[petsc-users] win32fe icl won't work
Sam Guo
sam.guo at cd-adapco.com
Mon Dec 16 18:41:08 CST 2019
Thanks for the quick response. I attach the configure.log again.
icl is found
$ icl
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64,
Version 18.0.3.210 Build 20180410
Copyright (C) 1985-2018 Intel Corporation. All rights reserved.
icl: command line error: no files specified; for help type "icl /help"
On Mon, Dec 16, 2019 at 7:03 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> The attached configure.log is a link file. Can you resend the log from
> PETSC_ARCH/lib/petsc/conf
> Also can you verify that you followed instructions from
> https://www.mcs.anl.gov/petsc/documentation/installation.html#windows
> [its not explicitly specified - but you need to run the correct cmd that
> sets up Intel compiler - instead of the MS compiler]
> i.e verify 'icl' works from cygwin/bash - before attempting configure.
> Satish
> On Mon, 16 Dec 2019, Sam Guo wrote:
> > Dear PETSc dev team,
> > I tried to compile petsc using intel compiler win32fe icl on cygwin
> but
> > encountered error. By the way, I am able to compile using visual studio
> > compiler win32fe cl.
> > Configuring PETSc to compile on your system
> > Warning: "with-clean" is specified. Removing all build files from
> arch-starccmplus_s===============================================================================
> > TESTING: checkCCompiler from
> config.setCompilers(config/BuildSystem/config/setCompilers.py*******************************************************************************
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > details):
> > C compiler you provided with -with-cc=win32fe icl does not work.
> > Cannot compile/link C with
> > /home/xianzhongg/dev/star/petsc/lib/petsc/bin/win32fe/win32fe icl.
> > BR,
> > Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191216/472b2abe/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191216/472b2abe/attachment-0001.obj>
