[petsc-users] Problem in loading Matrix Market format
Matthew Knepley
knepley at gmail.com
Tue Feb 12 09:46:37 CST 2019
Hi Junchao,
Could you fix the MM example in PETSc to have this full support? That way
we will always have it.
Matt
On Tue, Feb 12, 2019 at 10:27 AM Zhang, Junchao via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Eda,
> I have a code that can read in Matrix Market and write out PETSc binary
> files. Usage: mpirun -n 1 ./mm2petsc -fin <infile> -fout <outfile>. You
> can have a try.
> --Junchao Zhang
> On Tue, Feb 12, 2019 at 1:50 AM Eda Oktay via petsc-users <
>> Hello,
>> I am trying to load matrix in Matrix Market format. I found an example on
>> mat file (ex78) whih can be tested by using .dat file. Since .dat file and
>> .mtx file are similar in structure (specially afiro_A.dat file is similar
>> to amesos2_test_mat0.mtx since they both have 3 columns and the columns
>> represent the same properties), I tried to run ex78 by using
>> amesos2_test_mat0.mtx instead of afiro_A.dat. However, I got the error
>> "Badly formatted input file". Here is the full error message:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Badly formatted input file
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
>> [0]PETSC ERROR: ./ex78 on a arch-linux2-c-debug named
>> 7330.wls.metu.edu.tr by edaoktay Tue Feb 12 10:47:58 2019
>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
>> --download-metis --download-parmetis --download-superlu_dist
>> --download-slepc --download-mpich
>> [0]PETSC ERROR: #1 main() line 73 in
>> /home/edaoktay/petsc-3.10.3/src/mat/examples/tests/ex78.c
>> [0]PETSC ERROR: PETSc Option Table entries:
>> [0]PETSC ERROR: -Ain
>> /home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/amesos2_test_mat0.mtx
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1
>> system msg for write_line failure : Bad file descriptor
>> I know there is also an example (ex72) for Matrix Market format but in
>> description, it is only proper for symmmetric and lower triangle, so I
>> decided to use ex78.
>> Best regards,
>> Eda
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190212/14f4ad7d/attachment.html>
