[petsc-users] About DMDA (and extracting its ordering)
Thibaut Appel
t.appel17 at imperial.ac.uk
Mon Feb 25 06:15:19 CST 2019
Hi Matthew,
The file in the link you sent does not call DMGetLocalToGlobalMapping
nor ISLocalToGlobalMappingGetIndicesF90 though?
Anyway, everything you wanted is there:
https://bitbucket.org/petsc/petsc/issues/262/fortran-unassociated-pointer-with
Thibaut
On 25/02/2019 12:03, Matthew Knepley wrote:
> On Mon, Feb 25, 2019 at 3:19 AM Appel, Thibaut
> <t.appel17 at imperial.ac.uk <mailto:t.appel17 at imperial.ac.uk>> wrote:
> Hi Matthew,
> Yes I need F90 and the syntax in the file / yours
>> PetscInt, pointer :: id_ltog(:)
> Is the exact same as
>> PetscInt, dimension(:), pointer :: id_ltog
> They’re both modern fortran ”correct”
> Anyways I tried both and I still get the same error message.
> Okay, that file I sent the link to is tested every night, so I suspect
> a compiler bug in your version.
> Please send your entire example so I can run it here. Also, let us
> know what Fortran compiler
> and version you are using again.
> Thanks,
> Matt
> Thibaut
> On 24 Feb 2019, at 23:38, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
>> On Sun, Feb 24, 2019 at 6:33 PM Appel, Thibaut
>> Is that for the id_ltog argument? I tried declaring it as IS,
>> and you can’t declare an deferred-shape array as target. Same
>> message. XXX(:) is syntactic sugar for dimension(:) :: XXX
>> I’m really confused because this
>> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex14f.F90.html
>> doesn’t use the xxxF90 variants of the routines we’re talking
>> about?
>> You can use the F77 stuff if you want. I thought you needed F90.
>> For F90, I think you need to declare it
>> like it is in the link I sent you.
>> Thanks,
>> Matt
>> Thibaut
>>> On 24 Feb 2019, at 22:50, Matthew Knepley <knepley at gmail.com
>>> On Sun, Feb 24, 2019 at 4:28 PM Appel, Thibaut
>>> wrote:
>>> Hi Matthew,
>>> With the following data declaration and routines calls:
>>> I am not a Fortran90 expert, but your declaration looks
>>> different than the ones I have seen work:
>>> https://bitbucket.org/petsc/petsc/src/master/src/dm/impls/plex/examples/tutorials/ex1f90.F90
>>> Thanks,
>>> Matt
>>> DM :: da
>>> ISLocalToGlobalMapping :: ltog
>>> PetscInt, DIMENSION(:), POINTER :: id_ltog
>>> CALL
>>> DMDACreate2D(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,(nx+1),(ny+1),
>>> PETSC_DECIDE,PETSC_DECIDE,neq,0,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>>> CHKERRA(ierr)
>>> CALL DMSetUp(da,ierr)
>>> CHKERRA(ierr)
>>> CALL
>>> DMDAGetCorners(da,icx,icy,PETSC_NULL_INTEGER,lx,ly,PETSC_NULL_INTEGER,ierr)
>>> CHKERRA(ierr)
>>> CALL DMGetLocalToGlobalMapping(da,ltog,ierr)
>>> CHKERRA(ierr)
>>> CALL
>>> ISLocalToGlobalMappingGetIndicesF90(ltog,id_ltog,ierr)
>>> CHKERRA(ierr)
>>> CALL
>>> ISLocalToGlobalMappingRestoreIndicesF90(ltog,id_ltog,ierr)
>>> CHKERRA(ierr)
>>> CALL DMDestroy(da,ierr)
>>> CHKERRA(ierr)
>>> I get, with the most recent Intel Fortran compiler and a
>>> fresh “git pull” PETsc:
>>> forrtl: severe (408): fort: (7): Attempt to use pointer
>>> ID_LTOG when it is not associated with a target
>>> Thibaut
>>>> On 22 Feb 2019, at 15:13, Matthew Knepley
>>>> <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>> On Fri, Feb 22, 2019 at 9:10 AM Thibaut Appel via
>>>> petsc-users <petsc-users at mcs.anl.gov
>>>> <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>> I reckon that what corresponds best to my situation is
>>>> to create my own MPIAIJ matrix, recover the DMDA local
>>>> to global mapping, preallocate myself and fill my
>>>> values with MatSetValues.
>>>> However, what is the correct way to
>>>> call ISLocalToGlobalMappingGetIndices in Fortran? It
>>>> seems there's something missing in the documentation as
>>>> my code just won't work.
>>>> Some examples include a PetscOffset argument which is
>>>> not present in the documentation and there is no manual
>>>> page for ISLocalToGlobalMappingGetIndicesF90: the only
>>>> information I could find is on
>>>> /src/vec/is/utils/f90-custom/zisltogf90.c. Are
>>>> you supposed to allocate the index array yourself? I
>>>> tried declaring it as a pointer too. I keep getting an
>>>> error
>>>> 1) There was a bug in that file, but I don't think it
>>>> should have affected you. I will put in a PR
>>>> 2) You are supposed to pass in a pointer, unallocated.
>>>> We manage all the allocation, which is why you call
>>>> Restore. What happens when you do that?
