[petsc-users] petsc on windows
Sam Guo
sam.guo at cd-adapco.com
Thu Aug 29 15:01:51 CDT 2019
Thanks for the quick response. Attached please find the configure.log
containing the configure error.
Regarding our dup, our wrapper does support it. In fact, everything works
fine on Linux. I suspect on windows, PETSc picks the system mpi.h somehow.
I am investigating it.
Sam
On Thu, Aug 29, 2019 at 3:39 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Aug 29, 2019 at 3:33 PM Sam Guo via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear PETSc dev team,
>> I am looking some tips porting petsc to windows. We have our mpi
>> wrapper (so we can switch different mpi). I configure petsc using
>> --with-mpi-lib and --with-mpi-include
>> ./configure --with-cc="win32fe cl" --with-fc=0 --download-f2cblaslapack
>> --with-mpi-lib=/home/xianzhongg/dev/star/lib/win64/intel18.3vc14/lib/StarMpiWrapper.lib
>> --with-mpi-include=/home/xianzhongg/dev/star/base/src/mpi/include
>> --with-shared-libaries=1
>> But I got error
>> Configuring PETSc to compile on your system
>> TESTING: check from
>> config.libraries(config/BuildSystem/config/libraries.py:154)
>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
>> details):
>> --with-mpi-lib=['/home/xianzhongg/dev/star/lib/win64/intel18.3vc14/lib/StarMpiWrapper.lib']
>> and
>> --with-mpi-include=['/home/xianzhongg/dev/star/base/src/mpi/include'] did
>> not work
> Your MPI wrapper should pass the tests here. Send the configure.log
>> To fix the configuration error, in config/BuildSystem/config/package.py,
>> I removed
>> self.executeTest(self.checkDependencies)
>> self.executeTest(self.configureLibrary)
>> self.executeTest(self.checkSharedLibrary)
>> To link, I add my mpi wrapper
>> to ${PTESTC_ARCH}/lib/petsc/conf/petscvariables:
>> PCC_LINKER_FLAGS = -MD -wd4996 -Z7
>> I got libpetstc.dll and libpetstc.lib. When I try to test it inside our
>> code, PETSc somehow crates a duplicate of communicator with only 1 MPI
>> process and PETSC_COMM_WORLD is set to 2. If I set PETSC_COMM_WORLD to 1
>> (our MPI_COMM_WORLD), PETSc is hanging.
> We do dup the communicator on entry. Shouldn't that be supported by your
> wrapper?
> Thanks,
> Matt
>> I am wondering if you could give me some tips how to debug this problem.
>> BR,
>> Sam
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190829/266b1212/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190829/266b1212/attachment.obj>
