[petsc-users] DMPlexSetRefinementFunction
Thu Jan 3 07:49:27 CST 2019
On Wed, Jan 2, 2019 at 7:28 PM David Fuentes via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> Starting with TS example 45
> $ pwd
> /opt/apps/PETSc/petsc-3.10.2
> $ ls src/ts/examples/tutorials/ex45.c
> petsc configured with: ./config/configure.py --with-shared-libraries
> --with-clanguage=c++ --CFLAGS='-g -O0' --CXXFLAGS='-g -O0'  --with-c2html=0
> --download-ctetgen  --download-triangle --with-debugging=yes
> --download-netcdf  --download-zlib  --download-exodusii --download-hdf5
> --download-pnetcdf
> I'm trying to refine the DMPlexCreateBoxMesh  with the
> DMPlexSetRefinementFunction.
> It generally seems to be working, except that the refined element is
> slightly offset from what I was expecting.
> Based on my application specific criteria, element id number 7 is flagged
> to be refined by the DMPlexSetRefinementFunction but when I open in
> paraview, it looks like element id number 8 is being refined. See attached
> pic.
> [image: Screen Shot 2019-01-02 at 6.02.02 PM.png]
> [image: Screen Shot 2019-01-02 at 6.02.11 PM.png]
> Is it possible that the maxVolumes array is 'off by one' when transfering
> to tetgen data structures somehow ?
I looked through and cannot see it by eye. Could you send me your modified
example and I will walk through it with the
debugger?
     Matt
> https://bitbucket.org/petsc/petsc/src/bd27d3f284687498e4c4678d234c0e308a5bc236/src/dm/impls/plex/plexadapt.c?at=master&fileviewer=file-view-default#plexadapt.c-252
> (gdb) bt
> #0  DMPlexRefine_CTetgen (dm=0x932180, maxVolumes=0x919710,
> dmRefined=0x7fffffffb938) at
> /opt/apps/PETSc/petsc-3.10.2/src/dm/impls/plex/generators/ctetgen/ctetgenerate.c:182
> #1  0x00007ffff6b76401 in DMPlexRefine_Internal (dm=0x932180,
> adaptLabel=0x0, dmRefined=0x7fffffffb938) at
> /opt/apps/PETSc/petsc-3.10.2/src/dm/impls/plex/plexadapt.c:252
> #2  0x00007ffff6b72720 in DMRefine_Plex (dm=0x932180, comm=0x6b,
> /opt/apps/PETSc/petsc-3.10.2/src/dm/impls/plex/plexrefine.c:10361
> #3  0x00007ffff6dad8ff in DMRefine (dm=0x932180, comm=0x6b,
> dmf=0x7fffffffb938) at
> /opt/apps/PETSc/petsc-3.10.2/src/dm/interface/dm.c:1808
> #4  0x0000000000405274 in CreateMesh (comm=0x7ffff5891680
> <ompi_mpi_comm_world>, dm=0x7fffffffb9d0, ctx=0x7fffffffba00) at
> /rsrch1/ip/dtfuentes/github/thermoembo/tutorials/exac.c:253
> #5  0x00000000004063c4 in main (argc=32, argv=0x7fffffffdb68) at
> /rsrch1/ip/dtfuentes/github/thermoembo/tutorials/exac.c:336
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190103/11ddcf63/attachment-0001.html>
Name: Screen Shot 2019-01-02 at 6.02.02 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190103/11ddcf63/attachment-0002.png>
Name: Screen Shot 2019-01-02 at 6.02.11 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190103/11ddcf63/attachment-0003.png>
