[petsc-users] About DMDA (and extracting its ordering)
Mon Feb 25 06:03:56 CST 2019
On Mon, Feb 25, 2019 at 3:19 AM Appel, Thibaut <t.appel17 at imperial.ac.uk>
wrote:
> Hi Matthew,
> Yes I need F90 and the syntax in the file / yours
> PetscInt, pointer :: id_ltog(:)
> Is the exact same as
> PetscInt, dimension(:), pointer :: id_ltog
> They’re both modern fortran ”correct”
> Anyways I tried both and I still get the same error message.
Okay, that file I sent the link to is tested every night, so I suspect a
compiler bug in your version.
Please send your entire example so I can run it here. Also, let us know
what Fortran compiler
and version you are using again.
     Matt
> Thibaut
> On 24 Feb 2019, at 23:38, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Feb 24, 2019 at 6:33 PM Appel, Thibaut <t.appel17 at imperial.ac.uk>
> wrote:
>> Is that for the id_ltog argument? I tried declaring it as IS, and you
>> can’t declare an deferred-shape array as target. Same message. XXX(:) is
>> syntactic sugar for dimension(:) :: XXX
>> I’m really confused because this
>> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex14f.F90.html
>> doesn’t use the xxxF90 variants of the routines we’re talking about?
> You can use the F77 stuff if you want. I thought you needed F90.  For F90,
> I think you need to declare it
> like it is in the link I sent you.
>   Thanks,
>      Matt
>> Thibaut
>> On 24 Feb 2019, at 22:50, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Feb 24, 2019 at 4:28 PM Appel, Thibaut <t.appel17 at imperial.ac.uk>
>> wrote:
>>> Hi Matthew,
>>> With the following data declaration and routines calls:
>> I am not a Fortran90 expert, but your declaration looks different than
>> the ones I have seen work:
>> https://bitbucket.org/petsc/petsc/src/master/src/dm/impls/plex/examples/tutorials/ex1f90.F90
>>   Thanks,
>>      Matt
>>>   DM :: da
>>>   ISLocalToGlobalMapping :: ltog
>>>   PetscInt, DIMENSION(:), POINTER :: id_ltog
>>>   CALL
>>> DMDACreate2D(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,(nx+1),(ny+1),
>>>   PETSC_DECIDE,PETSC_DECIDE,neq,0,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>>>   CHKERRA(ierr)
>>>   CALL DMSetUp(da,ierr)
>>>   CHKERRA(ierr)
>>>   CALL
>>> DMDAGetCorners(da,icx,icy,PETSC_NULL_INTEGER,lx,ly,PETSC_NULL_INTEGER,ierr)
>>>   CHKERRA(ierr)
>>>   CALL DMGetLocalToGlobalMapping(da,ltog,ierr)
>>>   CHKERRA(ierr)
>>>   CALL ISLocalToGlobalMappingGetIndicesF90(ltog,id_ltog,ierr)
>>>   CHKERRA(ierr)
>>>   CALL ISLocalToGlobalMappingRestoreIndicesF90(ltog,id_ltog,ierr)
>>>   CHKERRA(ierr)
>>>   CALL DMDestroy(da,ierr)
>>>   CHKERRA(ierr)
>>> I get, with the most recent Intel Fortran compiler and a fresh “git
>>> pull” PETsc:
>>> forrtl: severe (408): fort: (7): Attempt to use pointer ID_LTOG when it
>>> is not associated with a target
>>> Thibaut
>>> On 22 Feb 2019, at 15:13, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Fri, Feb 22, 2019 at 9:10 AM Thibaut Appel via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>> I reckon that what corresponds best to my situation is to create my own
>>> MPIAIJ matrix, recover the DMDA local to global mapping, preallocate myself
>>> and fill my values with MatSetValues.
>>> However, what is the correct way to
>>> call ISLocalToGlobalMappingGetIndices in Fortran? It seems
>>> there's something missing in the documentation as my code just won't work.
>>> Some examples include a PetscOffset argument which is not present in the
>>> documentation and there is no manual page
>>> for ISLocalToGlobalMappingGetIndicesF90: the only information I could find
>>> is on /src/vec/is/utils/f90-custom/zisltogf90.c. Are you supposed to
>>> allocate the index array yourself? I tried declaring it as a pointer too. I
>>> keep getting an error
>>> 1) There was a bug in that file, but I don't think it should have
>>> affected you. I will put in a PR
>>> 2)  You are supposed to pass in a pointer, unallocated. We manage all
>>> the allocation, which is why you call Restore. What happens when you do
>>> that?
