[petsc-users] PCMGSetGalerkin() new inputs
Myriam Peyrounette myriam.peyrounette at idris.fr
Wed Feb 20 08:08:37 CST 2019
I am currently comparing two codes based on PETSc. The first one uses
PETSC 3.6.4 and the other one PETSc 3.10.2.
I am having a look at the use of the function PCMGSetGalerkin(). With
PETSc 3.6, the input is a boolean, while it is either
PC_MG_GALERKIN_MAT, PC_MG_GALERKIN_PMAT or PC_MG_GALERKIN_BOTH with PETSc 3.10.
Which one of these new inputs should I use to have the same
configuration as with PETSc 3.6?
Thanks in advance,
Myriam Peyrounette
CNRS/IDRIS - HLST
Type: application/pkcs7-signature
Desc: Signature cryptographique S/MIME
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190220/de54fc02/attachment.p7s>
