[petsc-users] [petsc-dev] IMPORTANT PETSc repository changed from Bucketbit to GitLab
Lisandro Dalcin
dalcinl at gmail.com
Tue Aug 20 03:51:21 CDT 2019
Dear Satish, are you planning to migrate petsc4py?
On Mon, 19 Aug 2019 at 23:47, Balay, Satish via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> A note:
> The bitbucket repository is saved at
> https://bitbucket.org/petsc/petsc-pre-gitlab
> The git part is now read-only. The other parts [issues, PRs, wiki etc] are
> perhaps writable - but we should avoid that.
> Satish
> On Mon, 19 Aug 2019, Smith, Barry F. via petsc-dev wrote:
> > PETSc folks.
> > This announcement is for people who access PETSc from the BitBucket
> repository or post issues or have other activities with the Bitbucket
> repository
> > We have changed the location of the PETSc repository from BitBucket
> to GitLab. For each copy of the repository you need to do
> > git remote set-url origin git at gitlab.com<mailto:git at gitlab.com
> >:petsc/petsc.git
> > or
> > git remote set-url origin https://gitlab.com/petsc/petsc.git
> > You will likely also want to set up an account on gitlab and remember
> to set the ssh key information
> > if you previously had write permission to the petsc repository and
> cannot write to the new repository please email bsmith at mcs.anl.gov<mailto:
> bsmith at mcs.anl.gov> with your GitLab
> > username and the email used
> > Please do not make pull requests to the Gitlab site yet; we will be
> manually processing the PR from the BitBucket site over the next couple of
> > days as we implement the testing.
> > Please be patient, this is all new to use and it may take a few days
> to get out all the glitches.
> > Thanks for your support
> > Barry
> > The reason for switching to GitLab is that it has a better testing
> system than BitBucket and Gitlab. We hope that will allow us to test and
> manage
> > pull requests more rapidly, efficiently and accurately, thus allowing
> us to improve and add to PETSc more quickly.
Lisandro Dalcin
Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190820/7c36b018/attachment.html>