>>>   Thanks,
>>>      Matt
>>> [0]PETSC ERROR: #1 User provided function() line 0 in User file
>>> application called MPI_Abort(MPI_COMM_SELF, -42924) - process 0
>>> Minimal example:
>>> PROGRAM test_dmda
>>> #include <petsc/finclude/petscdm.h>
>>> #include <petsc/finclude/petscdmda.h>
>>>   USE PetscDMDA
>>>   IMPLICIT NONE
>>>   PetscErrorCode :: ierr
>>>   PetscInt       :: irank, icx, icy, lx, ly, n_ltog
>>>   DM             :: da
>>>   PetscInt, DIMENSION(:), ALLOCATABLE :: id_ltog
>>>   !PetscInt, DIMENSION(:), POINTER :: id_ltog
>>>   PetscInt, PARAMETER :: nx=24, ny=9, neq=4
>>>   CHARACTER(LEN=100) :: err_msg
>>>   CALL PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>>   CALL MPI_COMM_RANK(PETSC_COMM_WORLD,irank,ierr)
>>> CALL DMDACreate2D(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,(nx+1),(ny+1), &
>>>   CHKERRA(ierr)
>>>   CHKERRA(ierr)
>>> CALL DMDAGetCorners(da,icx,icy,PETSC_NULL_INTEGER,lx,ly,PETSC_NULL_INTEGER,ierr)
>>>   CHKERRA(ierr)
>>>   WRITE(*,'(*(1X,A,I3))') 'I am process #', irank, ' - my lower left
>>> corner is icx=', icx, &
>>>                           'and icy=', icy, ' - the width is lx=', lx, '
>>> and ly=', ly
>>>   CHKERRA(ierr)
>>>   CALL ISLocalToGlobalMappingGetSize(ltog,n_ltog,ierr)
>>>   CHKERRA(ierr)
>>>   ALLOCATE(id_ltog(1:n_ltog),STAT=ierr,ERRMSG=err_msg)
>>>   CALL ISLocalToGlobalMappingGetIndices(ltog,id_ltog,ierr)
>>>   CHKERRA(ierr)
>>>   CALL ISLocalToGlobalMappingRestoreIndices(ltog,id_ltog,ierr)
>>>   CHKERRA(ierr)
>>>   DEALLOCATE(id_ltog,STAT=ierr,ERRMSG=err_msg)
>>>   CHKERRA(ierr)
>>>   CALL PetscFinalize(ierr)
>>> END PROGRAM test_dmda
>>> On 21/02/2019 17:49, Matthew Knepley wrote:
>>> On Thu, Feb 21, 2019 at 11:16 AM Thibaut Appel via petsc-users <
>>> Dear PETSc developers/users,
>>> I’m solving linear PDEs on a regular grid with high-order finite
>>> differences, assembling an MPIAIJ matrix to solve linear systems or
>>> eigenvalue problems. I’ve been using vertex major, natural ordering for
>>> the parallelism with PetscSplitOwnership (yielding rectangular slices
>>> of the physical domain) and wanted to move to DMDA to have a more
>>> square-ish domain decomposition and minimize communication between
>>> processes.
>>> However, my application is memory critical, and I have finely-tuned
>>> matrix preallocation routines for allocating memory “optimally”. It seems
>>> the memory of a DMDA matrix is allocated along the value of the stencil
>>> width of DMDACreate and the manual says about it
>>> “These DMDA stencils have nothing directly to do with any finite
>>> difference stencils one might chose to use for a discretization”
>>> And despite reading the manual pages there must be something I do not
>>> understand in the DM topology, what is that "stencil width" for then? I
>>> will not use ghost values for my FD-method, right?
>>> What this is saying is, "You might be using some stencil that is not
>>> STAR or BOX, but we are preallocating according to one of those".
>>> If you really care about how much memory is preallocated, which it seems
>>> you do, then you might be able to use
>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDASetBlockFills.html
>>> to tell use exactly how to preallocate.
>>> I was then wondering if I could just create a MPIAIJ matrix, and with a
>>> PETSc routine get the global indices of the domain for each process:
>>> in other words, an equivalent of PetscSplitOwnership that gives me the DMDA
>>> unknown ordering. So I can feed and loop on that in my preallocation and
>>> assembly routines.
>>> You can make an MPIAIJ matrix yourself of course. It should have the
>>> same division of rows as the DMDA division of dofs. Also,
>>> MatSetValuesStencil() will not work for a custom matrix.
>>>   Thanks,
>>>      Matt
>>> Thanks very much,
>>> Thibaut
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190225/e9fe04b6/attachment.html>
