[petsc-users] (no subject)
Matthew Knepley
knepley at gmail.com
Mon Dec 2 06:21:35 CST 2019
On Mon, Dec 2, 2019 at 4:04 AM Li Luo <li.luo at kaust.edu.sa> wrote:
> Thank you for your reply.
> The matrix is small with only 67500 rows, but is relatively dense since a
> second-order discontinuous Galerkin FEM is used, nonzeros=23,036,400.
This is very dense, 0.5% fill or 340 nonzeros per row.
> The number of colors is 539 as shown by using -mat_fd_coloring_view:
Coloring is not appropriate for this matrix since you have enormous dense
blocks (I am guessing). It could work if you statically
condense them out or had a fast analytic Jacobian. With 540 colors, it
takes 540 matvecs to generate the action of the Jacobian.
Matt
> MatFDColoring Object: 64 MPI processes
> type not yet set
> Error tolerance=1.49012e-08
> Umin=1.49012e-06
> Number of colors=539
> Information for color 0
> Number of columns 1
> 378
> Number of rows 756
> 0 1188
> 1 1188
> 2 1188
> 3 1188
> 4 1188
> 5 1188
> Is this normal?
> When using MCFD, is there any difference using mpiaij and mpibaij?
> Best,
> Li
> On Mon, Dec 2, 2019 at 10:03 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> How many colors is it requiring? And how long is the MatGetColoring()
>> taking? Are you running in parallel? The MatGetColoring() MATCOLORINGSL
>> uses a sequential coloring algorithm so if your matrix is large and
>> parallel the coloring will take a long time. The parallel colorings are
>> MATCOLORINGGREEDY and MATCOLORINGJP
>> Barry
>> > On Dec 1, 2019, at 12:56 AM, Li Luo <li.luo at kaust.edu.sa> wrote:
>> > Dear Developers,
>> > I tried to use the multi-color finite-difference (MC-FD) method for
>> constructing the Jacobians. However, I find it is very slow compared to the
>> exact Jacobian.
>> > My implementation of MC-FD Jacobian is posted below, would you please
>> check whether I am correct? Anything missed? Thank you!
>> > ////////// Setup phase:
>> > MatStructure flag;
>> > ISColoring iscoloring;
>> > ierr = MatGetColoring(Jac,MATCOLORINGSL,&iscoloring);
>> > ierr =
>> MatFDColoringCreate(Jac,iscoloring,&this->matfdcoloring);
>> > ierr =
>> MatFDColoringSetFunction(this->matfdcoloring,(PetscErrorCode
>> (*)(void))__libmesh_petsc_snes_residual,(void *)this);
>> > ierr = MatFDColoringSetFromOptions(this->matfdcoloring);
>> > ierr = ISColoringDestroy(&iscoloring);
>> > //////////// Apply:
>> > ierr = MatZeroEntries(*jac);CHKERRQ(ierr);
>> > ierr =
>> MatFDColoringApply(*jac,solver->matfdcoloring,x,msflag,snes);
>> > Best regards,
>> > Li Luo
>> > This message and its contents, including attachments are intended
>> solely for the original recipient. If you are not the intended recipient or
>> have received this message in error, please notify me immediately and
>> delete this message from your computer system. Any unauthorized use or
>> distribution is prohibited. Please consider the environment before printing
>> this email.
> Postdoctoral Fellow
> Extreme Computing Research Center
> King Abdullah University of Science & Technology
> https://sites.google.com/site/rolyliluo/
> This message and its contents, including attachments are intended solely
> for the original recipient. If you are not the intended recipient or have
> received this message in error, please notify me immediately and delete
> this email.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191202/a135c26a/attachment.html>
