[petsc-users] Could not find a CXX preprocessor on Catalina
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Dec 5 02:32:24 CST 2019
Hmm, MPICH and OpenMPI have also passed this info in there compilers; perhaps this is a newer version clang that no longer tolerates these options
I think we need to strip out those options as a guess
> On Dec 4, 2019, at 2:18 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
> Yes - this is a link time option - and somehow your build of mpich is
> using at compile/preprocess time.
> You can try rebuilding this mpich - or use --download-mpich with petsc configure
> Satish
> On Wed, 4 Dec 2019, Alexander Lindsay wrote:
>> Is this regarded as failing just because of the unused option warning? The
>> `mpicxx` wrapper specifies `-Wl,-flat_namespace` which is indeed going to
>> be unused during preprocessing...
>> On Wed, Dec 4, 2019 at 11:40 AM Alexander Lindsay <alexlindsay239 at gmail.com>
>> wrote:
>>> I'm currently unable to build superlu_dist during configuration because of
>>> "Could not find a CXX preprocessor". From configure.log it looks like CXXPP
>>> is getting deleted after errors executing `mpicxx -E` and then `mpicxx
>>> --use cpp32`. Attached is configure.log.
