[petsc-users] VecGetArrayF90 in PETSc/3.10 (Fortran)
Victor Eijkhout
eijkhout at tacc.utexas.edu
Sun Jan 6 17:21:26 CST 2019
Hey Barry,
Chang is one of my users and I’m out of my depth here:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Corrupt argument:
> [0]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
> [0]PETSC ERROR: #1 VecGetArray() line 1578 in
It looks like VecGetArrayF90 is no longer allowed in callbacks, which is what seems to be happening here.
Victor.
On Jan 6, 2019, at 5:05 PM, Smith, Barry F. via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
What is the error message, cut and paste the entire message?
Barry
On Jan 6, 2019, at 3:12 PM, Chang Liu via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi All,
Recently, when I am upgrading our code from 3.8 to 3.10, it always runs into error during VecGetArrayF90 call (it is Fortran90-based code). The reason we use is to access the array for our user-defined matrix-vector multiplication subroutine, for example:
subroutine mymult(A,x,y,loco_ierr)
!!!!!!!!!!!!!!! matrix-vector multiplication y=A.x !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
use mat_vec_mult,only:matvec
implicit none
Mat,intent(in)::A ! required by PETSc
Vec,intent(in)::x
Vec,intent(out)::y
PetscErrorCode,intent(out)::loco_ierr
PetscScalar,pointer::xx(:),yy(:)
call VecGetArrayReadF90(x,xx,loco_ierr)
call VecGetArrayF90(y,yy,loco_ierr)
call matvec(xx,yy)
call VecRestoreArrayReadF90(x,xx,loco_ierr)
call VecRestoreArrayF90(y,yy,loco_ierr)
return
end subroutine mymult
I checked the change log on the website and saw a statement:
TAO:
• Added VecLock{Push|Pop} calls around user callbacks; use of VecGetArray in user callbacks is now prohibited.
Is there any relation to my issue? All the online PETSc examples and description for VecGetArray/VecGetArrayF90 are the same as PETSc/3.8. I tried to add/use VecLockPop/Push, but still doesn't work.
I am confused and not sure what is the problem?
Could I get some help?
Chang Liu
PhD candidate
Dept. of Electrical & Computer Engineering
Ph: 765-7143357
Email: chang.liu at utexas.edu<mailto:chang.liu at utexas.edu>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190106/0d4e81c3/attachment-0001.html>
