[petsc-users] petsc on windows
Sam Guo sam.guo at cd-adapco.com
Thu Aug 29 15:16:18 CDT 2019
Sorry, attachment again.
On Thu, Aug 29, 2019 at 4:01 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> Thanks for the quick response. Attached please find the configure.log
> containing the configure error.
> Regarding our dup, our wrapper does support it. In fact, everything works
> fine on Linux. I suspect on windows, PETSc picks the system mpi.h somehow.
> I am investigating it.
> Thanks,
> Sam
> On Thu, Aug 29, 2019 at 3:39 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Aug 29, 2019 at 3:33 PM Sam Guo via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Dear PETSc dev team,
>>>    I am looking some tips porting petsc to windows. We have our mpi
>>> wrapper (so we can switch different mpi). I configure petsc using
>>> --with-mpi-lib and --with-mpi-include
>>>  ./configure --with-cc="win32fe cl" --with-fc=0 --download-f2cblaslapack
>>> --with-mpi-lib=/home/xianzhongg/dev/star/lib/win64/intel18.3vc14/lib/StarMpiWrapper.lib
>>> --with-mpi-include=/home/xianzhongg/dev/star/base/src/mpi/include
>>> --with-shared-libaries=1
>>> But I got error
>>>              Configuring PETSc to compile on your system
>>> TESTING: check from
>>> config.libraries(config/BuildSystem/config/libraries.py:154)
>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>> for details):
>>> --with-mpi-lib=['/home/xianzhongg/dev/star/lib/win64/intel18.3vc14/lib/StarMpiWrapper.lib']
>>> and
>>> --with-mpi-include=['/home/xianzhongg/dev/star/base/src/mpi/include']
>>> did not work
>> Your MPI wrapper should pass the tests here. Send the configure.log
>>> To fix the configuration error,  in
>>> config/BuildSystem/config/package.py, I removed
>>>  self.executeTest(self.checkDependencies)
>>>  self.executeTest(self.configureLibrary)
>>>  self.executeTest(self.checkSharedLibrary)
>>> To link, I add my mpi wrapper
>>> to ${PTESTC_ARCH}/lib/petsc/conf/petscvariables:
>>> PCC_LINKER_FLAGS =    -MD -wd4996 -Z7
>>> I got libpetstc.dll and libpetstc.lib. When I try to test it inside our
>>> code, PETSc somehow crates a duplicate of communicator with only 1 MPI
>>> process and PETSC_COMM_WORLD is set to 2. If I set PETSC_COMM_WORLD to 1
>>> (our MPI_COMM_WORLD), PETSc is hanging.
>> We do dup the communicator on entry. Shouldn't that be supported by your
>> wrapper?
>>   Thanks,
>>      Matt
>>> I am wondering if you could give me some tips how to debug this problem.
>>> BR,
>>> Sam
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190829/78e8504d/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190829/78e8504d/attachment-0001.obj>
