[petsc-users] About DMDA (and extracting its ordering)
Sun Feb 24 17:38:37 CST 2019
On Sun, Feb 24, 2019 at 6:33 PM Appel, Thibaut <t.appel17 at imperial.ac.uk>
wrote:
> Is that for the id_ltog argument? I tried declaring it as IS, and you
> can’t declare an deferred-shape array as target. Same message. XXX(:) is
> syntactic sugar for dimension(:) :: XXX
> I’m really confused because this
> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex14f.F90.html
> doesn’t use the xxxF90 variants of the routines we’re talking about?
You can use the F77 stuff if you want. I thought you needed F90.  For F90,
I think you need to declare it
  PetscInt, pointer :: id_ltog(:)
like it is in the link I sent you.
     Matt
> Thibaut
> On 24 Feb 2019, at 22:50, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Feb 24, 2019 at 4:28 PM Appel, Thibaut <t.appel17 at imperial.ac.uk>
> wrote:
>> Hi Matthew,
>> With the following data declaration and routines calls:
> I am not a Fortran90 expert, but your declaration looks different than the
> ones I have seen work:
> https://bitbucket.org/petsc/petsc/src/master/src/dm/impls/plex/examples/tutorials/ex1f90.F90
>   Thanks,
>      Matt
>>   DM :: da
>>   ISLocalToGlobalMapping :: ltog
>>   PetscInt, DIMENSION(:), POINTER :: id_ltog
>>   CALL
>> DMDACreate2D(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,(nx+1),(ny+1),
>>   PETSC_DECIDE,PETSC_DECIDE,neq,0,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
>>   CHKERRA(ierr)
>>   CALL DMSetUp(da,ierr)
>>   CHKERRA(ierr)
>>   CALL
>> DMDAGetCorners(da,icx,icy,PETSC_NULL_INTEGER,lx,ly,PETSC_NULL_INTEGER,ierr)
>>   CHKERRA(ierr)
>>   CALL DMGetLocalToGlobalMapping(da,ltog,ierr)
>>   CHKERRA(ierr)
>>   CALL ISLocalToGlobalMappingGetIndicesF90(ltog,id_ltog,ierr)
>>   CHKERRA(ierr)
>>   CALL ISLocalToGlobalMappingRestoreIndicesF90(ltog,id_ltog,ierr)
>>   CHKERRA(ierr)
>>   CALL DMDestroy(da,ierr)
>>   CHKERRA(ierr)
>> I get, with the most recent Intel Fortran compiler and a fresh “git pull”
>> PETsc:
>> forrtl: severe (408): fort: (7): Attempt to use pointer ID_LTOG when it
>> is not associated with a target
>> Thibaut
>> On 22 Feb 2019, at 15:13, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Feb 22, 2019 at 9:10 AM Thibaut Appel via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> I reckon that what corresponds best to my situation is to create my own
>> MPIAIJ matrix, recover the DMDA local to global mapping, preallocate myself
>> and fill my values with MatSetValues.
>> However, what is the correct way to call ISLocalToGlobalMappingGetIndices
>> in Fortran? It seems there's something missing in the documentation as my
>> code just won't work.
>> Some examples include a PetscOffset argument which is not present in the
>> documentation and there is no manual page
>> for ISLocalToGlobalMappingGetIndicesF90: the only information I could find
>> is on /src/vec/is/utils/f90-custom/zisltogf90.c. Are you supposed to
>> allocate the index array yourself? I tried declaring it as a pointer too. I
>> keep getting an error
>> 1) There was a bug in that file, but I don't think it should have
>> affected you. I will put in a PR
>> 2)  You are supposed to pass in a pointer, unallocated. We manage all the
>> allocation, which is why you call Restore. What happens when you do that?
