[petsc-users] different dof in DMDA creating
Danyang Su
danyang.su at gmail.com
Thu Aug 15 11:18:22 CDT 2019
Hi Barry and Matt,
Would you please give me some advice on the functions I need to use to
set different dof to the specified nodes. For now, I use
DMPlexCreateSection that dof is uniform throughout the domain. I am a
bit lost in choosing the right DMPlex functions, unfortunately.
Thanks and regards,
Danyang
On 2019-02-07 1:53 p.m., Danyang Su wrote:
> Thanks, Barry. DMPlex also works for my code.
> Danyang
> On 2019-02-07 1:14 p.m., Smith, Barry F. wrote:
>> No, you would need to use the more flexible DMPlex
>>> On Feb 7, 2019, at 3:04 PM, Danyang Su via petsc-users
>>> <petsc-users at mcs.anl.gov> wrote:
>>> Dear PETSc Users,
>>> Does DMDA support different number of degrees of freedom for
>>> different node? For example I have a 2D subsurface flow problem with
>>> the default dof = 1 throughout the domain. Now I want to add some
>>> sparse fractures in the domain. For the nodes connected to the
>>> sparse fractures, I want to set dof to 2. Is it possible to set dof
>>> to 2 for those nodes only?
>>> Thanks,
>>> Danyang
