[petsc-users] Check vector for zeros
Jed Brown
jed at jedbrown.org
Thu Jan 3 14:25:19 CST 2019
Florian Lindner via petsc-users <petsc-users at mcs.anl.gov> writes:
> I get a vector from a linear solve and is used a divisor in VecPointwiseDivide. Clearly, I must check for zero entries before doing the division.
Note that VecPointwiseDivide does not divide by values that are
identically zero.
for (i=0; i<n; i++) {
if (yy[i] != 0.0) ww[i] = xx[i] / yy[i];
else ww[i] = 0.0;
This is semantically peculiar, but if it's okay for you, you can use
VecChop to truncate sufficiently small values to zero.
> What is the best way to do so, especially performance wise?
> The only way I come up with so far, is to VecCopy, VecAbs and then check for VecMin > eps. The VecCopy kind of scares me for the performance draw back. I haven't found something like a VecAbsMin.
> Any better ideas?
> Thanks,
> Florian
