[petsc-users] petsc under cygwin
Povolotskyi, Mykhailo mpovolot at purdue.edu
Fri Dec 6 09:28:14 CST 2019
Hi Satish,
I looked into cygwin mail list
https://sourceware.org/ml/cygwin/2018-08/msg00349.html
It seem that they have removed something, so probably -lmpi_cxx is not
needed, but it keeps looking for it.
Michael.
On 12/6/2019 9:04 AM, Balay, Satish wrote:
> Its likely my cygwin is slightly old [as its not updated in the past few months].
> balay at ps5 ~/petsc
> $ cygcheck.exe -f /usr/bin/mpicxx
> openmpi-3.1.3-1
> Satish
> On Fri, 6 Dec 2019, Balay, Satish wrote:
>> Are you sure this is cygwin from OpenMPI? I don't see it refer to -lmpi_cxx
>> $ which mpicxx
>> /usr/bin/mpicxx
>> $ mpicxx -show
>> g++ -L/usr/lib -lmpi -lopen-rte -lopen-pal -lm -lgdi32 -lz
>> Here is what I get with cygwin/openmpi,lapack,blas
>> Satish
>> $ ./configure --with-scalar-type=real --with-x=0 --with-hdf5 --download-hdf5=1 --with-single-library=1 --with-shared-libraries=0 --with-log=0 --with-clanguage=C++ --with-cxx-d
>> ialect=C++11 --CXXFLAGS="-fopenmp -fPIC" --CFLAGS="-fopenmp -fPIC" --with-fortran=0 --FFLAGS="-fopenmp -fPIC" --with-64-bit-indices=0 --with-debugging=0 --with-cc=mpicc --with
>> -fc=mpif77 --with-cxx=mpicxx COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 --with-fortran-kernels=0
>>               Configuring PETSc to compile on your system
>> ===============================================================================        WARNING -with-clanguage=C++ is a developer feature and is *not* required for regular usage of PETSc either from C or C++                                                  ===============================================================================        ===============================================================================        Trying to download git://https://bitbucket.org/petsc/pkg-sowing.git for SOWING        ===============================================================================        ===============================================================================        Running configure on SOWING; this may take several minutes        ===============================================================================        ===============================================================================        Running make on SOWING; this may take several minutes        ===============================================================================        ===============================================================================        Running make install on SOWING; this may take several minutes        ===============================================================================        ===============================================================================        Trying to download https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.10/hdf5-1.10.5/src/hdf5-1.10.5.tar.gz for HDF5                                                   ===============================================================================        ===============================================================================        Running configure on HDF5; this may take several minutes        ===============================================================================        ===============================================================================        Running make on HDF5; this may take several minutes        ===============================================================================        ===============================================================================        Running make install on HDF5; this may take several minutes        ===============================================================================        Compilers:
>>    C Compiler:         mpicc -fopenmp -fPIC -O3
>>      Version: gcc (GCC) 7.4.0
>>    C++ Compiler:       mpicxx -fopenmp -fPIC -O3
>>      Version: g++ (GCC) 7.4.0
>>    Fortran Compiler:   mpif77 -fopenmp -fPIC -O3
>>      Version: GNU Fortran (GCC) 7.4.0
>> Linkers:
>>    Static linker:   /usr/bin/ar cr
>>    Dynamic linker:   /usr/bin/ar
>>    Libraries linked against:   -lgdi32 -luser32 -ladvapi32 -lkernel32 -lquadmath -lstdc++ -ldl
>> make:
>>    Version:  4.2
>>    /usr/bin/make
>> BlasLapack:
>>    Library:  -llapack -lblas
>>    uses 4 byte integers
>> MPI:
>>    Version:  3
>>    Mpiexec: mpiexec --oversubscribe
>>    OMPI_VERSION: 3.1.3
>> pthread:
>> hdf5:
>>    Version:  1.10.5
>>    Includes: -I/home/balay/petsc/arch-mswin-cxx-opt/include
>>    Library:  -Wl,-rpath,/home/balay/petsc/arch-mswin-cxx-opt/lib -L/home/balay/petsc/arch-mswin-cxx-opt/lib -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5
>> cmake:
>>    Version:  3.14.5
>>    /usr/bin/cmake
>> sowing:
>>    Version:  1.1.25
>>    /home/balay/petsc/arch-mswin-cxx-opt/bin/bfort
>>    Language used to compile PETSc: Cxx
>> PETSc:
>>    PETSC_ARCH: arch-mswin-cxx-opt
>>    PETSC_DIR: /home/balay/petsc
>>    Scalar type: real
>>    Precision: double
>>    Support for __float128
>>    Integer size: 4 bytes
>>    shared libraries: disabled
>>    Memory alignment from malloc(): 16 bytes
>> xxx=========================================================================xxx
>>   Configure stage complete. Now build PETSc libraries with:
>>     make PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-mswin-cxx-opt all
>> On Fri, 6 Dec 2019, Povolotskyi, Mykhailo wrote:
>>> I checked:
>>> I cannot build C++ programs with MPI, but I can build and run C programs
>>> with MPI.
>>> I have -with-log=0 because there is an overhead if many small objects
>>> are created, which is my case.
>>> As for the fortran, I will remove  --with-fortran=0
>>> On 12/5/2019 11:53 PM, Smith, Barry F. wrote:
>>>>     Can you actually build and run C++ programs with the MPI?
>>>> Executing: mpicxx  -o /tmp/petsc-Llvze6/config.setCompilers/conftest.exe   -fopenmp -fPIC /tmp/petsc-Llvze6/config.setCompilers/conftest.o
>>>> Possible ERROR while running linker: exit code 1
>>>> stderr:
>>>> /usr/lib/gcc/x86_64-pc-cygwin/7.4.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lmpi_cxx
>>>> collect2: error: ld returned 1 exit status
>>>>             Error testing C++ compiler: Cannot compile/link Cxx with mpicxx.
>>>>               MPI installation mpicxx is likely incorrect.
>>>>     Use --with-mpi-dir to indicate an alternate MPI.
>>>> Also you have  --with-fortran=0
>>>> but --download-fblaslapack  and FOPTFLAGS=-O3
>>>> and why do you have --with-log=0   it costs no overhead if you do not use it and is always useful for tracking performance.
>>>>     Barry
>>>>> On Dec 5, 2019, at 9:19 PM, Povolotskyi, Mykhailo <mpovolot at purdue.edu> wrote:
>>>>> Dear Petsc support team,
>>>>> for some reasons I have to build petsc under Windows.
>>>>> I have installed Cygwin with GNU compilers and OpenMPI.
>>>>> Unfortunately, the configuration fails with the following message:
>>>>> TESTING: checkCxxCompiler from
>>>>> config.setCompilers(config/BuildSystem/config/setCompilers.py:814)
>>>>>            UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>>>> for details):
>>>>> C++ compiler you provided with -with-cxx=mpicxx does not work.
>>>>> I'm attaching the *.log file.
>>>>> Please advise,
>>>>> Michael.
>>>>> <configure.log>
