[petsc-users] petsc under cygwin
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Thu Dec  5 22:53:14 CST 2019
  Can you actually build and run C++ programs with the MPI?
Executing: mpicxx  -o /tmp/petsc-Llvze6/config.setCompilers/conftest.exe   -fopenmp -fPIC /tmp/petsc-Llvze6/config.setCompilers/conftest.o
Possible ERROR while running linker: exit code 1
stderr:
/usr/lib/gcc/x86_64-pc-cygwin/7.4.0/../../../../x86_64-pc-cygwin/bin/ld: cannot find -lmpi_cxx
collect2: error: ld returned 1 exit status
          Error testing C++ compiler: Cannot compile/link Cxx with mpicxx.
            MPI installation mpicxx is likely incorrect.
  Use --with-mpi-dir to indicate an alternate MPI.
Also you have  --with-fortran=0
but --download-fblaslapack  and FOPTFLAGS=-O3
and why do you have --with-log=0   it costs no overhead if you do not use it and is always useful for tracking performance.
  Barry
> On Dec 5, 2019, at 9:19 PM, Povolotskyi, Mykhailo <mpovolot at purdue.edu> wrote:
> Dear Petsc support team,
> for some reasons I have to build petsc under Windows.
> I have installed Cygwin with GNU compilers and OpenMPI.
> Unfortunately, the configuration fails with the following message:
> TESTING: checkCxxCompiler from
> config.setCompilers(config/BuildSystem/config/setCompilers.py:814)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> C++ compiler you provided with -with-cxx=mpicxx does not work.
> I'm attaching the *.log file.
> Please advise,
> Michael.
> <configure.log>
