[petsc-users] Problem in loading Matrix Market format
Zhang, Junchao
jczhang at mcs.anl.gov
Tue Feb 12 09:26:53 CST 2019
Eda,
I have a code that can read in Matrix Market and write out PETSc binary files. Usage: mpirun -n 1 ./mm2petsc -fin <infile> -fout <outfile>. You can have a try.
--Junchao Zhang
On Tue, Feb 12, 2019 at 1:50 AM Eda Oktay via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I am trying to load matrix in Matrix Market format. I found an example on mat file (ex78) whih can be tested by using .dat file. Since .dat file and .mtx file are similar in structure (specially afiro_A.dat file is similar to amesos2_test_mat0.mtx since they both have 3 columns and the columns represent the same properties), I tried to run ex78 by using amesos2_test_mat0.mtx instead of afiro_A.dat. However, I got the error "Badly formatted input file". Here is the full error message:
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Badly formatted input file
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
[0]PETSC ERROR: ./ex78 on a arch-linux2-c-debug named 7330.wls.metu.edu.tr<http://7330.wls.metu.edu.tr> by edaoktay Tue Feb 12 10:47:58 2019
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas --download-metis --download-parmetis --download-superlu_dist --download-slepc --download-mpich
[0]PETSC ERROR: #1 main() line 73 in /home/edaoktay/petsc-3.10.3/src/mat/examples/tests/ex78.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -Ain /home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/amesos2_test_mat0.mtx
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1
system msg for write_line failure : Bad file descriptor
I know there is also an example (ex72) for Matrix Market format but in description, it is only proper for symmmetric and lower triangle, so I decided to use ex78.
Best regards,
Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190212/b1c8697a/attachment-0001.html>
Type: application/gzip
Desc: matrixmarket2petsc.tgz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190212/b1c8697a/attachment-0001.bin>