>>   Thanks,
>>      Matt
>> [0]PETSC ERROR: #1 User provided function() line 0 in User file
>> application called MPI_Abort(MPI_COMM_SELF, -42924) - process 0
>> Minimal example:
>> PROGRAM test_dmda
>> #include <petsc/finclude/petscdm.h>
>> #include <petsc/finclude/petscdmda.h>
>>   USE PetscDMDA
>>   IMPLICIT NONE
>>   PetscErrorCode :: ierr
>>   PetscInt       :: irank, icx, icy, lx, ly, n_ltog
>>   DM             :: da
>>   PetscInt, DIMENSION(:), ALLOCATABLE :: id_ltog
>>   !PetscInt, DIMENSION(:), POINTER :: id_ltog
>>   PetscInt, PARAMETER :: nx=24, ny=9, neq=4
>>   CHARACTER(LEN=100) :: err_msg
>>   CALL PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>   CALL MPI_COMM_RANK(PETSC_COMM_WORLD,irank,ierr)
>> CALL DMDACreate2D(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,(nx+1),(ny+1), &
>>   CHKERRA(ierr)
>>   CHKERRA(ierr)
>> CALL DMDAGetCorners(da,icx,icy,PETSC_NULL_INTEGER,lx,ly,PETSC_NULL_INTEGER,ierr)
>>   CHKERRA(ierr)
>>   WRITE(*,'(*(1X,A,I3))') 'I am process #', irank, ' - my lower left
>> corner is icx=', icx, &
>>                           'and icy=', icy, ' - the width is lx=', lx, '
>> and ly=', ly
>>   CHKERRA(ierr)
>>   CALL ISLocalToGlobalMappingGetSize(ltog,n_ltog,ierr)
>>   CHKERRA(ierr)
>>   ALLOCATE(id_ltog(1:n_ltog),STAT=ierr,ERRMSG=err_msg)
>>   CALL ISLocalToGlobalMappingGetIndices(ltog,id_ltog,ierr)
>>   CHKERRA(ierr)
>>   CALL ISLocalToGlobalMappingRestoreIndices(ltog,id_ltog,ierr)
>>   CHKERRA(ierr)
>>   DEALLOCATE(id_ltog,STAT=ierr,ERRMSG=err_msg)
>>   CHKERRA(ierr)
>>   CALL PetscFinalize(ierr)
>> END PROGRAM test_dmda
>> On 21/02/2019 17:49, Matthew Knepley wrote:
>> On Thu, Feb 21, 2019 at 11:16 AM Thibaut Appel via petsc-users <
>> Dear PETSc developers/users,
>> I’m solving linear PDEs on a regular grid with high-order finite
>> differences, assembling an MPIAIJ matrix to solve linear systems or
>> eigenvalue problems. I’ve been using vertex major, natural ordering for
>> the parallelism with PetscSplitOwnership (yielding rectangular slices
>> of the physical domain) and wanted to move to DMDA to have a more
>> square-ish domain decomposition and minimize communication between
>> processes.
>> However, my application is memory critical, and I have finely-tuned
>> matrix preallocation routines for allocating memory “optimally”. It seems
>> the memory of a DMDA matrix is allocated along the value of the stencil
>> width of DMDACreate and the manual says about it
>> “These DMDA stencils have nothing directly to do with any finite
>> difference stencils one might chose to use for a discretization”
>> And despite reading the manual pages there must be something I do not
>> understand in the DM topology, what is that "stencil width" for then? I
>> will not use ghost values for my FD-method, right?
>> What this is saying is, "You might be using some stencil that is not STAR
>> or BOX, but we are preallocating according to one of those".
>> If you really care about how much memory is preallocated, which it seems
>> you do, then you might be able to use
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDASetBlockFills.html
>> to tell use exactly how to preallocate.
>> I was then wondering if I could just create a MPIAIJ matrix, and with a
>> PETSc routine get the global indices of the domain for each process:
>> in other words, an equivalent of PetscSplitOwnership that gives me the DMDA
>> unknown ordering. So I can feed and loop on that in my preallocation and
>> assembly routines.
>> You can make an MPIAIJ matrix yourself of course. It should have the same
>> division of rows as the DMDA division of dofs. Also, MatSetValuesStencil()
>> will not work for a custom matrix.
>>   Thanks,
>>      Matt
>> Thanks very much,
>> Thibaut
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190224/71d5961b/attachment.html>
