[petsc-users] DMPlexSetRefinementFunction
David Fuentes fuentesdt at gmail.com
Mon Jan 7 10:41:42 CST 2019
thanks Matt,
I posted a slightly modified example
https://github.com/fuentesdt/dmplexrefinement/blob/master/ex45.c
and changes from the orginal
https://github.com/fuentesdt/dmplexrefinement/blob/master/refinement.diff
This is what I'm seeing
https://github.com/fuentesdt/dmplexrefinement/blob/master/paraview.png
I'm refining based on this element centroid:
https://github.com/fuentesdt/dmplexrefinement/blob/master/testcentroid.stl
unrefined -
https://github.com/fuentesdt/dmplexrefinement/blob/master/unrefined.vtu
refined -
https://github.com/fuentesdt/dmplexrefinement/blob/master/refined.vtu
Maybe I don't understand the refinement algorithm, but the refinement is a
little offset from what I was expecting.
Also, can you pass an application context to the user refinement function ?
https://github.com/fuentesdt/dmplexrefinement/blob/master/ex45.c#L119
On Thu, Jan 3, 2019 at 7:49 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 2, 2019 at 7:28 PM David Fuentes via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi,
>> Starting with TS example 45
>> $ pwd
>> /opt/apps/PETSc/petsc-3.10.2
>> $ ls src/ts/examples/tutorials/ex45.c
>> petsc configured with: ./config/configure.py --with-shared-libraries
>> --with-clanguage=c++ --CFLAGS='-g -O0' --CXXFLAGS='-g -O0'  --with-c2html=0
>> --download-ctetgen  --download-triangle --with-debugging=yes
>> --download-netcdf  --download-zlib  --download-exodusii --download-hdf5
>> --download-pnetcdf
>> I'm trying to refine the DMPlexCreateBoxMesh  with the
>> DMPlexSetRefinementFunction.
>> It generally seems to be working, except that the refined element is
>> slightly offset from what I was expecting.
>> Based on my application specific criteria, element id number 7 is flagged
>> to be refined by the DMPlexSetRefinementFunction but when I open in
>> paraview, it looks like element id number 8 is being refined. See attached
>> pic.
>> [image: Screen Shot 2019-01-02 at 6.02.02 PM.png]
>> [image: Screen Shot 2019-01-02 at 6.02.11 PM.png]
>> Is it possible that the maxVolumes array is 'off by one' when transfering
>> to tetgen data structures somehow ?
> I looked through and cannot see it by eye. Could you send me your modified
> example and I will walk through it with the
> debugger?
>   Thanks,
>      Matt
>> https://bitbucket.org/petsc/petsc/src/bd27d3f284687498e4c4678d234c0e308a5bc236/src/dm/impls/plex/plexadapt.c?at=master&fileviewer=file-view-default#plexadapt.c-252
>> (gdb) bt
>> #0  DMPlexRefine_CTetgen (dm=0x932180, maxVolumes=0x919710,
>> dmRefined=0x7fffffffb938) at
>> /opt/apps/PETSc/petsc-3.10.2/src/dm/impls/plex/generators/ctetgen/ctetgenerate.c:182
>> #1  0x00007ffff6b76401 in DMPlexRefine_Internal (dm=0x932180,
>> adaptLabel=0x0, dmRefined=0x7fffffffb938) at
>> /opt/apps/PETSc/petsc-3.10.2/src/dm/impls/plex/plexadapt.c:252
>> #2  0x00007ffff6b72720 in DMRefine_Plex (dm=0x932180, comm=0x6b,
>> /opt/apps/PETSc/petsc-3.10.2/src/dm/impls/plex/plexrefine.c:10361
>> #3  0x00007ffff6dad8ff in DMRefine (dm=0x932180, comm=0x6b,
>> dmf=0x7fffffffb938) at
>> /opt/apps/PETSc/petsc-3.10.2/src/dm/interface/dm.c:1808
>> #4  0x0000000000405274 in CreateMesh (comm=0x7ffff5891680
>> <ompi_mpi_comm_world>, dm=0x7fffffffb9d0, ctx=0x7fffffffba00) at
>> /rsrch1/ip/dtfuentes/github/thermoembo/tutorials/exac.c:253
>> #5  0x00000000004063c4 in main (argc=32, argv=0x7fffffffdb68) at
>> /rsrch1/ip/dtfuentes/github/thermoembo/tutorials/exac.c:336
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190107/f79fe153/attachment.html>
