[petsc-users] Check vector for zeros
Thu Jan 3 10:18:27 CST 2019
On Thu, Jan 3, 2019 at 11:16 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> It already checks for zeros. See VecPointwiseDivide_Seq in
> src/vec/vec/impls/seq/bvec2.c
Yes, I was assuming he wanted to know if there were zeros and take some
other action.
    Matt
> On Jan 3, 2019, at 5:12 PM, Matthew Knepley via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> On Thu, Jan 3, 2019 at 11:01 AM Florian Lindner via petsc-users <
>> Hello,
>> Happy New Year Everybody!
>> I get a vector from a linear solve and is used a divisor in
>> VecPointwiseDivide. Clearly, I must check for zero entries before doing the
>> division.
>> What is the best way to do so, especially performance wise?
>> The only way I come up with so far, is to VecCopy, VecAbs and then check
>> for VecMin > eps. The VecCopy kind of scares me for the performance draw
>> back. I haven't found something like a VecAbsMin.
>> Any better ideas?
> I would write VecAbsMin() yourself,
> https://bitbucket.org/petsc/petsc/src/bd27d3f284687498e4c4678d234c0e308a5bc236/src/vec/vec/utils/vinv.c#lines-299
> https://bitbucket.org/petsc/petsc/src/bd27d3f284687498e4c4678d234c0e308a5bc236/src/vec/vec/utils/vinv.c#lines-1510
> It should only be about 8 lines.
>   Thanks,
>     Matt
>> Thanks,
>> Florian
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190103/eb43cdef/attachment.html>
