[petsc-users] MatGetDiagonal
hg hgbk2008 at gmail.com
Mon Dec 9 09:55:40 CST 2019
I think the manual is also insufficient in this case. The vector must be
VECMPI and contains only the portion in the local process. Is that correct?
Giang
On Wed, Jan 23, 2013 at 5:24 PM Nachiket Gokhale <gokhalen at gmail.com> wrote:
> Thanks, I guess I misinterpreted the manual.
> -Nachiket
> On Wed, Jan 23, 2013 at 11:20 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > It works in serial. In parallel, it currently gives the diagonal of the
> > "diagonal blocks" induced by the row and column distributions. That only
> > matches the true diagonal for square matrices, though an actual diagonal
> > doesn't typically make algorithmic sense for a non-square parallel
> matrix.
> > On Wed, Jan 23, 2013 at 10:16 AM, Nachiket Gokhale <gokhalen at gmail.com>
> > wrote:
> >> Any chance of making this work in serial?
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetDiagonal.html
> >> Not a show stopper, I am trying to get the diagonal  of some small
> >> projected, dense matrices (which come from large sparse matrices).  I
> >> am running in serial because 1) Since my projected matrices are small,
> >> and 2) PETSc does not do certain matrix multiplications involving a
> >> dense matrix in parallel,
> >> -Nachiket
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191209/5c0ca82c/attachment.html>
