[petsc-users] Noncomforming object sizes error in MatEqual
Eda Oktay eda.oktay at metu.edu.tr
Wed Dec 18 05:42:15 CST 2019
Hi all,
I solved the problem by using different routine.
Thanks anyway!
Eda
Eda Oktay <eda.oktay at metu.edu.tr>, 18 Ara 2019 Çar, 10:24 tarihinde şunu
yazdı:
> Hello everyone,
> In a part of my code, I am trying to understand whether a matrix is equal
> to its transpose, that is why I am using MatEqual(). However, for most of
> the matrices I took from University of Florida State Sparse Matrix Library,
> I get the following error for more than 2 processes, where main() line 155
> is MatEqual:
> [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Nonconforming object sizes
> [2]PETSC ERROR: Mat A,Mat B: global dim 6 6 8 5
> [2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [2]PETSC ERROR: Petsc Release Version 3.11.1, Apr, 12, 2019
> [2]PETSC ERROR: ./yeni_vertexweight_imbalance_without_spectral on a
> arch-linux2-c-debug named d1e.wls.metu.edu.tr by edaoktay Wed Dec 18
> 10:18:30 2019
> [2]PETSC ERROR: Configure options --download-mpich --download-openblas
> --download-slepc --download-metis --download-parmetis --download-chaco
> --with-X=1
> [2]PETSC ERROR: #1 MatEqual() line 5130 in
> /home/edaoktay/petsc-3.11.1/src/mat/interface/matrix.c
> [2]PETSC ERROR: #2 MatEqual_MPIAIJ() line 2112 in
> /home/edaoktay/petsc-3.11.1/src/mat/impls/aij/mpi/mpiaij.c
> [2]PETSC ERROR: #3 MatEqual() line 5136 in
> [2]PETSC ERROR: #4 main() line 115 in
> /home/edaoktay/petsc-3.11.1/arch-linux2-c-debug/share/slepc/examples/src/eda/yeni_vertexweight_imbalance_without_spectral.c
> [2]PETSC ERROR: PETSc Option Table entries:
> [2]PETSC ERROR: -f
> /home/edaoktay/petsc-3.11.1/share/petsc/datafiles/matrices/binary_files/Ragusa16_binary
> [2]PETSC ERROR: -mat_partitioning_type parmetis
> [2]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> And this is the part of my code:
>   ierr = PetscInitialize(&argc,&argv,(char*)0,help);if (ierr) return ierr;
>      Determine files from which we read matrix
>   ierr =
> PetscOptionsGetString(NULL,NULL,"-f",file,PETSC_MAX_PATH_LEN,&flg);CHKERRQ(ierr);
>   if (!flg) SETERRQ(PETSC_COMM_WORLD,1,"Must indicate binary file with the
> -f option");
>      Open binary file.  Note that we use FILE_MODE_READ to indicate
>      reading from this file.
>   ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,file,FILE_MODE_READ,&fd);CHKERRQ(ierr);
>     Load the matrix; then destroy the viewer.
>   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>   ierr = MatSetOptionsPrefix(A,"a_");CHKERRQ(ierr);
>   ierr = MatSetFromOptions(A);CHKERRQ(ierr);
>   ierr = MatLoad(A,fd);CHKERRQ(ierr);
>   ierr = PetscViewerDestroy(&fd);CHKERRQ(ierr);
>  /* PetscLogDouble v1,v2,elapsed_time;
>   PetscTime(&v1);   */
>                     Create Partitioning
>   ierr = MatConvert(A,MATMPIADJ,MAT_INITIAL_MATRIX,&AL);CHKERRQ(ierr);
>   ierr = MatPartitioningCreate(MPI_COMM_WORLD,&part);CHKERRQ(ierr);
>   ierr = MatPartitioningSetAdjacency(part,AL);CHKERRQ(ierr);
>       /* Symmetry check */
>       Mat Atr,SymmA,Atrabs,Aabs;
>       PetscBool isEqual;
>       Vec D;
>       PetscInt i;
>     ierr = MatTranspose(A,MAT_INITIAL_MATRIX,&Atr);CHKERRQ(ierr);
>     ierr = MatDuplicate(Atr,MAT_COPY_VALUES,&SymmA);CHKERRQ(ierr);
>     flg = PETSC_TRUE;
>     PetscOptionsGetBool(NULL,NULL, "-check_symmetry", &flg,NULL);
>     if (flg) {
>         ierr = MatEqual(A,Atr,&isEqual);CHKERRQ(ierr);
> For this specific error, the matrix is of size 24*24. When I checked, I
> couldn't understand what is wrong when it comes to 3rd process. I will be
> glad if someone can tell me what is wrong with my code that I get this
> dimension error.
> Thanks,
> Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191218/86441376/attachment.html>
