[petsc-users] (no subject)
Li Luo
li.luo at kaust.edu.sa
Mon Dec 2 06:30:54 CST 2019
Thank you very much! It looks forming an analytic Jacobian is the only
choice.
Best,
Li
On Mon, Dec 2, 2019 at 3:21 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 2, 2019 at 4:04 AM Li Luo <li.luo at kaust.edu.sa> wrote:
>> Thank you for your reply.
>> The matrix is small with only 67500 rows, but is relatively dense since a
>> second-order discontinuous Galerkin FEM is used, nonzeros=23,036,400.
> This is very dense, 0.5% fill or 340 nonzeros per row.
>> The number of colors is 539 as shown by using -mat_fd_coloring_view:
> Coloring is not appropriate for this matrix since you have enormous dense
> blocks (I am guessing). It could work if you statically
> condense them out or had a fast analytic Jacobian. With 540 colors, it
> takes 540 matvecs to generate the action of the Jacobian.
> Thanks,
> Matt
>> MatFDColoring Object: 64 MPI processes
>> type not yet set
>> Error tolerance=1.49012e-08
>> Umin=1.49012e-06
>> Number of colors=539
>> Information for color 0
>> Number of columns 1
>> 378
>> Number of rows 756
>> 0 1188
>> 1 1188
>> 2 1188
>> 3 1188
>> 4 1188
>> 5 1188
>> Is this normal?
>> When using MCFD, is there any difference using mpiaij and mpibaij?
>> Best,
>> Li
>> On Mon, Dec 2, 2019 at 10:03 AM Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>> How many colors is it requiring? And how long is the
>>> MatGetColoring() taking? Are you running in parallel? The MatGetColoring()
>>> MATCOLORINGSL uses a sequential coloring algorithm so if your matrix is
>>> large and parallel the coloring will take a long time. The parallel
>>> colorings are MATCOLORINGGREEDY and MATCOLORINGJP
>>> Barry
>>> > On Dec 1, 2019, at 12:56 AM, Li Luo <li.luo at kaust.edu.sa> wrote:
>>> > Dear Developers,
>>> > I tried to use the multi-color finite-difference (MC-FD) method for
>>> constructing the Jacobians. However, I find it is very slow compared to the
>>> exact Jacobian.
>>> > My implementation of MC-FD Jacobian is posted below, would you please
>>> check whether I am correct? Anything missed? Thank you!
>>> > ////////// Setup phase:
>>> > MatStructure flag;
>>> > ISColoring iscoloring;
>>> > ierr = MatGetColoring(Jac,MATCOLORINGSL,&iscoloring);
>>> > ierr =
>>> MatFDColoringCreate(Jac,iscoloring,&this->matfdcoloring);
>>> > ierr =
>>> MatFDColoringSetFunction(this->matfdcoloring,(PetscErrorCode
>>> (*)(void))__libmesh_petsc_snes_residual,(void *)this);
>>> > ierr = MatFDColoringSetFromOptions(this->matfdcoloring);
>>> > ierr = ISColoringDestroy(&iscoloring);
>>> > //////////// Apply:
>>> > ierr = MatZeroEntries(*jac);CHKERRQ(ierr);
>>> > ierr =
>>> MatFDColoringApply(*jac,solver->matfdcoloring,x,msflag,snes);
>>> > Best regards,
>>> > Li Luo
>>> > This message and its contents, including attachments are intended
>>> solely for the original recipient. If you are not the intended recipient or
>>> have received this message in error, please notify me immediately and
>>> delete this message from your computer system. Any unauthorized use or
>>> distribution is prohibited. Please consider the environment before printing
>>> this email.
>> Postdoctoral Fellow
>> Extreme Computing Research Center
>> King Abdullah University of Science & Technology
>> https://sites.google.com/site/rolyliluo/
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this email.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Postdoctoral Fellow
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191202/42159d15/attachment-0001.html>
