[petsc-users] Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Fande Kong
fdkong.jd at gmail.com
Tue Dec 17 10:11:05 CST 2019
Are you able to run your MPI code using " mpiexec_mpt -n 1 ./yourbinary"?
You need to use --with-mpiexec to specify what exactly command lines you
can run, e.g., --with-mpiexec="mpirun -n 1".
I am also CCing the email to PETSc guys who may know the answer to these
questions.
Fande,
On Mon, Dec 16, 2019 at 3:52 PM Tomas Mondragon <
tom.alex.mondragon at gmail.com> wrote:
> I have attached the configure.log file from when I ran
> update_and_rebuild_petsc.sh on both machines. In the log from jim is from
> an attempt to rebuild after adding --with-mpiexec=mpiexec_mpt to the call
> to pets/configure in the update and rebuild script
> You received this message because you are subscribed to the Google Groups
> "moose-users" group.
> To unsubscribe from this group and stop receiving emails from it, send an
> email to moose-users+unsubscribe at googlegroups.com.
> To view this discussion on the web visit
> https://groups.google.com/d/msgid/moose-users/edd3a169-5012-4e46-a060-5088a199603c%40googlegroups.com
> <https://groups.google.com/d/msgid/moose-users/edd3a169-5012-4e46-a060-5088a199603c%40googlegroups.com?utm_medium=email&utm_source=footer>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191217/7d8b07ff/attachment.html>
