-bit indices on very large problems
> with say 10 billion degrees of freedoms (exceeding the limit of 32-bit
> indices for a global ID) would it crash and require us to re-compile with
> 64-bit indices or can it gracefully handle this?
You would need to reconfigure for 64-bit indices. Keeping local indices
32-bit does not do much. I experimented with a local-index-only version
several years ago, but it breaks a lot of things, and does not really
deliver much benefit.
    Matt
> Sincerely,
> Brian
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190109/bd65e09d/attachment.html>
