[petsc-users] Strange Memory Increase in PCHYPRE BOOMERAMG
Mohammed Mostafa
mo7ammedmostafa at gmail.com
Wed Dec 18 01:32:24 CST 2019
Hello everyone,
I seem to have a problem of increasing memory size with the linear solver.
I double check every single part of my code and I isolated the problem to
KSPSolve command.
A bit of context/background regarding my algorithm.
I am writing a finite volume numerical solver for incompressible two phase
flow. I am mainly solving liquid sloshing and waves impact problems. Until
recently most of simulations were 2D with max cell count of 100K cells but
now I am considering solving 3D problems with cell counts between 6M~10M
cells.
The algorithm is as follows:
setup ksp
setup pc
loop 1 → number of timesteps
1- // do some work
2- create the pressure poisson matrix
3 – loop: iloop 1 to 4
4-1- solve the matrix if ( iloop == 1) update the precond
4-2- // do some work
4-3- update rhs(no matrix or precond update)
4- do the next timestep and go back to step 1
*From many online posts many people recommended KSPCG with PCHYPRE with the
following options*
// PC Setup
PCCreate(PETSC_COMM_WORLD, &preconditioner);
PCSetType(preconditioner, PCHYPRE);
PCHYPRESetType(preconditioner, "boomeramg");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_strong_threshold", "0.4");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_agg_nl", "3");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_agg_num_paths", "4");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_interp_type", "ext+i");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_truncfactor", "0.3");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_max_iter", "1");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_relax_type_all",
"SOR/Jacobi");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_grid_sweeps_down", "1");
PetscOptionsSetValue(NULL, "-pc_hypre_boomeramg_rtol", "0");
KSPSetPC(iterSolver, preconditioner);
KSPSetOperators(iterSolver, A, A);
// KSP Setup
KSPSetType(iterSolver, KSPCG);
KSPSetInitialGuessNonzero(iterSolver, PETSC_TRUE);
KSPSetNormType(iterSolver, KSP_NORM_UNPRECONDITIONED);
KSPSetFromOptions(iterSolver);
PCSetUp(preconditioner);
KSPSetUp(iterSolver);
KSPSetTolerances(iterSolver, 1e-18 /*reltol*/, 1e-12 /*abstol*/,
1e5 /*divergencetol*/, 50);
*When solving the linear system for the first time during the timestep
(iloop =1), the following commands are used so that the preconditioner is
reconstructed based on the new matrix values.*
KSPSetReusePreconditioner(iterSolver, PETSC_FALSE);
KSPSetOperators(iterSolver, A, A); // set the new matrix
KSPSolve(iterSolver, *RHS, *x);
*Otherwise*
KSPSetReusePreconditioner(iterSolver, PETSC_TRUE);
*It should be noted that matrix non-zero structure remains the same
throught the simulation but the values change every timestep.*
Now My problem is that memory size keep changing throught the simulation
utill my workstation evetually runs out of memory.
I tracked down the memory increase to the step which solve the linear
system of equations.
* KSPSetReusePreconditioner(iterSolver, PETSC_FALSE);*
* KSPSetOperators(iterSolver, A, A); // set the new matrix*
* KSPSolve(iterSolver, *RHS, *x);*
My current problem is a sloshing problem with cell count of 1.2M cells
running on workstation with 40 Cores and 94GB of RAM.
The memory increase I observed did not occur every single time step but
more like every 3-10 time step. The increase each time is somewhere from
0.51MB~3.0MB per mpi process and not not all process show memory change.
For example in time step id 14 , proc0, proc6, proc13, proc24 show change
but the others don’t. On average 10~15 processes show memory change while
the others do not.
Over 1000 time steps the solver use up additional 10GB of memory and still
increasing until the system runs out of memory after nearly 10K time steps.
I wanted to try another preconditioner PCJACOBI which ultimately failed due
to max number of iterations but at least no memory change was observed over
50 time steps.
Since I am using multigrid I expected the increase in memory required by
the linear solver, I just assumed that after enough number of timesteps it
would settle on some value. But it just kept increasing util finally the
system ran out of memory.
I monitored the memory usage of other parts/components of the code and no
memory change occurs at all except at code section above.
I configure PETSC with following options
PETSC_ARCH=release3 -with-debugging=0 COPTFLAGS="-O3 -march=native
-mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
-march=native -mtune=native" --with-cc=mpicc --w
ith-cxx=mpicxx --with-fc=mpif90 --download-metis --download-hypre
I tried configuring it in debug and compiling my code also in debug mode
and running as the FAQ suggests but the code ended up being too slow so I
shut it down after running it for 50mins and not even one timestep was
completed.
So to track down the memory leak/increase I used
PetscMemoryGetCurrentUsage(&mem1);
// some code
PetscMemoryGetCurrentUsage(&mem2);
memChnge = mem2 – mem1;
I believe it could be one of the following possibilities:
1.
A memory leak (bug) in the petsc library ( unlikely otherwise someone
would have found it by now )
2.
Some thing to do with setting of the boomerAMG Hypre preconditioner
which makes it unnecessarily add additional levels. The settings I am
using, I got from an online post I found so I don’t really understand it.
https://mooseframework.inl.gov/application_development/hypre.html
3.
Some problem with the sequence of commands I am using for the solution
of linear system of eqns that makes allocate additional memory with freeing
the old one.
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191218/332fba8f/attachment-0001.html>
