[petsc-users] Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Balay, Satish balay at mcs.anl.gov
Tue Dec 17 10:51:16 CST 2019
The recommendation is to use --with-batch=1  if there is working mpiexec
Note: the option is --with-mpiexec="mpirun" where "mpirun" would work with "mpirun -n 1 ./binary"
Satish
On Tue, 17 Dec 2019, Fande Kong wrote:
> Are you able to run your MPI code using " mpiexec_mpt -n 1 ./yourbinary"?
> You need to use --with-mpiexec to specify what exactly command lines you
> can run, e.g., --with-mpiexec="mpirun -n 1".
> I am also CCing the email to PETSc guys who may know the answer to these
> questions.
> Thanks,
> Fande,
> On Mon, Dec 16, 2019 at 3:52 PM Tomas Mondragon <
> tom.alex.mondragon at gmail.com> wrote:
> > I have attached the configure.log file from when I ran
> > update_and_rebuild_petsc.sh on both machines. In the log from jim is from
> > an attempt to rebuild after adding --with-mpiexec=mpiexec_mpt to the call
> > to pets/configure in the update and rebuild script
> > You received this message because you are subscribed to the Google Groups
> > "moose-users" group.
> > To unsubscribe from this group and stop receiving emails from it, send an
> > email to moose-users+unsubscribe at googlegroups.com.
> > To view this discussion on the web visit
> > https://groups.google.com/d/msgid/moose-users/edd3a169-5012-4e46-a060-5088a199603c%40googlegroups.com
> > <https://groups.google.com/d/msgid/moose-users/edd3a169-5012-4e46-a060-5088a199603c%40googlegroups.com?utm_medium=email&utm_source=footer>