>>>> Thanks,
>>>> Matt
>>>> [0]PETSC ERROR: #1 User provided function() line 0 in
>>>> User file
>>>> application called MPI_Abort(MPI_COMM_SELF, -42924) -
>>>> process 0
>>>> Minimal example:
>>>> PROGRAM test_dmda
>>>> #include <petsc/finclude/petscdm.h>
>>>> #include <petsc/finclude/petscdmda.h>
>>>> USE PetscDMDA
>>>> IMPLICIT NONE
>>>> PetscErrorCode :: ierr
>>>> PetscInt :: irank, icx, icy, lx, ly, n_ltog
>>>> DM :: da
>>>> PetscInt, DIMENSION(:), ALLOCATABLE :: id_ltog
>>>> !PetscInt, DIMENSION(:), POINTER :: id_ltog
>>>> PetscInt, PARAMETER :: nx=24, ny=9, neq=4
>>>> CHARACTER(LEN=100) :: err_msg
>>>> CALL PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>>> CALL MPI_COMM_RANK(PETSC_COMM_WORLD,irank,ierr)
>>>> CALL DMDACreate2D(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,(nx+1),(ny+1), &
>>>> CHKERRA(ierr)
>>>> CHKERRA(ierr)
>>>> CALL DMDAGetCorners(da,icx,icy,PETSC_NULL_INTEGER,lx,ly,PETSC_NULL_INTEGER,ierr)
>>>> CHKERRA(ierr)
>>>> WRITE(*,'(*(1X,A,I3))') 'I am process #', irank, ' - my
>>>> lower left corner is icx=', icx, &
>>>> 'and icy=', icy, ' - the width is lx=', lx, ' and
>>>> ly=', ly
>>>> CHKERRA(ierr)
>>>> CALL ISLocalToGlobalMappingGetSize(ltog,n_ltog,ierr)
>>>> CHKERRA(ierr)
>>>> ALLOCATE(id_ltog(1:n_ltog),STAT=ierr,ERRMSG=err_msg)
>>>> CALL ISLocalToGlobalMappingGetIndices(ltog,id_ltog,ierr)
>>>> CHKERRA(ierr)
>>>> CALL
>>>> ISLocalToGlobalMappingRestoreIndices(ltog,id_ltog,ierr)
>>>> CHKERRA(ierr)
>>>> DEALLOCATE(id_ltog,STAT=ierr,ERRMSG=err_msg)
>>>> CHKERRA(ierr)
>>>> CALL PetscFinalize(ierr)
>>>> END PROGRAM test_dmda
>>>> On 21/02/2019 17:49, Matthew Knepley wrote:
>>>>> On Thu, Feb 21, 2019 at 11:16 AM Thibaut Appel via
>>>>> Dear PETSc developers/users,
>>>>> I’m solving linear PDEs on a regular grid with
>>>>> high-order finite differences, assembling an MPIAIJ
>>>>> matrix to solve linear systems or eigenvalue problems.
>>>>> I’ve been using vertex major, natural ordering for
>>>>> the parallelism with PetscSplitOwnership (yielding
>>>>> rectangular slices of the physical domain) and wanted
>>>>> to move to DMDA to have a more square-ish domain
>>>>> decomposition and minimize communication between
>>>>> processes.
>>>>> However, my application is memory critical, and I have
>>>>> finely-tuned matrix preallocation routines for
>>>>> allocating memory “optimally”. It seems the memory of
>>>>> a DMDA matrix is allocated along the value of
>>>>> the stencil width of DMDACreate and the manual says
>>>>> about it
>>>>> “These DMDA stencils have nothing directly to do with
>>>>> any finite difference stencils one might chose to use
>>>>> for a discretization”
>>>>> And despite reading the manual pages there must be
>>>>> something I do not understand in the DM topology, what
>>>>> is that "stencil width" for then? I will not use ghost
>>>>> values for my FD-method, right?
>>>>> What this is saying is, "You might be using
>>>>> some stencil that is not STAR or BOX, but we are
>>>>> preallocating according to one of those".
>>>>> If you really care about how much memory
>>>>> is preallocated, which it seems you do, then you might
>>>>> be able to use
>>>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDASetBlockFills.html
>>>>> to tell use exactly how to preallocate.
>>>>> I was then wondering if I could just create a MPIAIJ
>>>>> matrix, and with a PETSc routine get the global
>>>>> indices of the domain for each process: in other
>>>>> words, an equivalent of PetscSplitOwnership
>>>>> that gives me the DMDA unknown ordering. So I can feed
>>>>> and loop on that in my preallocation and
>>>>> assembly routines.
>>>>> You can make an MPIAIJ matrix yourself of course.
>>>>> It should have the same division of rows as the DMDA
>>>>> division of dofs. Also, MatSetValuesStencil() will not
>>>>> work for a custom matrix.
>>>>> Thanks,
>>>>> Matt
>>>>> Thanks very much,
>>>>> Thibaut
>>>>> What most experimenters take for granted before they
>>>>> begin their experiments is infinitely more interesting
>>>>> than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>> -- Norbert Wiener
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> -- Norbert Wiener
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments is infinitely more interesting than any results to
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190225/9ab2c957/attachment-0001.html>
