[petsc-users] VecGetArrayF90 in PETSc/3.10 (Fortran)
Smith, Barry F.
bsmith at mcs.anl.gov
Sun Jan 6 17:24:56 CST 2019
> On Jan 6, 2019, at 5:21 PM, Victor Eijkhout <eijkhout at tacc.utexas.edu> wrote:
> Hey Barry,
> Chang is one of my users and I’m out of my depth here:
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Corrupt argument:
> > [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
> > [0]PETSC ERROR: #1 VecGetArray() line 1578 in
> It looks like VecGetArrayF90 is no longer allowed in callbacks, which is what seems to be happening here.
> Victor.
>> On Jan 6, 2019, at 5:05 PM, Smith, Barry F. via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> What is the error message, cut and paste the entire message?
>> Barry
>>> On Jan 6, 2019, at 3:12 PM, Chang Liu via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>> Hi All,
>>> Recently, when I am upgrading our code from 3.8 to 3.10, it always runs into error during VecGetArrayF90 call (it is Fortran90-based code). The reason we use is to access the array for our user-defined matrix-vector multiplication subroutine, for example:
>>> subroutine mymult(A,x,y,loco_ierr)
>>> !!!!!!!!!!!!!!! matrix-vector multiplication y=A.x !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
>>> use mat_vec_mult,only:matvec
>>> implicit none
>>> Mat,intent(in)::A ! required by PETSc
>>> Vec,intent(in)::x
>>> Vec,intent(out)::y
This is wrong. y is not returned from your subroutine, it is passed into the subroutine and hence is intent(in).
Hopefully this resolves your problem, otherwise let us know.
Barry
>>> PetscErrorCode,intent(out)::loco_ierr
>>> PetscScalar,pointer::xx(:),yy(:)
>>> call VecGetArrayReadF90(x,xx,loco_ierr)
>>> call VecGetArrayF90(y,yy,loco_ierr)
>>> call matvec(xx,yy)
>>> call VecRestoreArrayReadF90(x,xx,loco_ierr)
>>> call VecRestoreArrayF90(y,yy,loco_ierr)
>>> return
>>> end subroutine mymult
>>> I checked the change log on the website and saw a statement:
>>> TAO:
>>> • Added VecLock{Push|Pop} calls around user callbacks; use of VecGetArray in user callbacks is now prohibited.
>>> Is there any relation to my issue? All the online PETSc examples and description for VecGetArray/VecGetArrayF90 are the same as PETSc/3.8. I tried to add/use VecLockPop/Push, but still doesn't work.
>>> I am confused and not sure what is the problem?
>>> Could I get some help?
>>> Thanks,
>>> Chang Liu
>>> PhD candidate
>>> Dept. of Electrical & Computer Engineering
>>> Ph: 765-7143357
>>> Email: chang.liu at utexas.edu
