[petsc-users] questions regarding simple petsc matrix vector operation
Karl Lin
karl.linkui at gmail.com
Thu Apr 25 09:35:04 CDT 2019
Thanks for tip, I figured out the issue. I was linking to ilp64 instead of
lp64.
On Thu, Apr 25, 2019 at 12:34 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> I ran your problem fine on one process. no errors.
> Suggest you run under valgrind on your system:
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind or if that
> is not useful
> Run in the debugger with the option -start_in_debugger noxterm
> Good luck,
> Barry
> > On Apr 24, 2019, at 10:36 PM, Zhang, Junchao via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > How many MPI ranks do you use? The following line is suspicious. I
> guess you do not want a vector of global length 1.
> > 66 VecSetSizes(b,PETSC_DECIDE,1);
> > --Junchao Zhang
> > On Wed, Apr 24, 2019 at 4:14 PM Karl Lin via petsc-users <
> > Hi, there
> > I have been trying to get a simple program run with the following code:
> > 12 int main(int argc,char **args)
> > 13 {
> > 14 PetscErrorCode ierr;
> > 15 Mat A;
> > 16 Mat AT;
> > 17 Mat N;
> > 18 char name[1024];
> > 19 char vname[1024];
> > 20 char pass[1024];
> > 21 PetscBool flg;
> > 22 Vec b,x,u,Ab,Au;
> > 23 PetscViewer viewer; /* viewer */
> > 24 PetscMPIInt rank,size;
> > 25
> > 26 KSP QRsolver;
> > 27 PC pc;
> > 28 PetscInt its;
> > 29 PetscReal norm;
> > 30
> > 31 PetscInt n1, n2, n3, np1, np2, np3, p, jj;
> > 32
> > 33 PetscInt *cols, *dnz, *onz;
> > 34 PetscScalar *vals;
> > 35
> > 36 ierr = PetscInitialize(&argc,&args,0,help);if (ierr) return ierr;
> > 37
> > 38 ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
> > 39 ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
> > 40
> > 41 PetscMalloc1(1, &dnz);
> > 42 PetscMalloc1(1, &onz);
> > 43
> > 44 dnz[0]=2;
> > 45 onz[0]=1;
> > 46
> > 47 MatCreateMPIAIJMKL(PETSC_COMM_WORLD, 1, 2, 1, 2, 2, dnz, 2, onz,
> &A); CHKERRQ(ierr);
> > 48
> > 49 PetscMalloc1(2, &cols);
> > 50 PetscMalloc1(2, &vals);
> > 51
> > 52 jj = rank;
> > 53 cols[0]=0; cols[1]=1;
> > 54 vals[0]=1.0;vals[1]=1.0;
> > 55
> > 56 MatSetValues(A, 1, &jj, 2, cols, vals, INSERT_VALUES);
> > 57
> > 58 MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
> > 59 MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
> > 60
> > 61 VecCreate(PETSC_COMM_WORLD,&x);
> > 62 VecSetSizes(x,PETSC_DECIDE,2);
> > 63 VecSetFromOptions(x);
> > 64
> > 65 VecCreate(PETSC_COMM_WORLD,&b);
> > 67 VecSetFromOptions(b);
> > 68
> > 69 VecCreate(PETSC_COMM_WORLD,&u);
> > 70 VecSetSizes(u,PETSC_DECIDE,1);
> > 71 VecSetFromOptions(u);
> > 72
> > 73 VecSet(b, 2.0);
> > 74 VecSet(u, 0.0);
> > 75 VecSet(x, 0.0);
> > 76
> > 77 MatMult(A, x, u);
> > 78
> > 79 VecView(x, PETSC_VIEWER_STDOUT_WORLD);
> > 80 VecView(b, PETSC_VIEWER_STDOUT_WORLD);
> > 81 VecView(u, PETSC_VIEWER_STDOUT_WORLD);
> > 82
> > 83 VecAXPY(u,-1.0,b);
> > However, it always crashes at line 83 even with single process saying:
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> > [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> > [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
> and run
> > [0]PETSC ERROR: to get more information on the crash.
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Signal received
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.10.4, Feb, 26, 2019
> > I can't figure out why this would happen. The printout from VecView
> shows every vec value is correct. I will greatly appreciate any tips.
> > Regards,
> > Karl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190425/70fa9f44/attachment.html>
