[petsc-users] Accessing Global Vector Data with
Matthew Knepley
knepley at gmail.com
Mon Aug 19 10:41:59 CDT 2019
On Mon, Aug 19, 2019 at 10:24 AM Daniel Mckinnell <d_mckinnell at aol.co.uk>
wrote:
> Sorry I'm still a bit confused about this. I changed DMPlexPointLocalRef
> for DMPlexPointGlobalRef as shown in my attached code but got the
> following error:
You do not need the global section. I have rewritten your code and it works
for me.
Matt
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: [1]PETSC ERROR:
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see
> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] DMPlexPointGlobalRef line 313
> /home/daniel/petsc/src/dm/impls/plex/plexpoint.c
> [1]PETSC ERROR: likely location of problem given in stack below
> [1]PETSC ERROR: --------------------- Stack Frames
> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [1]PETSC ERROR: INSTEAD the line number of the start of the function
> [1]PETSC ERROR: is given.
> [1]PETSC ERROR: [1] DMPlexPointGlobalRef line 313
> [1]PETSC ERROR:
> I am guessing that this is because the array is not a global one but I'm
> not sure how you can produce a global array from a global Vec?
> Thanks,
> Daniel
> -----Original Message-----
> From: Matthew Knepley <knepley at gmail.com>
> To: Daniel Mckinnell <d_mckinnell at aol.co.uk>
> CC: PETSc <petsc-maint at mcs.anl.gov>
> Sent: Mon, 19 Aug 2019 12:13
> Subject: Re: [petsc-users] Accessing Global Vector Data with
> On Mon, Aug 19, 2019 at 4:46 AM Daniel Mckinnell <d_mckinnell at aol.co.uk>
> wrote:
> Thank you for the help, the "if (voff >= 0)" line was to prevent errors
> from looping over ghost vertices but it is better to just loop from the
> start of the vertices to the end of the physical vertices.
> I am really just trying to create an example file of a method to access
> the associated field data of a sample vertex in the global Vec, alter the
> field data and then set it back into the Vec object.
> The easiest thing to do is use
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexPointGlobalRef.html
> Thanks,
> Matt
> Best Regards,
> Daniel
> Sent: Thu, 15 Aug 2019 17:19
> On Thu, Aug 15, 2019 at 12:05 PM Daniel Mckinnell <d_mckinnell at aol.co.uk>
> wrote:
> Thank you, it seemed to work nicely for the fields associated with cells
> but I'm having problems with the field on vertices. The code for altering
> the field is as follows:
> for (int i = vStart; i < vEnd; i++)
> PetscScalar *values;
> PetscInt vsize, voff;
> PetscSectionGetDof(globalsection, i, &vsize);
> PetscSectionGetOffset(globalsection, i, &voff);
> You do not need the Section calls I think.
> VecGetArray(u, &values);
> Hoist GetArray out of v loop
> if (voff >= 0)
> This check is not needed I think. What you are doing here is a mix of
> local and global.
> What do you actually want to do?
> PetscScalar *p;
> DMPlexPointLocalRef(*dm, i, values, &p);
> p[0] = i + 1;
> VecRestoreArray(u, &values);
> Hoist RestoreArray out of v loop.
> Thanks,
> Matt
> The Global PetscSection is:
> PetscSection Object: 2 MPI processes
> type not yet set
> Process 0:
> ( 0) dim 2 offset 0
> ( 1) dim 2 offset 2
> ( 2) dim -3 offset -13
> ( 3) dim -3 offset -15
> ( 4) dim 1 offset 4
> ( 5) dim 1 offset 5
> ( 6) dim 1 offset 6
> ( 7) dim -2 offset -17
> ( 8) dim -2 offset -18
> ( 9) dim -2 offset -19
> ( 10) dim -2 offset -20
> ( 11) dim -2 offset -21
> ( 12) dim -2 offset -22
> ( 13) dim 1 offset 7
> ( 14) dim 1 offset 8
> ( 15) dim 1 offset 9
> ( 16) dim 1 offset 10
> ( 17) dim 1 offset 11
> ( 18) dim -2 offset -23
> ( 19) dim -2 offset -24
> ( 20) dim -2 offset -25
> ( 21) dim -2 offset -26
> ( 22) dim -2 offset -27
> ( 23) dim -2 offset -28
> ( 24) dim -2 offset -29
> Process 1:
> ( 0) dim 2 offset 12
> ( 1) dim 2 offset 14
> ( 3) dim -3 offset -3
> ( 4) dim 1 offset 16
> ( 5) dim 1 offset 17
> ( 6) dim 1 offset 18
> ( 7) dim 1 offset 19
> ( 8) dim 1 offset 20
> ( 9) dim 1 offset 21
> ( 10) dim -2 offset -5
> ( 11) dim -2 offset -6
> ( 12) dim -2 offset -7
> ( 13) dim 1 offset 22
> ( 14) dim 1 offset 23
> ( 15) dim 1 offset 24
> ( 16) dim 1 offset 25
> ( 17) dim 1 offset 26
> ( 18) dim 1 offset 27
> ( 19) dim 1 offset 28
> ( 20) dim -2 offset -8
> ( 21) dim -2 offset -9
> ( 22) dim -2 offset -10
> ( 23) dim -2 offset -11
> ( 24) dim -2 offset -12
> where points 4-6 on proc 0 and points 4-9 on proc 1 are vertices.
> The altered vec is:
> Vec Object: 2 MPI processes
> type: mpi
> Process [0]
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 5.
> 6.
> 7.
> 0.
> Process [1]
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 0.
> 5.
> 6.
> 7.
> 8.
> 9.
> 10.
> 0.
> 0.
> 0.
> However the altered values do not correspond with the offsets in the
> PetscSection and I'm not sure what is going wrong.
> Thanks for all of the help.
> Daniel
> From: Matthew Knepley via petsc-users <petsc-users at mcs.anl.gov>
> CC: PETSc <petsc-users at mcs.anl.gov>
> Sent: Thu, 15 Aug 2019 16:11
> On Thu, Aug 15, 2019 at 10:59 AM Daniel Mckinnell via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi,
> Attached is a way I came up with to access data in a global vector, is
> this the best way to do this or are there other ways? It would seem
> intuitive to use the global PetscSection and VecGetValuesSection but this
> doesn't seem to work on global vectors.
> Instead I have used VecGetValues and VecSetValues, however I also have a
> problem with these when extracting more than one value, I initialise the
> output of VecGetValues as PetscScalar *values; and then call VecGetValues(Other
> stuff... , values). This seems to work some times and not others and I
> can't find any rhyme or reason to it?
> I guess I should write something about this. I like to think of it as a
> sort of decision tree.
> 1) Get just local values, meaning those owned by this process
> These can be obtained from either a local or global vector.
> 2) Get ghosted values, meaning those values lying on unowned points that
> exist in the default PetscSF
> These can only get obtained from a local vector
> 3) Get arbitrary values
> You must use a VecScatter or custom PetscSF to get these
> For 1) and 2), I think the best way to get values normally is to use
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexPointLocalRef.html
> These also have Read versions, and Field version to split off a particular
> field in the Section.
> Does this help?
> Thanks,
> Matt
> Finally I was wondering if there is a good reference code base on Github
> including DMPlex that would be helpful in viewing applications of the
> DMPlex functions?
> Thanks,
> Daniel Mckinnell
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190819/2ba0c739/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190819/2ba0c739/attachment-0001.obj>
