[petsc-users] Identifying matching points in differently distributed DMPlexs
Matthew Knepley
knepley at gmail.com
Tue Feb 19 15:30:16 CST 2019
On Tue, Feb 19, 2019 at 11:00 AM Lawrence Mitchell via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear petsc-users,
> I have two (different) distributions of the (topologically) same DMPlex
> object (DM_a and DM_b).
> I would like to identify the map from points(DM_a) to points(DM_b) such
> that I can transfer fields between the two.
> Does such a facility exist?
Case #1: You made DM_b from DM_a
Then you are fine. The PetscSF you get from Distribute() is the map.
Case #2: They are completely unconnected
This is hard. I wrote code to do it at least twice, but I keep throwing
it away when I rewrite things because
it is so ugly. Hopefully you do not need this.
Matt
> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190219/7f31305d/attachment.html>
