[petsc-users] (no subject)
DAFNAKIS PANAGIOTIS panagiotis.dafnakis at polito.it
Wed Feb 27 18:01:17 CST 2019
Hi everybody,
I am trying to install PETSc version 3.10.3 on OSX Sierra
10.13.6 with the following configure options
./configure --CC=mpicc --CXX=mpicxx --FC=mpif90
--PETSC_ARCH=sierra-dbg --with-debugging=1
--download-hypre=1 --with-x=0
however I am getting the following error messages when I
do 'make check'. See below the resulting message. Any
suggestions?
--Panos
panos at Sierra-iMac:~/Softwares/PETSc-Bitbucket/PETSc$ make
PETSC_DIR=/Users/panos/Softwares/PETSc-Bitbucket/PETSc
PETSC_ARCH=sierra-dbg check
Running test examples to verify correct installation
Using
PETSC_DIR=/Users/panos/Softwares/PETSc-Bitbucket/PETSc and
make[2]: [ex19.PETSc] Error 2 (ignored)
*******************Error detected during compile or
link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/Users/panos/Softwares/PETSc-Bitbucket/PETSc/src/snes/examples/tutorials
ex19
mpicc -o ex19.o -c -Wall -Wwrite-strings
-Wno-strict-aliasing -Wno-unknown-pragmas
-Qunused-arguments -fvisibility=hidden -g3
  -I/Users/panos/Softwares/PETSc-Bitbucket/PETSc/include
-I/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/include
   `pwd`/ex19.c
mpicc -Wl,-multiply_defined,suppress -Wl,-multiply_defined
-Wl,suppress -Wl,-commons,use_dylibs
-Wl,-search_paths_first -Wl,-no_compact_unwind    -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-Qunused-arguments -fvisibility=hidden -g3  -o ex19 ex19.o
 -Wl,-rpath,/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib
-L/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib
-Wl,-rpath,/usr/local/Cellar/mpich/3.3/lib
-L/usr/local/Cellar/mpich/3.3/lib
-Wl,-rpath,/usr/local/Cellar/gcc/8.3.0/lib/gcc/8/gcc/x86_64-apple-darwin17.7.0/8.3.0
-L/usr/local/Cellar/gcc/8.3.0/lib/gcc/8/gcc/x86_64-apple-darwin17.7.0/8.3.0
-Wl,-rpath,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries
-L/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries
-Wl,-rpath,/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources
-L/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources
-Wl,-rpath,/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources
-L/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources
-lpetsc -lHYPRE -ldl -lmpifort -lmpi -lpmpi -lgfortran
-lquadmath -lm -lGFXShared -lGLU -lGL -lGLImage
-lCVMSPluginSupport -lFontParser -lFontRegistry -lJPEG
-lTIFF -lPng -lGIF -lJP2 -lRadiance -lCoreVMClient -ldl
ld: warning: text-based stub file
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.tbd
and library file
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
are out of sync. Falling back to library file for linking.
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.tbd
and library file
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.tbd
and library file
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.tbd
and library file
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.tbd
and library file
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.tbd
and library file
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.tbd
and library file
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.tbd
and library file
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.tbd
and library file
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.tbd
and library file
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.tbd
and library file
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.tbd
and library file
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.tbd
and library file
/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.tbd
and library file
/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
/System/Library/Frameworks//CoreFoundation.framework/Versions/A/CoreFoundation.tbd
and library file
/System/Library/Frameworks//IOKit.framework/Versions/A/IOKit.tbd
and library file
/System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator.tbd
and library file
/System/Library/Frameworks//ApplicationServices.framework/Versions/A/ApplicationServices.tbd
and library file
/System/Library/Frameworks//CoreGraphics.framework/Versions/A/CoreGraphics.tbd
and library file
/System/Library/Frameworks//Security.framework/Versions/A/Security.tbd
and library file
/System/Library/Frameworks//CoreServices.framework/Versions/A/CoreServices.tbd
and library file
/System/Library/Frameworks//Foundation.framework/Versions/C/Foundation.tbd
and library file
/System/Library/Frameworks//OpenCL.framework/Versions/A/OpenCL.tbd
and library file
/System/Library/Frameworks//IOSurface.framework/Versions/A/IOSurface.tbd
and library file
/System/Library/Frameworks//CoreText.framework/Versions/A/CoreText.tbd
and library file
/System/Library/Frameworks//ImageIO.framework/Versions/A/ImageIO.tbd
and library file
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS.tbd
and library file
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices.tbd
and library file
/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis.tbd
and library file
/System/Library/Frameworks//CFNetwork.framework/Versions/A/CFNetwork.tbd
and library file
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices.tbd
and library file
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices.tbd
and library file
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList.tbd
and library file
/System/Library/Frameworks//DiskArbitration.framework/Versions/A/DiskArbitration.tbd
and library file
/System/Library/Frameworks//OpenGL.framework/Versions/A/OpenGL.tbd
and library file
/System/Library/Frameworks//CoreAudio.framework/Versions/A/CoreAudio.tbd
and library file
/System/Library/Frameworks//AudioToolbox.framework/Versions/A/AudioToolbox.tbd
and library file
/System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory.tbd
and library file
/System/Library/Frameworks//ServiceManagement.framework/Versions/A/ServiceManagement.tbd
and library file
/System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS.tbd
and library file
Undefined symbols for architecture x86_64:
   "_jpeg_CreateCompress", referenced from:
       import-atom in libpetsc.dylib
   "_jpeg_destroy_compress", referenced from:
   "_jpeg_finish_compress", referenced from:
   "_jpeg_set_defaults", referenced from:
   "_jpeg_start_compress", referenced from:
   "_jpeg_std_error", referenced from:
   "_jpeg_stdio_dest", referenced from:
   "_jpeg_write_scanlines", referenced from:
   "_png_create_info_struct", referenced from:
   "_png_create_write_struct", referenced from:
   "_png_destroy_write_struct", referenced from:
   "_png_init_io", referenced from:
   "_png_set_IHDR", referenced from:
   "_png_set_PLTE", referenced from:
   "_png_set_longjmp_fn", referenced from:
   "_png_write_end", referenced from:
   "_png_write_info", referenced from:
   "_png_write_row", referenced from:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use
-v to see invocation)
make[3]: [ex19] Error 1 (ignored)
/usr/bin/dsymutil ex19
error: cannot parse the debug map for 'ex19': No such file
or directory
make[3]: *** [ex19] Error 1
rm ex19.o
1,5c1,2
< lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
<   0 SNES Function norm 0.0406612
<   1 SNES Function norm 4.12227e-06
<   2 SNES Function norm 6.098e-11
< Number of SNES iterations = 2
> [proxy:0:0 at Sierra-iMac.local] HYDU_create_process (utils/launch/launch.c:74): execvp error on file ./ex19 (No such file or directory)
Possible problem with ex19_hypre, diffs above
ex5f
mpif90 -c -Wall -ffree-line-length-0
-Wno-unused-dummy-argument -g
   -o ex5f.o ex5f.F90
mpif90 -Wl,-multiply_defined,suppress
-Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs
-ffree-line-length-0 -Wno-unused-dummy-argument -g   -o
ex5f ex5f.o
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
and library file
collect2: error: ld returned 1 exit status
make[3]: [ex5f] Error 1 (ignored)
rm ex5f.o
Completed test examples
