[petsc-users] About DMDA (and extracting its ordering)
Appel, Thibaut
t.appel17 at imperial.ac.uk
Sun Feb 24 17:33:08 CST 2019
Is that for the id_ltog argument? I tried declaring it as IS, and you can’t declare an deferred-shape array as target. Same message. XXX(:) is syntactic sugar for dimension(:) :: XXX
I’m really confused because this
https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex14f.F90.html
doesn’t use the xxxF90 variants of the routines we’re talking about?
Thibaut
On 24 Feb 2019, at 22:50, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Sun, Feb 24, 2019 at 4:28 PM Appel, Thibaut <t.appel17 at imperial.ac.uk<mailto:t.appel17 at imperial.ac.uk>> wrote:
Hi Matthew,
With the following data declaration and routines calls:
I am not a Fortran90 expert, but your declaration looks different than the ones I have seen work:
https://bitbucket.org/petsc/petsc/src/master/src/dm/impls/plex/examples/tutorials/ex1f90.F90
Matt
DM :: da
ISLocalToGlobalMapping :: ltog
PetscInt, DIMENSION(:), POINTER :: id_ltog
CALL DMDACreate2D(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,(nx+1),(ny+1), &
PETSC_DECIDE,PETSC_DECIDE,neq,0,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da,ierr)
CHKERRA(ierr)
CALL DMSetUp(da,ierr)
CHKERRA(ierr)
CALL DMDAGetCorners(da,icx,icy,PETSC_NULL_INTEGER,lx,ly,PETSC_NULL_INTEGER,ierr)
CHKERRA(ierr)
CALL DMGetLocalToGlobalMapping(da,ltog,ierr)
CHKERRA(ierr)
CALL ISLocalToGlobalMappingGetIndicesF90(ltog,id_ltog,ierr)
CHKERRA(ierr)
CALL ISLocalToGlobalMappingRestoreIndicesF90(ltog,id_ltog,ierr)
CHKERRA(ierr)
CALL DMDestroy(da,ierr)
CHKERRA(ierr)
I get, with the most recent Intel Fortran compiler and a fresh “git pull” PETsc:
forrtl: severe (408): fort: (7): Attempt to use pointer ID_LTOG when it is not associated with a target
Thibaut
On 22 Feb 2019, at 15:13, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Feb 22, 2019 at 9:10 AM Thibaut Appel via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I reckon that what corresponds best to my situation is to create my own MPIAIJ matrix, recover the DMDA local to global mapping, preallocate myself and fill my values with MatSetValues.
However, what is the correct way to call ISLocalToGlobalMappingGetIndices in Fortran? It seems there's something missing in the documentation as my code just won't work.
Some examples include a PetscOffset argument which is not present in the documentation and there is no manual page for ISLocalToGlobalMappingGetIndicesF90: the only information I could find is on /src/vec/is/utils/f90-custom/zisltogf90.c. Are you supposed to allocate the index array yourself? I tried declaring it as a pointer too. I keep getting an error
1) There was a bug in that file, but I don't think it should have affected you. I will put in a PR
2) You are supposed to pass in a pointer, unallocated. We manage all the allocation, which is why you call Restore. What happens when you do that?
Matt
[0]PETSC ERROR: #1 User provided function() line 0 in User file
application called MPI_Abort(MPI_COMM_SELF, -42924) - process 0
Minimal example:
PROGRAM test_dmda
#include <petsc/finclude/petscdm.h>
#include <petsc/finclude/petscdmda.h>
USE PetscDMDA
IMPLICIT NONE
PetscErrorCode :: ierr
PetscInt :: irank, icx, icy, lx, ly, n_ltog
DM :: da
PetscInt, DIMENSION(:), ALLOCATABLE :: id_ltog
!PetscInt, DIMENSION(:), POINTER :: id_ltog
PetscInt, PARAMETER :: nx=24, ny=9, neq=4
CHARACTER(LEN=100) :: err_msg
CALL PetscInitialize(PETSC_NULL_CHARACTER,ierr)
CALL MPI_COMM_RANK(PETSC_COMM_WORLD,irank,ierr)
CHKERRA(ierr)
CHKERRA(ierr)
CHKERRA(ierr)
WRITE(*,'(*(1X,A,I3))') 'I am process #', irank, ' - my lower left corner is icx=', icx, &
'and icy=', icy, ' - the width is lx=', lx, ' and ly=', ly
CHKERRA(ierr)
CALL ISLocalToGlobalMappingGetSize(ltog,n_ltog,ierr)
CHKERRA(ierr)
ALLOCATE(id_ltog(1:n_ltog),STAT=ierr,ERRMSG=err_msg)
CALL ISLocalToGlobalMappingGetIndices(ltog,id_ltog,ierr)
CHKERRA(ierr)
CALL ISLocalToGlobalMappingRestoreIndices(ltog,id_ltog,ierr)
CHKERRA(ierr)
DEALLOCATE(id_ltog,STAT=ierr,ERRMSG=err_msg)
CHKERRA(ierr)
CALL PetscFinalize(ierr)
END PROGRAM test_dmda
On 21/02/2019 17:49, Matthew Knepley wrote:
On Thu, Feb 21, 2019 at 11:16 AM Thibaut Appel via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear PETSc developers/users,
I’m solving linear PDEs on a regular grid with high-order finite differences, assembling an MPIAIJ matrix to solve linear systems or eigenvalue problems. I’ve been using vertex major, natural ordering for the parallelism with PetscSplitOwnership (yielding rectangular slices of the physical domain) and wanted to move to DMDA to have a more square-ish domain decomposition and minimize communication between processes.
However, my application is memory critical, and I have finely-tuned matrix preallocation routines for allocating memory “optimally”. It seems the memory of a DMDA matrix is allocated along the value of the stencil width of DMDACreate and the manual says about it
“These DMDA stencils have nothing directly to do with any finite difference stencils one might chose to use for a discretization”
And despite reading the manual pages there must be something I do not understand in the DM topology, what is that "stencil width" for then? I will not use ghost values for my FD-method, right?
What this is saying is, "You might be using some stencil that is not STAR or BOX, but we are preallocating according to one of those".
If you really care about how much memory is preallocated, which it seems you do, then you might be able to use
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDASetBlockFills.html
to tell use exactly how to preallocate.
I was then wondering if I could just create a MPIAIJ matrix, and with a PETSc routine get the global indices of the domain for each process: in other words, an equivalent of PetscSplitOwnership that gives me the DMDA unknown ordering. So I can feed and loop on that in my preallocation and assembly routines.
You can make an MPIAIJ matrix yourself of course. It should have the same division of rows as the DMDA division of dofs. Also, MatSetValuesStencil() will not work for a custom matrix.
Matt
Thanks very much,
Thibaut
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/
-- Norbert Wiener
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190224/71e4b819/attachment-0001.html>
