[petsc-users] Updating TS solution outside PETSc
Jed Brown
jed at jedbrown.org
Thu Dec 5 13:47:03 CST 2019
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> Let's look at the 1d case with vertex centered differencing
> u-1* u0 u1 ...
> u-1* is the ghost value, u0 the edge value etc.
> Say you are solving u_n on boundary is g(t), u inside satisfies u_t = U_xx
> Then if you provide a function of TSSetRHSFunction() it would be something like
> DMGetLocalVector(DM,&ulocal);
> DMGlobalToLocal(dm, U, ulocal) ;
> DMDAGetArray(ulocal,&u)
> DMDAGetArray(fglobal,&f)
> for (i=0,....
> f[i] = (u[i+1] - 2*u[i] + u[i-1])/h
> f[0] += g(t)
> Note that f[0] = (u[i+1] - 2*u[i] + u[i-1])/h^2 = (u[1] - u[0])/h + g(t)
Better to reflect with bias, e.g.,
u[-1] = u[1] + 2*h*g(t)
and apply the standard differencing rule. Note that f[0] means
u_t[0] = f[0]
so you can't drop factors of h, etc.,
> So you are satisfying the PDE inside the domain and on the boundary you are using one-sided differencing to approximate the Neumann boundary conditions.
Only by accident in a sense is a one-sided differencing. Yes, it
reduces to some one-sided formula once you eliminate the ghost points,
but the interpretation is less clear when using higher order methods,
non-uniform spacing, or upwinding in the volumetric discretization.
